Reply
Thread Tools View Mode
Old 24th Jan 2013, 01:19   #21
Mechh69
I think we can make that fit
Mechh69's Avatar
Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.
Nicely thought out and designed. I can't imagine the design work that went in to it. I look forward to the rest of the build. Nicely done!
__________________
Originally Posted by Deders View Post
What if you touch yourself with kittens?
I7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, BFG 260 GTX Core 216 X3, BFG 9600 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses
Mechh69 is offline   Reply With Quote
Old 24th Jan 2013, 16:03   #22
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
whooaaa, i thoght they were 20mm holes.
Thats crazy dude !
KoSoVaR^ is offline   Reply With Quote
Old 25th Jan 2013, 13:12   #23
NFusion
What's a Dremel?
NFusion's Avatar
NFusion has yet to learn the way of the Dremel
Originally Posted by Overminde View Post
Very nice mate.
Thank you both.
Yup, countless hours went into design, but at the end it will be worth it.
Thats crazy dude !
yea, 5x 180mm fans all with Magicool radiators for BEASTy cooling.
NFusion is offline   Reply With Quote
Old 29th Jan 2013, 14:01   #24
NFusion
What's a Dremel?
NFusion's Avatar
Short Update - Radeon HD 7950 Waterblock installation
EK Full Cover Water Block EK-FC7950 Acetal+EN
with EK-FC7950 Backplate
Taking apart 7950 and start cleaning TIM. I used Akasa TIM clean.
Cleaned GPU and applied thermal pads.
Applied fresh TIM. I used Arctic Cooling MX-2.
End result
Old 29th Jan 2013, 14:11   #25
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
Thats a nice looking card you've got there
Mankz is offline   Reply With Quote
Old 30th Jan 2013, 01:15   #26
KoSoVaR^
KoSoVaR^'s Avatar
thats looking awsome why not CSQ block?
Old 30th Jan 2013, 08:20   #27
Mankz
dat steak
Mankz's Avatar
Why not CSQ block?
Because CSQ is ugly?
Old 30th Jan 2013, 09:35   #28
WaRn00b™
bit-tech addict
WaRn00b™'s Avatar
WaRn00b™ has yet to learn the way of the Dremel
DAMN!! Very nice indeed!! Would love to do a scratch build like this one day, but alas, access to engineering equipment and skill to do this is what I lack.
Heck, if I were to attempt something like this, I'd probably end up missing a limb afterwards. :P
Subbed!!
WaRn00b™ is offline   Reply With Quote
Old 30th Jan 2013, 10:58   #29
Hukkel
Multimodder
Hukkel has yet to learn the way of the DremelHukkel has yet to learn the way of the DremelHukkel has yet to learn the way of the Dremel
Oldschool EK blocks = YES!!!
Also; new case design = YES!!!
Hukkel is offline   Reply With Quote
Old 30th Jan 2013, 15:11   #30
NFusion
What's a Dremel?
NFusion's Avatar
Yes, i think these blocks will look better in this build.
And the CPU block is also oldschool
Subbed!!
Thanks.
Don't worry you would be fine
Old 14th Feb 2013, 10:58   #31
NFusion
What's a Dremel?
NFusion's Avatar
Quick update.
I finally have all of components, so this project will go fast
I installed components and finished tubing.
Next up is leak testing, hopefully everything will go well
Old 14th Feb 2013, 12:14   #32
Father-Time
Multimodder
Father-Time has yet to learn the way of the Dremel
QFT!
NFusion, you sir are an extremely talented individual, looks AWESOME, great attention to detail and stunning execution.
Looking at it again, and again, and again the tubes going through the grill just look somewhat .... out of place i guess, kinda like an after thought, you could go with some bulkhead passthrough fittings just out side the bottom grill, use 45 degrees and you would still retain those luverly curves on the tube
Hope i didnt offend, still looks great either way
__________________
Current Project : Server mod incoming!
Father-Time is offline   Reply With Quote
Old 15th Feb 2013, 07:22   #33
NFusion
What's a Dremel?
NFusion's Avatar
Originally Posted by Father-Time View Post
QFT!
Hi Father-Time, thanks for the kind words, it means a alot to me.
Hmm, i also think bulkhead solution would be better, but i would have to order these fittings, which means waiting for atleast one and a half weeks to finish this build.
Normally this isn't a problem, but i have a client build that needs my time
No offense taken thank you for healthy criticism.
Old 19th Feb 2013, 09:20   #34
NFusion
What's a Dremel?
NFusion's Avatar
Hi everyone.
The Ignition project is on the final stretch. The leak testing went well, so i also did all the wiring, lighting
and finished project IgnitiOn.
Thank you everyone for kind words and encouragement.
Next project is a client build, so stay tuned
Old 19th Feb 2013, 13:19   #35
Father-Time
Multimodder
Well Done Mate!!
Looks fantastic, lighting looks really good without being too much, second to last pic, res looks stunning.
__________________
Old 19th Feb 2013, 13:55   #36
Hukkel
Multimodder
Looks really nice!
Old 20th Feb 2013, 10:59   #37
Lehani
Multimodder
Lehani's Avatar
Lehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the Dremel
wow really wonderful job you did on thise plastic cuttings and putting the case together, if it was me i rather coose to do something otherwise..
really great job high rated from here... do you make those laser cuttings for others :P?
__________________
Why did you buy that? - because i can
Mods: Watered Shadey
Lehani is offline   Reply With Quote
Old 21st Feb 2013, 08:12   #38
NFusion
What's a Dremel?
NFusion's Avatar
Hi Lehani.
Yes, i also do client builds and i'm seriously thinking about making one "production" case
Old 21st Feb 2013, 11:51   #39
panman9
What's a Dremel?
panman9 has yet to learn the way of the Dremel
Loving it so far
panman9 is offline   Reply With Quote
Old 21st Feb 2013, 12:37   #40
jamsand
Hypermodder
jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!
looks stunning!
jamsand is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
