Reply
Thread Tools View Mode
Old 22nd Dec 2012, 09:15   #1
BOBDBONE
Multimodder
BOBDBONE's Avatar
BOBDBONE has yet to learn the way of the DremelBOBDBONE has yet to learn the way of the DremelBOBDBONE has yet to learn the way of the DremelBOBDBONE has yet to learn the way of the DremelBOBDBONE has yet to learn the way of the DremelBOBDBONE has yet to learn the way of the Dremel
CES builds - Twin Phantom 820's for ADATA
HI guys-
I've been very busy with all these mods lately so I am just now starting a thread about these. I am about finished with paint now so I figured I would take a break and catch up on work logs. I have 5 different builds being displayed at CES this year. Enermax will have 3 and ADATA will have 2.
These 2 Phantom 820's will be built identical so that after the show they can have one at each of their HQ's on the west and east coast.
I came up with a paint design that would incorporate all of their colors/logo's. They pretty much left it up to me so I hope they like it. :P
So here are the victims -
These are stripped down to the frame and you can see I cut big windows into the side panels.
I'm only spraying the outside so I needed to mask off the interior. I used this special masking that is used for doing auto paint stencil work. It's super wide and I can just wrap it right around the center and be done.
Stick the panels back on and I'm ready to go!
Double the parts - double the fun.....
I sprayed a white epoxy up the middle and black epoxy on the sides. On the side panel with the funny shape bulge I sprayed it white too.
The reason for the 2 colors of epoxy is that I am spraying multiple colors and I don't want to spray a white paint over a black primer. It would take a lot of paint to hide the black underneath. THis picture shows the area painted in white now and I applied some stencils of their logo's.
I also wanted to give this raised area some depth so I added a fine line tape all around the perimeter so that it will leave a nice white line once I spray the next color over the top.
I matched their yellow as close as possible and I will be using it over the white areas. But, I will be doing some blending also. The raised panel area is going to be a lot of yellow and I will fade some white in around the ADATA name. Up the middle will be a fade that matches the SSD. It will fade out to black.
I spray teh white down first then follow up with yellow but I let the white bleed through so it makes the yellow pop even more. I also want to leave a faint white line in the dead center that looks like the SSD.
Now I start to fade the black into the yellow and white..
Base coats are done....
I pull the tape and stencils off so I can start laying down the clear..
Now you can see why I sprayed white in some areas too.
I also want the hummingbird tail and star looking things to have a flat black look so I am adding the stencils over the top of the base coat so that clear coat won't get on it. That will make it look flat. It looks flat until you hit it with clear and then the color jumps out. This black is a fine metallic. It's called Magnetic Black.
THis is what I was using for the idea.
Here is the first coat of clear....
That's all you get for now. Once I hit it with the buffer, I'll come back and show you the shine.
8)
__________________
_______________
www.bsmods.com
BOBDBONE is offline   Reply With Quote
Old 22nd Dec 2012, 17:27   #2
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Love the paint job so far mate!
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 22nd Dec 2012, 20:00   #3
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for president
That paint job is awesome.
__________________
Cosmos S Reaper L.R.E.C. Scorpio
Arya-under construction ROG Crawler-under construction
Pranja is offline   Reply With Quote
Old 22nd Dec 2012, 23:48   #4
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
the painting looks great!
KoSoVaR^ is offline   Reply With Quote
Old 23rd Dec 2012, 06:23   #5
BOBDBONE
Multimodder
BOBDBONE's Avatar
Thank you gentlemen.
Started putting things back together and thought I would get a few pics real quick. This pic shows the reflection of the paint. It's such a shiny clear black that I can see scratch marks from my super soft painter towels. I'll be waxing it so they will go away.
I pulled the stencils for the hummingbird tail and exposed the flat black. It really looks awesome in person. It looks like they are stamped into the panel.
And here you can see the mirror like reflection (even in the yellow). This camera I used is crappy so I will get much better pics at the end with the DSLR.
I have to fabricate a couple acrylic pieces for gpu covers and SSD brackets so I'm on to that as soon as I finish buffing the rest of the parts.
8)
__________________
_______________
www.bsmods.com
Old 23rd Dec 2012, 07:15   #6
Editor22
E22.BIZ
Editor22's Avatar
hats off for the paint job mate! top notch
__________________
Store: E22
Old 23rd Dec 2012, 08:03   #7
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
Paint looks amazing!
But can't help but feel the white letters on the yellow need a black border or the like to help them 'pop' out
Mankz is offline   Reply With Quote
Old 14th Jan 2013, 22:51   #8
BOBDBONE
Multimodder
BOBDBONE's Avatar
Sorry for the break in updates... been a long busy time getting so many mods ready for CES.
We went and conquered the show. Now I can throw up the final pics. Sorry I didn't get full detailed shots of the rest of the progress but there was no time.
I needed to make a piece that would really show off the ADATA name and SSD's since that was their big focus this year. I took several layers of acrylic and lit them so I would have a nice podium for the SSD mounts.
I bent a piece of white to use as the stand and bonded everything together. Then I bolted it through the bottom of the case.
I sprayed the back of the GPU pcb's black since Gigabyte uses blue. It wasn't going to match very well so I used conformal spray and then black paint really lightly.
I used NZXT Kraken coolers in them. The logo lights up and can be tuned with software to do all kinds of cool stuff.
Wire management was a lot of work but all the room inside this Phantom made it a hell of a lot easier than it could have been.
So here they are together ... TWINS!
You can also see that I made a cover that goes over the optical bay area to smooth it out.
And at the ADATA suite in Vegas...
Mission accomplished.
__________________
_______________
www.bsmods.com
Old 14th Jan 2013, 22:53   #9
Editor22
E22.BIZ
Editor22's Avatar
Finished up perfectly mate, congrats on a nice display
__________________
Store: E22
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
