#1 |
Trust me, I am doctor!
Blowholes with hidden screws
Here's a quick guide on mounting fans for blowhole use without having the ugly screws showing.
![]() ![]() The screws I am using have a 4mm diameter and are 16mm long. It is important that the heads are countersunk. First, key the heads of the screws with sandpaper or emery cloth. I used grit 100 paper ![]() ![]() Next mark out where the screws are to go. I just used an 80mm wire grill. I won't be cutting out the hole because this is a box I use to test stuff on before I do anything to aluminium. That, and I'm waiting on new holesaws ![]() ![]() ![]() For the adhesive I used 5 minute epoxy resin which is safe to handle in about 15 minutes and completely cured in one hour. I've been told JB Weld would be a much better option, so I'll probably use this in the future. Mix equal amounts of resin and hardner ![]() ![]() I have keyed the area for each screw with some more 100 grit sandpaper. Generously apply the adhesive to the head of each screw making sure it gets into the groove for the screwdriver. Any that gets out and leaks over the head of the screw will only help it stay in place. Here I placed a delta fan on top to keep the screws in the correct position, and placed a weight on top of the fan ![]() After an hour off came the fan ![]() Fix whatever 80mm fan you want to use in place (after cutting the hole out obviously) ![]() On the underside, you will see nothing but the blowhole and grill if you choose to use one ![]() Nice and strong |
#2 |
Yes, if you push the screws or try to pull them off... they will come off, but the weight of a fan and grill will not cause any problems and the adhesive will hold it very securely.
#3 |
After reading that JB Weld has steel particles in the resin, I tried a little experiement which was a complete success... If you are dremeling anything, steel or aluminium, don't brush the dust away. Scrape it onto an old cd or something, and mix it in with the epoxy. It should turn silver and holds much better.
#4 |
DeX, I wouldn't use superglue if I were you. Epoxy is quite cheap and is a lot stronger. Superglue tends to be very brittle. I bought some JB Weld the other day and mounted screws to alu sheets with it and it is a hell of a lot stronger.
#5 |
What happens if you change your mind?
#6 |
I'm talking about changing your mind about which fans to use. If they are glued onto the case then you will ruin the fan removing it. Besides, removing the bolts is easy. A sharp knock with a small hammer or similar will shear the epoxy.
#7 |
Good good, let us see
#8 |
I will when I get my new digicam in a week. My Finepix 2300 is on the blink. You're talking about 1mm unless you were to enlarge the screw holes on the fan, countersink the holes, or use thinner screws such as M3 (3mm dia)
#9 |
Countersinking actually creates a slope to the hole drilled. It allows countersunk screws, which have a triangular shaped head when viewed from the side, to sit in the hole and be flush with the surface. This means your fan will be closer to the steel/alu/whatever.
#10 |
Devil_h@ck, the countersunk screws are used because they have a flat heat. The only thing needing countersunk if there is too much of a gap is the fan/gril
Deviate, some laser cut grills come countersunk. sinizterguy, use a countersink. No seriously, it's an attachment for your drill and is cone shaped. |
#11 |
Yes, unless you have a wire grill which you can widen the holes of. Some laser cut grills have the holes already countersunk which means they sit almost flush with the case.
You can put rubber washers on with maybe a tiny gap. |
#12 |
I use JB weld for my mounts now. Oh, and IMO using moulding on the blowhole would defeat the purpose. When done properly, a laser cut grill will sit flush against the inside of the case panel and appear almost seamless.
#13 |
Never read that before. Nice case that
#14 |
And if the fan gets dusty or it needs replacing...?
#15 |
I'd rather undo a few screws than wrench the fan off and reglue it. Wouldn't you?
![]() Yes Koolvin's article was posted earlier in the thread. However, a guide does not necesserally have to be a never before done mod. |
#16 |
Didn't someone suggest just using hot glue to fix the fan to the case and not the bolts? In that case, to replace the fan you would have to pull the fan from the glue and reglue it.
#17 |
Amusing ain't it?
#18 |
The question was already answered on page one.... god I wish this threa was closed
| Tags |
| guide |
| Thread Tools | |
| View Mode | |
