#21 |
Minimodder
Looks good so far, I would like to see what kind of siding you will produce.
Just a tip about the wood, I don't know if you know this, if you do, kind of disregard the tip. When you glue wood side to side, make sure that the bindings are opposed. I noticed on the bottom that the bindings are not opposed, chances are it could be fine, but it could warp a little depending on where you'll be storing the case. I actually broke that rule on my project (deliberately) on the floor board on my desk. |
#22 |
Car lover and Speed Junkie
bindings? my wood vocab is rather dimunitive
#23 | |
Multimodder
Another update is here.
![]() Quote:
Thanks for the tip. ![]() HDD case in da haus! ![]() ![]() I decide to go with space for five drives, and some space for Raspberry Pi. Also i made radiator standoffs for easy radiator removal.
#24 |
Multimodder
Wow, this is going to be damn impressive
__________________
Main box: FX 6300 @4.2GHz, 8GB Value RAM, Nvidia GTX 470, Corsair Force GT 90GB, Silverstone PS07, Win7 |
#25 |
↓ Don't trust that face!
Oh, cool. So the pegs will be on the radiator and it will just slide in... cup, things.
__________________
#26 | |
Multimodder
I hope so, thanks.
#27 | |
#28 |
Uber Noob
looks good,
keep it up |
#29 |
Multimodder
Thanks
#30 |
Multimodder
Hi guys,new update is here.
![]() I cut the hole for I/O ports. ![]() Also i monted the radiator. ![]() And i got remaining parts for water cooling. ![]() To cool down water pump i got some old CPU heatsink. ![]() And finally sneak peak for tomorrow job.
#31 |
Multimodder
Are we going to see a custom res per chance
__________________
#32 |
Multimodder
Yes
![]() Today I finished reservoir. After drilling, gluing and stuff I got nice clean res. ![]()
#33 |
Minimodder
Great work!
I like the res.
#34 |
Multimodder
Thanks!
#35 |
Multimodder
Little update today.
![]() After some thinking I figure out how to mount the pump. On down side pump has two unused 4mm holes. ![]() I cut two 2 cm aluminum pieces and drill holes in it. ![]() And this is how it looks when mounted. ![]() ![]() ![]() ![]() One notice, screw is going through down side of the case and holding all that together. |
#36 |
Multimodder
Last important construction piece is done.
I present to you mobo tray. ![]() ![]() Measure twice, cut once. ![]() ![]() ![]() Mounted. ![]() ![]() Lets see how mobo fits. ![]() ![]() ![]() Few extra pic. ![]() ![]() ![]() I still need to mount two thermometers and first phase is over. |
#37 |
Thats one massive chipset cooler. and one sexy piece of acrylic reservoir
#38 |
Multimodder
@siliconfanatic; thanks
Long time no see. Time for another update. Apogee block didn't come with AMD mounting plate so I need to made one. I decide to use plexiglass. ![]() ![]() ![]() ![]() After some testing I found some screws and mount block on motherboard. ![]()
#39 |
Multimodder
looking good so far
#40 |
Multimodder
Thanks!
| Thread Tools | |
| View Mode | |
