Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 31st Dec 2012, 14:32   #1
GoodBytes
How many wifi's does it have?
GoodBytes's Avatar
GoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpit
Windows 8 Pro promotion >> ENDED <<
Hello everyone,
** Microsoft Promotion has ended **
This is a reminder that this is the last day to get Windows 8 Pro Upgrade is before Jan 31st. If you don't have the time now to upgrade to it, I would suggest to purchase it now, and later upgrade your system to it at your best convenient.
This is the last day for:
-> Purchasing Windows 8 Pro Upgrade for 40$ / £25.
-> Getting for Windows 8 Pro Windows Media Center + its codec pack (includes DVD playback ability) for free.
Remember, that you need a genuine, activated, OEM or RETAIL (UPGRADE included) license of Windows XP, Vista or 7 or any editions or versions (32/64-bit) to be eligible for Windows 8 Pro upgrade offer.
You have until February 28 to:
-> Upgrading Windows 7 PC purchase between June 2nd and January 31st, to get Windows 8 Pro for 15$ / £15.
Windows 8 Pro Upgrade offer:
US: http://windows.microsoft.com/en-US/windows/buy
UK: http://windows.microsoft.com/en-GB/windows/buy
Canada: http://windows.microsoft.com/en-CA/windows/buy
Media Center + Codec pack (includes DVD playback codec) for Windows 8 Pro (free):
US: http://windows.microsoft.com/en-US/w.../feature-packs
UK: http://windows.microsoft.com/en-GB/w.../feature-packs
Canada: http://windows.microsoft.com/en-CA/w.../feature-packs
PC with Windows 7 to 8 upgrade offer:
US: http://windowsupgradeoffer.com/en-US/Home/ProgramInfo
UK: http://windowsupgradeoffer.com/en-GB/Home/ProgramInfo
Canada: http://windowsupgradeoffer.com/en-CA/Home/ProgramInfo
Hurry and get it while you can.
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features.
Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB
GoodBytes is offline   Reply With Quote
Old 31st Dec 2012, 16:10   #2
NigelT
Multimodder
NigelT has yet to learn the way of the Dremel
Are you sure it's the last day? The link shows the 31st of jan for me?
I thought I had more time and won't get to download as I'm headin out for NYE in a mo.
NigelT is offline   Reply With Quote
Old 31st Dec 2012, 16:27   #3
supermonkey
Deal with it
supermonkey's Avatar
supermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpit
Indeed. I was just checking on that this morning and I also see January 31 as the deadline.
__________________
But of bliss and of glad life there is little to be said, before it ends; as works fair and wonderful, while still they endure for eyes to see, are their own record, and only when they are in peril or broken for ever do they pass into song.
-J.R.R. Tolkien, The Silmarillion
supermonkey is offline   Reply With Quote
Old 31st Dec 2012, 16:52   #4
thelaw
Cynical B*stard
thelaw's Avatar
thelaw can run Crysisthelaw can run Crysisthelaw can run Crysisthelaw can run Crysisthelaw can run Crysisthelaw can run Crysisthelaw can run Crysisthelaw can run Crysisthelaw can run Crysisthelaw can run Crysis
* Offer valid from October 26, 2012 until January 31, 2013 and is for individuals and small businesses needing to upgrade up to five devices.
Before i buy can anyone let me know if they have had any compability issues with applications/software like there was when Win XP went to win 7 and half of the games around stopped working?
Also as i use my pc for mainly games and watching movies is win 8 a worthwhile upgrade over win 7?
__________________
Main rig : I5 2500k @ 4.5Ghz / Asus P8P67 Pro / KUHLER H20 620 water cooler /16 GB 4x4gb Corsair Vengeance 1600 1.5v Ram / 2x Gigabyte GV-N460SO-1GI GeForce GTX 460 1GB super overclocked edition SLI'ed BABY / OCZ Vertex 2 60gb Sata 2 SSD + 2x 750GB samgsung drives / Coolmaster 700w gold series psu / antec 900 case with 120mm sickleflow fans / NZXT Sentry 2 fan controller / 2x 22 inch benQ full HD G222HDL 1920x1080 monitors and pair of Razer Carcharias for my sounds :-)
thelaw is offline   Reply With Quote
Old 31st Dec 2012, 17:47   #5
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for president
It depends if you are open minded enough to learn new ways of doing things, for the most part, if it works on windows 7, it should work on windows 8
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands
RichCreedy is offline   Reply With Quote
Old 1st Jan 2013, 06:27   #6
GoodBytes
GoodBytes's Avatar
Really sorry everyone, I miss read. I corrected the thread in the mean time.
Mod request: please delete this thread.
__________________
Old 1st Jan 2013, 07:41   #7
Bindibadgi
Omnipwntent
Bindibadgi's Avatar
Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.
It won't let me buy it because it's IP locked. I can't use my UK card to buy from Taiwan
EDIT: Bugger it. Wife will pay. And now she will ask what it is on her bill Why did you need to buy this Richard? What's wrong with Windows 7?
__________________
Slash88: That kettle video just made me go death thanks.
Fizzban: And it is being panda'd to..lame.
Bindibadgi is offline   Reply With Quote
Old 1st Jan 2013, 08:45   #8
theshadow2001
Ultramodder
theshadow2001's Avatar
theshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for president
I've just panic bought a couple of licenses, that could have waited for me to do a little thinking on what I actually need. Ah well.
...its one less than windows 8...duh!
theshadow2001 is online now   Reply With Quote
Old 1st Jan 2013, 08:50   #9
IamJudd
Hypermodder
IamJudd's Avatar
IamJudd is the Cheesecake. Relix smiles down upon them.IamJudd is the Cheesecake. Relix smiles down upon them.IamJudd is the Cheesecake. Relix smiles down upon them.IamJudd is the Cheesecake. Relix smiles down upon them.IamJudd is the Cheesecake. Relix smiles down upon them.IamJudd is the Cheesecake. Relix smiles down upon them.IamJudd is the Cheesecake. Relix smiles down upon them.IamJudd is the Cheesecake. Relix smiles down upon them.IamJudd is the Cheesecake. Relix smiles down upon them.IamJudd is the Cheesecake. Relix smiles down upon them.IamJudd is the Cheesecake. Relix smiles down upon them.
Lol... "This is one louder..."
__________________
i5 2500k OC4.7| Corsair 8GB 1600| ASUS P8Z68-V PRO Gen3 | Antec Kuhler 920
MSI GeForce GTX 560 Ti Twin Frozr 2GB OC| Fractal Define R3 | OCZ ZT650w
IamJudd is offline   Reply With Quote
Old 1st Jan 2013, 10:11   #10
Bitwacker
C# forever
Bitwacker's Avatar
Bitwacker has yet to learn the way of the Dremel
Thanks
__________________
i7-2600K | 16GB 1600 | ATI 5870 (Asus) | 2x120GB SSD (RAID 0) | 2x1TB Samsung F1 | Asus Xonar DX | 30" DELL | 2x23" Dell | Cooling: single water cooling loop
Bitwacker is offline   Reply With Quote
Old 1st Jan 2013, 12:09   #11
Picarro
I Mod, Therefore I Own
Picarro's Avatar
Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.
You don't NEED a valid license. You can do a clean install with the DVD, and then "Upgrade" from Windows 8 Pro to Windows 8 Pro. Then just put in your key and it will be activated.
__________________
Intel Core i5 2500k @ 5gHz -:- Gigabyte Z68X-UD3H-B3 -:- 2x4 gbCorsair Vengeance 1,5v 1600mHz -:- Gigabyte Windforce X3 GTX 670 -:- Crucial M4 128 gb -:- Samsung F3 Spinpoint 640 gb -:- Corsair H60 with 2x Gentle Typhoon 1850 in push-pull -:- Corsair HX650 -:- Lian Li A05FN -:- Dell U2410 flanked by 2x Dell U2001FP -:- BenQ W1000+ -:-
Picarro is online now   Reply With Quote
Old 1st Jan 2013, 13:10   #12
faugusztin
I *am* the guy with two left hands
faugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for president
The most stupid part of promotion ? If you got a device with Windows 8, upgrading to Windows 8 Pro is 69 euros .
__________________
Cerberus Core i7-2600K Asus P8Z77-I Deluxe GSkill RipjawsX 2x8GB DDR3-1600CL9 watercooled EVGA GTX670 Samsung 830 256GB Bitfenix Prodigy Seasonic X-460 Windows 8 Pro
Prometheus Xeon E3-1235 Asus P8B WS GSkill RipjawsX 2x4GB DDR3-1333CL7+2x8GB DDR3-1333CL9 Coolink Corator DS Force 3 240GB+4xWD30EFRX+2xWD20EARS+6xWD20EARX Nanoxia DS1 Seasonic X-460 Ubuntu 12.04
faugusztin is online now   Reply With Quote
Old 1st Jan 2013, 14:18   #13
theshadow2001
Ultramodder
Indeed. Just to switch stuff on thats already programmed into the operating system.
Old 1st Jan 2013, 14:56   #14
GoodBytes
GoodBytes's Avatar
I am really sorry :/
Hopefully you can sell them.
__________________
Old 1st Jan 2013, 15:07   #15
Picarro
Picarro's Avatar
You have 14 days of free return. Just call Microsoft - they can refund it for you.
__________________
Old 1st Jan 2013, 15:49   #16
hoochy
Need moar cooling
hoochy's Avatar
hoochy - it's over 9000!!!!!!!!1!1!1!!!hoochy - it's over 9000!!!!!!!!1!1!1!!!hoochy - it's over 9000!!!!!!!!1!1!1!!!hoochy - it's over 9000!!!!!!!!1!1!1!!!hoochy - it's over 9000!!!!!!!!1!1!1!!!hoochy - it's over 9000!!!!!!!!1!1!1!!!hoochy - it's over 9000!!!!!!!!1!1!1!!!hoochy - it's over 9000!!!!!!!!1!1!1!!!hoochy - it's over 9000!!!!!!!!1!1!1!!!hoochy - it's over 9000!!!!!!!!1!1!1!!!hoochy - it's over 9000!!!!!!!!1!1!1!!!
Thanks for the heads up GoodBytes.
Whats the difference between the £25 and £15 offer? Im a little confused - I bought an OEM copy of windows 7 and built a PC between the dates specified, does this mean I qualify for the £15 offer or does it need to be a ready build system with W7 on to qualify?
Either way I expect I will pick up the upgrade.
__________________
Fractal Design R3 | Intel Core i5 3570K @ 4.2 GHz | Corsair H60 Liquid | 2 x Sapphire 2GB OC 7850HD CrossFire | 8GB Corsair Vengeance 1600 | 500GB Seagate | 2 x 128GB Kingston v200 SSD | Asus Sabertooth Z77 | Corsair 650W | K60 w/ Reds | Razer Naga
hoochy is online now   Reply With Quote
Old 1st Jan 2013, 16:15   #17
GoodBytes
GoodBytes's Avatar
There is no difference. Try the 15 pound offer... if it gets rejected, simply get the 25 pound one.
__________________
Old 1st Jan 2013, 16:30   #18
hoochy
Need moar cooling
hoochy's Avatar
No theres a good idea!
I see there is a Windows Upgrade Assistant available that will scan your current PC and report any compatiblity issues with your current installed programs etc...
http://windows.microsoft.com/en-US/w...e-to-windows-8
Might be worth running for those thinking of ugrading and want to avoid any issues.
__________________
Old 2nd Jan 2013, 08:30   #19
thelaw
Cynical B*stard
thelaw's Avatar
Can i move it from PC to PC, Ie if i download it for my main PC on win 7 but decide its yucky for my everyday gaming machine and want to move it to the mrs older laptop which is currently running win XP would i be able too?
Or once its downloaded to my main PC its tied to it even if i re-install win 7 back onto it?
__________________
Old 2nd Jan 2013, 12:28   #20
CrazyJoe
Ultramodder
CrazyJoe's Avatar
CrazyJoe should be considered for presidentCrazyJoe should be considered for presidentCrazyJoe should be considered for presidentCrazyJoe should be considered for presidentCrazyJoe should be considered for presidentCrazyJoe should be considered for presidentCrazyJoe should be considered for presidentCrazyJoe should be considered for presidentCrazyJoe should be considered for presidentCrazyJoe should be considered for presidentCrazyJoe should be considered for president
You can also get 15% cashback from quidco from the Microsoft store, hooray!
CrazyJoe is online now   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
