Reply
Thread Tools View Mode
Old 31st Dec 2012, 16:45   #1
Marcos_Viegas
Supermodder
Marcos_Viegas's Avatar
Marcos_Viegas has yet to learn the way of the Dremel
Mini Box - Cooler Master Elite 120 Advanced - 01/02/ 2013 - Carbon Fiber!
Welcome to my new project using the mini itx case Cooler Master Elite 120 Advanced, the first changes were to "clean" the inside of the case:
Here's the video (in portuguese... ):
The cable management is messy, but I made this "montage" only to get a sense of how the VGA and PSU would stay in the case.
I started to modify the sides of the case, first place opening for installing the radiator 240:
Now taking all the side which will be installed in a different way, I will show in the next ups:
And now where the cut will be the VGA:
And here a test with the radiator:
In future posts I will detail all the hardware used in the project.
I hope you enjoyed.
Now news and finishing of parts, only next year.
Happy new year everyone!
Marcos_Viegas is offline   Reply With Quote
Old 2nd Jan 2013, 21:46   #2
Marcos_Viegas
Supermodder
Well, now the news ... The Water Cooler "custom" created by "Cooler Marcos" (in portuguese):
And here pictures of how the new WC was installed:
Next step will be to cover for VGA and also for the fans that will cool down the WC.
Thanks to all!
Old 2nd Jan 2013, 22:09   #3
patara
life is wonderful
patara's Avatar
patara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremel
the video card beautifully looks, (devil's translator of languages)
__________________
patara is offline   Reply With Quote
Old 7th Jan 2013, 20:20   #4
Marcos_Viegas
Supermodder
Thanks dude
I got the feet that I will install in the case, are known as "spykes" of ViaBlue, following the manufacturer's link: ViaBlue Spikes
And here the pictures:
Here they installed:
I hope you enjoyed.
Old 7th Jan 2013, 20:43   #5
Editor22
E22 | Hex-Gear
Editor22's Avatar
Editor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming Saiyan
oo man I have always wanted to use spikes for a build glad to see someone else doing it! they look brilliant!
__________________
Stores: E22 | HEX GEAR
Social: Youtube | Facebook
Projects: Evolution | K2 MK1 | 21
Editor22 is offline   Reply With Quote
Old 7th Jan 2013, 21:05   #6
OcSurfe
Uber Noob
OcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpit
DAYM those spikes!
good to see what can be done with a small build!
OcSurfe is offline   Reply With Quote
Old 8th Jan 2013, 00:17   #7
Marcos_Viegas
Supermodder
These "spikes" are very stylish, a friend of mine traveled to Germany and bought me this kit, I was lucky to get away with what he brought up.
They lend an air of "style" to the project, since the first time I've seen in a sound box, I wanted to buy some to test on a project, but as I needed a case "small" have not had the opportunity to test before, but I liked the result.
Originally Posted by OcSurfe View Post
DAYM those spikes!
They are very stylish even, really liked was how the visuals, combined with a very small case.
Old 15th Jan 2013, 19:38   #8
Marcos_Viegas
Supermodder
And for those who want news ... are below the photos.
I did the cover for VGA acrylic "fumê":
But it was not good, it gave some problems when folding and ended up crooked and there was to trash... Furthermore, in case the ASUS DirectCUII was only 3mm off the case, so I decided to do instead of cover, a frame.
And here are the phases, first glue the sheets, 2 and 1 aluminum acrylic "fumê":
I used Scotch epoxy glue Quick-Dry.
The next step was sanding 3 corners in 45º:
He took a heavy work and made a mess clueless, but the end result until it was good.
Still lack the finish and make the cuts to the frame.
I hope you enjoyed.
Old 16th Jan 2013, 03:09   #9
_-..zKiLLA..-_
Multimodder
_-..zKiLLA..-_'s Avatar
_-..zKiLLA..-_ has yet to learn the way of the Dremel
Cant see the pics mate
__________________
~ASUS M2N-SLI Deluxe AM2 NVIDIA nForce 570~
~AMD AM2 64X2 5600+ 3.25GHz~
~4gb G.Skill 4-4-4-12~
~nVidia 9800GTX+~
_-..zKiLLA..-_ is offline   Reply With Quote
Old 16th Jan 2013, 08:23   #10
Vetalar
*learning english*
Vetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming Saiyan
interesting build!!! but 12-channel fan-controller for mitx case is a bit overkill IMHO
and that spikes is good find!
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is offline   Reply With Quote
Old 16th Jan 2013, 22:06   #11
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
It looks like you got a little too rough with the sanding.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 16th Jan 2013, 23:27   #12
Marcos_Viegas
Supermodder
Try again, maybe slow to load.
I got this controller from my other project that I wore all channels.
I also really liked the look of the spikes, they left more stylish to the case.
I'll still give the finishing with sandpaper grain smoother, the piece is "unfinished"
Old 1st Feb 2013, 18:52   #13
Marcos_Viegas
Supermodder
And who was anxious for news, first I have to say that I gave up the idea of ​​making a cover for the VGA, because after installing I did not like the look, it was at odds with the look, so I chose to leave out, and all enveloped with adhesive 3M carbon fiber 3M™ Scotchprint® Wrap Film
Bonus:
I hope you enjoyed.
Old 1st Feb 2013, 23:56   #14
PcJunkie209
Multimodder
PcJunkie209 has yet to learn the way of the Dremel
Awesome work! I'm digging the open gpu and feet!!
PcJunkie209 is offline   Reply With Quote
Old 2nd Feb 2013, 17:34   #15
Marcos_Viegas
Supermodder
Thanks man!
Glad you enjoyed it, I tried to balance the visual, to be "clean", "stylish" and somewhat "traditional" with the colors.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
