Old 2nd Jan 2013, 14:38   #1
StreetSam
Multimodder
StreetSam's Avatar
StreetSam has yet to learn the way of the Dremel
GPU Folding
Hi All,
Over Xmas I was rooting about and found that I had nearly all the makings for another GPU Folding machine. I use 775pin eVGA/XFX/BFG 680i SLi boards because they have 3 PCIe slots that are double spaced. I found that I had two in the cupboard, with CPUs, RAM and coolers. Trust me this isn't unusual for me.
Anyway all I needed was a case and 3 Gfx cards. After a bit of research I thought I'd try the GTX650Ti.
Well they aren't the most powerful, roughly the same (500PPD less) as a GTX460(768). They are the same TDP(105W) as a GTS450, but run cooler then them by at least 15degC, in a similar case with the same fan profile set in MSI Afterburner.
You can compare the PPD in my .sig, and if anyone is interested I do a fuller write up, with figures.
__________________
Folding stats
Current Folding@Home stats
StreetSam is offline   Reply With Quote
Old 3rd Jan 2013, 15:23   #2
Chicken76
Hypermodder
Chicken76's Avatar
Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!
Interesting.
What brand did you go with?
__________________
Folding stats
Chicken76 is offline   Reply With Quote
Old 3rd Jan 2013, 17:04   #3
StreetSam
Multimodder
StreetSam's Avatar
The cheapest I could find, Palit. IMHO there is no point in buying more expensive cards, as any OC just puts more stain on them as they are to run 24/7. All I need now is the QRB to start on GPU WUs
__________________
Folding stats
Old 3rd Jan 2013, 17:15   #4
kirk46
Cheesecake Nom Nom
kirk46's Avatar
kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.
i cant imagen your electric costs with all those GPU's
ive just bought an GTX680 to add to list and for QRB when it starts also
__________________
2x Xeon 5620 @ 3.8GHz under water
3770k @ 4.8GHz, Custom loop, GTX680 OC'd
kirk46 is online now   Reply With Quote
Old 3rd Jan 2013, 17:38   #5
StreetSam
Multimodder
StreetSam's Avatar
Hi All,
Some accurate figures;
450@850 80-85degC (Mostly 3 in a case) TDP 105W
460@725 70-75degC (2 in a case) TDP 150W
650@950 60-65degC (3 in a case) TDP 105W
WU GTS450 GTX460(768) GTX650Ti
7623 13532 19210 18604
7624 12959 19405 18533
7625 13017 18913 18463
Figures are averages (mean) of all boards and use the HFM average of all WU of that type Folded.
The PPD/W figures for the 450 and 460 are nearly the same at 128PPD/W but the 650 is 177PPD/W
__________________
Folding stats
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
