Reply
Thread Tools View Mode
Old 3rd Jan 2013, 21:42   #1
Gobi
Minimodder
Gobi has yet to learn the way of the Dremel
LAN-Can - First build
Hello community and greetings from Finland!
First post and first build too, I have build many computers to stock cases and modified few. Nothing serious so far, here is few pictures of my latest HTPC-case:
Hardware:
Coolermaster Elite 120 Advanced
i5-3570k + Antec Kuhler 920
Asus P8H77-I
G.Skill 1600 4Gb
OZC 60Gb Vertex 3
Sleeved the PSU (first time), not happy with it. I didn't open the connectors, just cutted the wire -> sleeve -> shrink tube -> solder. I took about 25cm off from every wire. All cables will be sleeved eventually.
Color is from Harley-Davidson color chart, some pearl variant.
This case is still on hold, the front panel plastic "leaked" black color to base and final coat. I think the plastic primer did not do the job it was meant to do.
Now, back to business:
The base of this build was found on my workplace, which imports tools, chemicals and several other stuff. I found 3 old oil cans laying in a dusty compartment above shower room, had to reach out and take a picture of them.
(Sorry for bad image quality, used my SGS3)
They are dated to 1971-1973, the label says:
Silkolene Lubricants
Dalton & Co. Ltd
The Oil Refinery -
Belber Derbyshire
England
Phone 2374
^You in UK, does this ring any bells?^
Glad to have some info.
Plan is to make, like the title says, a compact portable LAN-case. The handle is ready, all i have to do is squeeze the parts inside.
Here is few pre-plan sketches, i modeled the can with Sketchup:
Must have:
Side window
Water cooling CPU+GPU (have only experience on that Antec 920)
Hardware (planned):
CPU: i-7 3770k
MBO: mATX Asus MAXIMUS V GENE Intel Z77
GPU: 7970/GTX680
All parts will be attached to a rig, which slides out from back.
I'll be back tomorrow.
Comments, suggestions? Please, leave a message.
Gobi is offline   Reply With Quote
Old 3rd Jan 2013, 21:42   #2
Gobi
Minimodder
I planned the base (red) which will be bolted to the bottom of the case:
Slides, which will be used to pull the rig (80's green) out, are still missing from there. First i thought making them myself, but couldn't find a way to make a slide which would slide that 350mm, which is needed to fully extend the rig out. Spotted slides from a kitchen cabinet maker and will use them. Called to a supplier and requested 2D drawings for the slides, they are made by Blum.
Fans will suck the air through bottom, radiator is 60mm thick. Will it be enough for that hardware?
Also, I called to a friend of mine, who works with laser cutters. Told my plan and got response to send drawings once the part plans are complete.
Tomorrow i'm going to crack the can open with Dremel, bought some extra cutting discs today.
Will post once job completed.
Old 3rd Jan 2013, 21:44   #3
Gobi
Minimodder
I went to workplace and started to cut the can. First I had to mark the cutting lines.
Cutting:
Grinding:
Finished:
It took 4,5 of those Dremel 0.75mm cutting disks to finish the job. I filled the can partially with water to prevent any fumes inside, because it was used to store hydraulic oil. In the heat of the work, i accidentally tipped it over, causing all the water to spill out from the cutted hole. Half of it went to my pants, the other half to floor.
Old 5th Jan 2013, 15:31   #4
Gobi
Minimodder
Finally got some work done. Now back to drawing board.
Old 7th Jan 2013, 20:14   #5
Gobi
Minimodder
Some progress again, only in design though. Many changes to original layout, removed the reverse layout from "must-have".
I ordered slides from UK, supplier here in Finland didn't have large stock.
Changed the Blum's to Schock Metall. Modeled the slides, they have full extension of 350mm.
I thought of soda blasting the can and re-painting it. Not sure about color theme yet.
Old 8th Jan 2013, 17:44   #6
Nealieboyee
Packaging Master!
Nealieboyee's Avatar
Nealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming Saiyan
I'm surprised nobody has commented on this yet. Looks good! Can't wait to see more!
__________________
BONNIE
AMD x4 750K @ 4.4GHz | Gigabyte GA-F2A88XM-DS2 | 4GB Kingston HyperX | HD 6670 | Sandisk Pulse 64GB | Corsair CX430 | Cooler Master Hyper 412S
Nealieboyee is offline   Reply With Quote
Old 8th Jan 2013, 17:58   #7
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
Yes, I like the idea. Looking forward to see how it progresses.
Subscribed!
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170i Pro|16GB|256GB M.2|500GB SSD|GTX 980|3007WFP-HC|Hadron Air
David is offline   Reply With Quote
Old 8th Jan 2013, 18:07   #8
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
The idea is awesome ,
k.3nny is offline   Reply With Quote
Old 8th Jan 2013, 20:10   #9
elAwesome
Multimodder
elAwesome's Avatar
elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.
Ths is going to be really interesting. I'm definately following this one!
elAwesome is offline   Reply With Quote
Old 8th Jan 2013, 20:32   #10
Gobi
Minimodder
Subscribed!
Yeyyy!
I've been designing the watercooling system, trying to fit 2 x 240 rad's behind those slides. Seems impossible at the moment, i think i figure something out.
Old 8th Jan 2013, 21:41   #11
SilveR_172
Supermodder
SilveR_172 has yet to learn the way of the DremelSilveR_172 has yet to learn the way of the Dremel
The looks very promising !
SilveR_172 is offline   Reply With Quote
Old 9th Jan 2013, 08:43   #12
dreps
Multimodder
dreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremel
looking interesting
dreps is offline   Reply With Quote
Old 9th Jan 2013, 09:41   #13
Lehani
Multimodder
Lehani's Avatar
Lehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the Dremel
as you said, i hope you change your mind during this project about the sleeving
but yea looks very interesting
__________________
Why did you buy that? - because i can
Mods: Watered Shadey 380t enlarged into mATX
Lehani is offline   Reply With Quote
Old 9th Jan 2013, 10:04   #14
jay2
Indonesian Modder
jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.jay2 is a hoopy frood who really knows where their towel is.
what the?
haha.. love it..
jay2 is offline   Reply With Quote
Old 9th Jan 2013, 15:49   #15
WhatTheTech
Macmodder Addict
WhatTheTech has yet to learn the way of the Dremel
Following - this has plenty of potential, I can't wait to see what you do!
WhatTheTech is offline   Reply With Quote
Old 9th Jan 2013, 19:54   #16
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Looking good. You CAN'T re-paint the can, though. The logo on the side is 90% of the can's charm. Give it a good clear-coating instead.
You can however, paint the insides and around the seams. -Well, you kinda have to.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 9th Jan 2013, 20:01   #17
Parge
the worst
Moderator
Parge's Avatar
Parge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming Saiyan
I agree! The current design is brilliant.
__________________
NCase M1 - 5820k @4.3Ghz - H105 - GTX 980ti - ASRock X99e ITX/ac - 16GB DDR4 - 3x SSD - 600w SFX - 29" Ultrawide - Xonar U7 - Bassshaker - RAT3 - Quickfire TK - Q90s - Orbweaver - Warthog
Parge is online now   Reply With Quote
Old 9th Jan 2013, 20:03   #18
Darkwisdom
Level 99 Retro Nerd
Darkwisdom's Avatar
Darkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming Saiyan
I'm with cheaps here. This is a great idea and the whole wow factor is the can it's in. You have to find a way to do it without getting rid of the logo. I'm liking this so far though. I'm gonna watch this one.
__________________
Main Rig: i3 3220 ~ GTX 970 Strix ~ 8GB Vengeance Ram ~ EVGA Supernova G2 750W ~ P8H77-m le ~ Samsung 830 128GB SSD ~ Steelseries GCv2 ~ Razer imperator ~
Darkwisdom is offline   Reply With Quote
Old 9th Jan 2013, 20:21   #19
Nealieboyee
Packaging Master!
Black interior would look great!
__________________
BONNIE
Old 9th Jan 2013, 20:29   #20
Gobi
Minimodder
Just when i thought that i had all worked out, you guys come and trash my plans!
Seriously, i was going to remove the both sides of the can, but you are right. The WOW!-factor of this project is the retro-look of the can. Cutting and painting would ruin it.
Window is staying, it's the "LAN" part of this mod. Or should i then go with sleeper-look, you know like sleeper-cars?
I thought of polishing the interior to mirror shine...
Reply
Tags
lan-can
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
