Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 4th Jan 2013, 10:21   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for president
Intel to launch sub-10W Ivy Bridge Y chips at CES
Ultra-low power chips heading to tablets.
http://www.bit-tech.net/news/hardwar...ivy-bridge-y/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter
bit-tech news correspondent, Custom PC columnist
I'm a filthy freelancer! Hire me!
Gareth Halfacree is offline   Reply With Quote
Old 4th Jan 2013, 10:41   #2
r3loaded
Ultramodder
r3loaded's Avatar
r3loaded is the Cheesecake. Relix smiles down upon them.r3loaded is the Cheesecake. Relix smiles down upon them.r3loaded is the Cheesecake. Relix smiles down upon them.r3loaded is the Cheesecake. Relix smiles down upon them.r3loaded is the Cheesecake. Relix smiles down upon them.r3loaded is the Cheesecake. Relix smiles down upon them.r3loaded is the Cheesecake. Relix smiles down upon them.r3loaded is the Cheesecake. Relix smiles down upon them.r3loaded is the Cheesecake. Relix smiles down upon them.r3loaded is the Cheesecake. Relix smiles down upon them.r3loaded is the Cheesecake. Relix smiles down upon them.
Well, you didn't expect to buy BGA soldered chips from Scan did you?
I'm guessing that these Y series will crop up in the Surface Pro?
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | MSI Radeon 7970 | 128GB Crucial C300 + 1TB Samsung F3 | CM Silent Pro Gold 600W | Samsung XL2270HD | KBT Race (brown switches) | Sidewinder X8
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400
r3loaded is offline   Reply With Quote
Old 4th Jan 2013, 11:07   #3
Anfield
Supermodder
Anfield has yet to learn the way of the DremelAnfield has yet to learn the way of the Dremel
its likely that they are headed for the surface pro yep, although given that haswell is around the corner I'd say don't buy a surface pro and wait for the surface pro 2 or whatever they'll end up calling it.
Anfield is offline   Reply With Quote
Old 4th Jan 2013, 12:04   #4
Stelph
Multimodder
Stelph has yet to learn the way of the Dremel
This news has certainly made me re-think buying a Clover Trail tablet if the release of these chips is so close! At the very least it should cause a dip in the price of the one im most interested in (Acer W510)
I do wonder however if there will be any performance benefit from these new chips or if it is simply power saving only, considering the W510 is capable of 8 hours (plus 8 hours more from the keyboard dock battery) these new chips will certainly be impressive
Why cant smartphones have similar leaps in battery life?
Stelph is offline   Reply With Quote
Old 4th Jan 2013, 12:30   #5
greigaitken
Multimodder
greigaitken has yet to learn the way of the Dremel
even if intel could flick a switch and get tdp to 1 watt, still doesnt do all that much for battery life when you still have to power the screen. If intel spent their next 10bn on battery tech instead, you'd get a better result, but then that would dilute their manufacturing advantage...
greigaitken is offline   Reply With Quote
Old 4th Jan 2013, 13:01   #6
jrs77
theorycrafting
jrs77's Avatar
jrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for president
Seeing the current i3-3217UE sitting at 17W, someone has to ask what they cut down to lower the power by almost half.
Maybe reducing clockspeed to 1-1.2 GHz and cutting down the iGPU aswell.
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB]
jrs77 is offline   Reply With Quote
Old 4th Jan 2013, 18:00   #7
azazel1024
Supermodder
azazel1024 has yet to learn the way of the Dremelazazel1024 has yet to learn the way of the Dremel
Likely reduced clock speeds of GPU and CPU combined with probably cherry picking the chips further than what is done for the ULV parts and then running at even lower voltages.
It might even involve going so far as changing the actual transistors on the chip to be extremely low leakage transistors.
Currently ULV Ivy Bridge chips seem to run roughly 4w per core loaded, so just the CPU end of things already is sub 10W TDP, though that doesn't include GPU or the other on die stuff (which when maxed out can push things to roughly 20w...which means TDP is exceeded, which results in the GPU being throttled a bit, to roughly 900Mhz to get back under the 17w TDP after a minute or so of turbo speeds exceeding TDP).
I'd would imagine that we are going to be looking at chips running in the 1-1.5Ghz range maybe with turbos that could boost them to 1.4-2Ghz range and probably a GPU running around 250Mhz base clock with maybe turbos in the 500-800Mhz range.
A fair amount slower than ULV Ivy even, but whicked faster than Cortex A15 or Atom (probably roughly 2-3x faster still than a quad core A15 for a dual core 1.5Ghz Ivy Bridge processor).
__________________
Core 2 Duo E7500, MSI P43-C51, 2x2GB G.Skill Eco DDR3 1600 Cas 7, OCZ Vertex 60GB, Vertex 30GB, Samsung F3 500GB, Samsung F4 2TB, Powercolor Go Green ATI 5570
azazel1024 is offline   Reply With Quote
Old 4th Jan 2013, 21:51   #8
Anfield
Supermodder
Yeah, this should eat atom for breakfast, although it does make it kind of questionable why intel even bothers with atom any more if they can scale the desktop cpus down to sub 10w.
Old 4th Jan 2013, 22:32   #9
Hanoken
Modder
Hanoken has yet to learn the way of the Dremel
"Last Vegas later this..."
um... you mean Las Vegas...?
__________________
Current Rig: i7 920 oc @ 3.5 GHZ, Evga X58 SLI FTW3, 24 Gb G Skill Sniper Ram @ 1600 Mhz
Evga 670 GTX FTW SLI
Need to build something new soon... I'm thirsting for a new build
Hanoken is offline   Reply With Quote
Old 4th Jan 2013, 22:44   #10
rollo
I Mod, Therefore I Own
rollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for president
With Arm chips below 4watts its still way too much for tablet or smartphone consumption which i guess is the idea.
Does not matter if it performs 10 times faster ( which it wont ) if it dies in 10mins flat.
a 10 watt apple ipad would last about 4hrs in full usage for reference.
Also something wierd is going on with intel chips and battery usage. As the samsung ativ thing with clevo chip lasts nearly 10hrs + without dock. The surface using the same chip scrapes in around 8hrs. so its not all intels fault. ( samsung ativ has a smaller battery than the surface does)
rollo is offline   Reply With Quote
Old 5th Jan 2013, 01:57   #11
dicobalt
Multimodder
dicobalt's Avatar
dicobalt has yet to learn the way of the Dremel
I think ARM's head is about to roll. Intel seems to have the power/performance advantage going forward.
dicobalt is offline   Reply With Quote
Old 5th Jan 2013, 08:09   #12
fluxtatic
Supermodder
fluxtatic has yet to learn the way of the Dremel
I'd agree - it hardly seems worth the bother that Intel will finally re-architect Atom into a proper OoO processor and put it on the current process node starting next year (Atom traditionally has been turned out in the older fabs that are a node behind the fabs used for the current generation - Ivy's on 22, Atom's on 32.)
If they can get IB down to 10, how low can Haswell go? Have to wonder, too, if maybe they'll just keep the Atom branding even if the arch inside is Haswell. Lucky for Intel that Atom doesn't have the lackluster reputation amongst the general public that it seems to with tech enthusiasts, and so the name won't hurt it.
fluxtatic is offline   Reply With Quote
Old 5th Jan 2013, 09:47   #13
r3loaded
Ultramodder
r3loaded's Avatar
While all Atom chips so far are essentially modernised derivatives of the Pentium 3 with PowerVR GPUs, future Intel Atom chips should be roughly based off the current-generation Core architecture of their time (e.g. Silvermont will share a lot with Haswell) and will use Intel's GPU IP. I think they're intending for Atom to be used in phones and mainstream tablets that require sub-4W TDP, with Core going in the high-end tablet/ultrabook market.
Apparently the arrival of the 14nm Broadwell architecture should bring low-power Core chips that are completely fanless. I can't wait to see what a fanless Surface Pro or MacBook Air looks like!
__________________
Reply
Tags
10w, arm, atom, ces 2013, core, intel, intel core, ivy bridge, ivy bridge y, processor, tablet, tdp, windows 8
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
