Old 6th Jan 2013, 05:04   #1
exiled
Minimodder
exiled has yet to learn the way of the Dremel
The Tempest
Hello All Wanted to build a case for myself till my son was asking around christmas for a pc so i figured id scrap my build which was already started to build another case just this one is a bit different its to house both a matx and a itx in the same case matx is my pc and the itx is going to be my sons so after 4 days of designing i came up with this
And with out keeping you hanging to long i started building friday since i have to build at my dads house progress has to be staggered days i can get there to build i try but at the same time i have to do things like keeping the project a secret from him so hopefully its kept from him till around February 19 his birthday so now for those seeking more pictures here we go
test fitting the mock up itx mobo
another shot
last shot of itx testing
took me quite a while to build the frame only working with limited tools at moment ie: drill press, riveter, metal shears, ruler and plan at moment
this is with the itx and matx mock up boards test fitting before i hard mount ether of them
had to ask for help for this shot couldn't take the picture while holding the matx
but that's where I'm at so far will be going back to my fathers tomorrow to work on some more and hopefully i can get the frame fully complete tomorrow then can start making the templates for the plexiglass hope you enjoy the write up so far.
exiled is offline   Reply With Quote
Old 6th Jan 2013, 22:58   #2
exiled
Minimodder
ok got some more progress done today itx motherboard bracing testing
having issues mounting the matx angle from bottom well testing mother board tray
all i can do at moment need to buy more aluminum turns out i didn't buy enough
well guys tell me what you think.
Old 7th Jan 2013, 00:49   #3
TheGreatSatan
Dark Lord of BT!
TheGreatSatan's Avatar
TheGreatSatan is the Cheesecake. Relix smiles down upon them.TheGreatSatan is the Cheesecake. Relix smiles down upon them.TheGreatSatan is the Cheesecake. Relix smiles down upon them.TheGreatSatan is the Cheesecake. Relix smiles down upon them.TheGreatSatan is the Cheesecake. Relix smiles down upon them.TheGreatSatan is the Cheesecake. Relix smiles down upon them.TheGreatSatan is the Cheesecake. Relix smiles down upon them.TheGreatSatan is the Cheesecake. Relix smiles down upon them.TheGreatSatan is the Cheesecake. Relix smiles down upon them.TheGreatSatan is the Cheesecake. Relix smiles down upon them.TheGreatSatan is the Cheesecake. Relix smiles down upon them.
ITX? Looks like it'll have a lot of deadspace
__________________
NEW GENESIS
Modified Azza Genesis with an Intel 2600K, Gigabyte Z68X-UD3H, 32GB (8GB x 4) Corsair XMS3, 480GB Sandisk Extreme, 240GB Sandisk Extreme, 1275 Watt Thermaltake 80 Platinum Modular PSU, EVGA GTX 690 4GB, and a Corsair H60
TheGreatSatan is offline   Reply With Quote
Old 7th Jan 2013, 03:47   #4
exiled
Minimodder
both ITX and MATX are in the plan along with 2 x 5.25 8 x 3.5 hd 4 x 2.5 ssd 2 x psu 4 x 120mm fans maybe water cooling to come led lightning but may have space left over but for my first build if its too big i will learn from the attempt
Old 10th Jan 2013, 07:28   #5
bluc
Supermodder
bluc has yet to learn the way of the Dremel
Looks good to me love big cases ! Will keep an eye on this build for sure subbed:thumbup:
Sent from my Nexus 7 using Tapatalk HD
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
bluc is online now   Reply With Quote
Reply
Tags
itx, matx, scratch build pc
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
