#41 |
We came, we saw, we mod, you awe!
hi everyone, i did a little more on the base and here are the pictures.
also a video to show ho the main keyboard drawer which is also the monitor base too will basically work. still a lot to do here. i had to stick another thicker ply plate to the base underneath to give it more stability. dont want it to bend under the SAMURAIs weight later on. as you can see the kvm will also be integrated. evene though the whole build is an all in one, i want that you can switch between the internal pc or the external source for more versatility. more to come two of the holes were not exactly lined up properly, have sewn them up with pegs again and will bore them anew to get them right. maybe its time i bought a ruler and went to the opticians ![]() i decided to shorten the base tunnel between the drawer and case to lessen the height in a whole of the case and compensate for the drawer height a bit. i chopped of about two inches, the picture shows only about one, but i cut twice to get it right. this is a 12 volt gear motor and will be driven back and forth by pole exchanging the wires and the biswitcher and here is the video first trial result of this ordeal. http://www.youtube.com/watch?feature...&v=g8hDt6nJuc0 http://www.youtube.com/watch?feature...&v=g8hDt6nJuc0 oops, anyone know how i can insert a youtube link here, somehow cant get it in more to come Last edited by abbas-it; 21st Jan 2013 at 17:41. |
#42 |
I'm insane, not stupid.
You just need to use [youtube]g8hDt6nJuc0[/youtube] tags like this to embed videos- and only include the part of the link after 'v='
__________________
ASUS P8Z77-M PRO | INTEL CORE i5 2500K @ 4.3GHZ | EVGA GEFORCE GTX 670FTW | CORSAIR VENGENCE DDR3 1600MHZ 2x 4GB | SAMSUNG SPINPOINT F3 1TB | TITAN FENRIR | ACER PREDATOR | WIN 7PRO x64
#43 |
Multimodder
nice idea you got there! very stylish
#44 |
#45 |
Minimodder
The drool-factor is getting bigger and bigger. keep up the work so we can awe.
#46 | |
here is a small update, its a back plate for the back which will have a purpose too when its ready. its not exactly finished yet though. will be doing more today and sending an update again asap. the back panel is drop in, i lift it up a bit under the top nippon bow and drop it into plave , so its doesnt have to be fixed, works great and gives me easy and quick access to the rear without any srewing needed. for the first plate i scrounged around in internet and found this one, will be slightly altered in design. more to come tonight.. |
#47 |
hi guys, so have worked a bit again today on the keyboard tray, still getting more conours into it. want to slant it of in the front and back too apart from that i have taken 2 envelope opener and they will be modded into the build too. they are miniature katanas and i have built a cross to hold them with one single rivet later on. they will be shield mounted under the helmet chin. so its back into the basement now to get some more done before beddy byes.
more to come later |
#48 |
hi guys, here is the next update, have been filing on the keyboard drawer a bit and also set in some ports at the back. still a lot to do but now the main base is finished i can decorate it accordingly. here is alsoa small video to show the top flap which moves up and down to cover the keyboard totally when retreated and concealed. tomorrow i will start decorating and doing it up to match the whole concept.
[IMG] more to come tomorrow |
#49 |
hi everyone, so its now time for an update again, have worked on certain different parts. the keyboard locker and the samurai fan etc.. here are some picx.
these are sliders so that the drawer doesnt touch the top flap. made of coathanger wires, will be polished afterwards every samurai has a ceremonial fan and even though its not exactly the feature i like the most, its part of the theme so here it is. will hold then camers chin prtotection servos, monitor leds and push buttons etc.. wehen painted it will look great. have carved and sanded it to look as if its really overlapper parts i needed more body and depth so here i fitted a frame around it. now i have enough depth for the elektronics looks pretty 3d ish, i like it will use these rivets to press the monitor button behind them this servo controler is for the chin dropper on the helmet, to close or open the camera view had to adjust and cut out the back cable tunnels a bit when this knob is fitted it hould make the fan look a bit like the japanese red dot in the flag and the ceremonial samurai fanner so guys, that all for now, more tonight or tomorrow, wanns get some paint on this one soon. hope the weather gets better so as for drying better.
#50 |
Hypermodder
sick, just sick.
Looking soo professional !
#51 |
What's a Dremel?
Abbas-it,
You're doing an awesome job so don't take this as critisim, merely a suggestion. The detail work is so stunning I cringe every time you show a hole drilled through it. How about making the fan manually rotate to reveal the controls behind it? Kinda like you did with the sliding webcam cover up top. Since I would probably mess up the powerplug hole if I tried something like this; I will take full credit for the whole project if you implement my idea! ;-) Mal Last edited by mal; 4th Feb 2013 at 20:13. |
#52 | ||
the fan is actually a dummy, even though i did think of making a real one. if i had then letting it open to show the buttons would have indeed been a good idea. but since i wanted to get it tough enough and to hold the servo fan ctrl. i made it this way, its not exactly finishe yet though. will change a lot. the knob is too big too, will also change. much much more to come. havent even started the rear yet either. i have a lot more surprises coming. am glad you like it
#53 |
Hypermodder
How did I miss this?! Words cannot describe all types of how awesome this is! Mad props dude, excellent!
__________________
Pexon PCs Pexon @ GH Steel Series 6G v2 w/ MX Black / Noppoo Choc Mini w/ MX Blues / Happy Hacking Keyboard Pro 2 Anthracite |
#54 |
Keep calm & mod on. =)
Love it abbas & keen as ever to watch it progress.
#55 | ||
hi everyone and all i can say is thanks for the motivating word from all of you, that reall helps and drives me to make this and every other build as good as i can possibly muster.. more to come late tonight, will be modding from 21 till about god knows when and will post after wards. |
#56 |
Belgian beer modder
this is true workmanship... everything looks so good, fits so well, it's pretty amazing.
Can't wait to see what else you've got planned.
__________________
Der_Meister: 100% completed, again... project log here. |
#57 | |
What's a Dremel?
Im living vicariously through your talent. I will stop now. Carry on. ![]() Mal |
#58 | |
more to come tonight, iits down in the basement for now and i will only submegre with something new to show, till then
#59 |
just amini update, have changed the monitor stud buttins to chrome instead of copper.
seeing as the eyelets leather bands will be chrome too, they match better more to come..have changed the form of the knob too a bit. |
#60 |
I've got wood
I'm loving the automated keyboard, that's an excellent feature. Keep up the great work, this one is excellent!
| Thread Tools | |
| View Mode | |
