Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 8th Jan 2013, 11:09   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Intel goes low-power crazy at CES
7W Ivy Bridge, new Atom, Haswell hints.
http://www.bit-tech.net/news/hardwar...tel-ces-2013/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 8th Jan 2013, 12:33   #2
r3loaded
Ultramodder
r3loaded's Avatar
r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.
While they were on updating the ultrabook spec, Intel really should have added some thickness and weight requirements. Some so-called ultrabooks are actually really thick and heavy yet they meet the other requirements of the spec.
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | XFX Radeon 7970 DD | 500GB Samsung 840 Evo | Samsung XL2270HD | KBT Race | Logitech G402
Mac: 13 inch MacBook Pro 2014 | 16GB RAM | Filco Minila Air | Magic Trackpad
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400 | Arch Linux
r3loaded is offline   Reply With Quote
Old 8th Jan 2013, 12:42   #3
greigaitken
Supermodder
greigaitken has yet to learn the way of the Dremel
until laptop screens are also sub 10w then then it doesnt matter all that much.
greigaitken is offline   Reply With Quote
Old 8th Jan 2013, 12:54   #4
Picarro
I Mod, Therefore I Own
Picarro's Avatar
Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.
I want Haswell out pronto because that will mean the launch of the Lenoxo X240 - which I desperately want for my studies.
__________________
Intel Core i5 2500k @ 5gHz -:- Gigabyte Z68X-UD3H-B3 -:- 2x4 gbCorsair Vengeance 1,5v 1600mHz -:- Gigabyte Windforce X3 GTX 670 -:- Crucial M4 128 gb -:- Samsung F3 Spinpoint 640 gb -:- Corsair H60 with 2x Gentle Typhoon 1850 in push-pull -:- Corsair HX650 -:- Lian Li A05FN -:- Dell U2410 flanked by 2x Dell U2001FP -:- BenQ W1000+ -:-
Picarro is offline   Reply With Quote
Old 8th Jan 2013, 17:51   #5
Blackshark
Multimodder
Blackshark has yet to learn the way of the Dremel
LoL - you young uns! Lenovo X240 for your studies :-) I remember when I wanted a P90 - (pentium) and managed to get buy it plus a rather nice 'triniton black' 15 inch sony monitor that (although) being 15inch weighed as much as the 23 inch giants at Uni (Southampton)
Good luck in your studies and I hope you get it
Blackshark is offline   Reply With Quote
Old 8th Jan 2013, 20:11   #6
OcSurfe
Uber Noob
OcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpitOcSurfe is almost as Godly as yodasarmpit
Low power will be the way most things will go,
Reduce power usage, reduce my bills, reduce global warming, SAVE THE UNIVERSE!
well done intel!
OcSurfe is offline   Reply With Quote
Old 8th Jan 2013, 22:57   #7
Skiddywinks
Hypermodder
Skiddywinks has yet to learn the way of the DremelSkiddywinks has yet to learn the way of the Dremel
This. Iterative power consumption decreases are always good, but when the single most power draining component is the screen, which are only getting bigger (especially in smartphones) and higher resolution, then you are going to get to the point where even a 70% decrease in draw from the SoC isn't going to make a difference to the 95% total energy draw the screen already had.
Skiddywinks is offline   Reply With Quote
Old 10th Jan 2013, 20:22   #8
Gtek
Doesn't raise the bar; he IS the bar.
Gtek's Avatar
Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.
Haswell GT3 + thin ITX - my cheesecake recipe
__________________
Gtek is offline   Reply With Quote
Old 11th Jan 2013, 21:06   #9
ssj12
Hypermodder
ssj12 has yet to learn the way of the Dremel
demand OLED screens then
ssj12 is offline   Reply With Quote
Reply
Tags
android, arm, atom, ces 2013, core i7-3689y, core-i53439y, cpu, haswell, intel, ivy bridge, kirk skaugen, lexington, north cape, smartphone
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
