#1 |
WIIGII!
bit-tech Staff
AMD unveils new APUs, SoCs and Radeon HD 8000 Series
Sadly, it's mostly limited to OEM customers.
http://www.bit-tech.net/news/hardwar...amd-ces-2013/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter bit-tech news correspondent, Custom PC columnist I'm a filthy freelancer! Hire me! |
#2 |
Post moar ponies.
bit-tech Staff
We should make clear, the 8-series parts are just 7-series re-brands, so 7970 owners, do not fret! This also means we wont be publishing any reviews of these parts.
#3 | |
Do you even mod, bro?
Doesn't make any sense.
__________________
Deep Silence 1 - 2500K @4.6Ghz - ROG Maximus V Extreme - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG |
#4 |
Is the daddy!
ooo could these be going into the Xi3 piston platform for the steam console?
__________________
Project log Mocha70 Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2 Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
#5 | |
Tech addict...
They should just keep the HD7970 name, I don't mind seeing the same name for 2 years...
__________________
Intel Core i3 3220 / AC Freezer 7 / ASUS P8B75-M LX / 2x4Gb DDR3 Gskill Sniper 1866Mhz / ATi HD5870 1Gb GDDR5 / Samsung T260 (HD) / Samsung 470 128Gb / Creative X-Fi Titanium / Corsair CX600 / CM 690 Intel Core i7 2670QM 2.2~3.1Ghz / 10Gb DDR3 1333Mhz / nVidia GT550M 2Gb / Intel 330 180Gb Intel Core i7 4770K@4.5Ghz / Noctua NH-U12P SE2 / ASUS Sabertooth Z87 / 2x4Gb Gskill Trident X 2400Mhz / AMD HD7970 3Gb / Samsung T260 / 2x Corsair Force GT 240Gb raid0/ Corsair HX-850W/ Silverstone FT02R-Wi |
#6 |
Ghost In The Machine
Anyone else think that the video for Win8 Gesture Control makes it look sluggish and retarded?
__________________
Motherboard - ASUS P5K Premium CPU - Q6600 @ 3GHz - Arctic Freezer 13 GPU - Palit 9600GT @ Clock 750MHz - Mem 1100MHz - Shader 1850MHz RAM - 6GB Corsair PC2-6400 DHX @ 960MHz
OS - Windows 7 Ultimate (64bit) |
#7 |
Supermodder
if bit-tech can include black mesa, a rebranded old HL1 game , on the game the the yrs list, then what amd is doing is just dandy also.
#8 | |
Soooo sluggish.
__________________
#9 |
What's a Dremel?
I really want AMD to focus on the development of their APU chips and am glad to hear the news regarding this. I recently built a system for my gf costing £350 that included the A10 5800k , 2133mhz Ram x8gb on a Mini-itx MSI motherboard. At 720p she can play much of the steam catalogue at high settings and i am really really impressed. Due to the size and low power requirements i was able to use a tiny case. If they continue in this direction (which i hope they do) i think AMD should partner with a company like Asus to make specially featured ITX or smaller mobo's. It seems to me that the size of enthusiast PC's are still the same size as they have been for decades, but if more focus is put on changing this then some really desireable systems/ tech could come to light
#10 | |
Supermodel
http://www.bbc.co.uk/news/technology-20949071 http://www.prnewswire.com/news-relea...185945182.html
__________________
ASUS P6X58D-E - Intel Core i7 930 - Thermaltake FRIO - 12GB Corsair (6x2G CMD12GX3M6A1600C8) - Corsair AX1200 - 2GB Sapphire Radeon HD5970 OC - 256Gb Crucial SSD - X-Fi Titanium Fatal1ty Pro - Silverstone Fortress FT02R-W Steam Profile ---------- XBL:Jedra ---------- PSN:Jedra ---------- BF3:Jedra7609 & Jedra |
#11 | |
Post moar ponies.
bit-tech Staff
#12 |
theorycrafting
Hmm... The A10-6800k is still on the 28nm process and still a t the 100W TDP. Seems like intel will be ahead of AMD for quiet a while to come.
I couldn't care less about the GPUs aswell, so I'm sticking with the mid-level intel + nVidia for the next two years to come I guess, but I don't think I need to upgrade within the next two years anyways.
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB] |
#13 | |
Marvin. I don't care what ^ says...
This has been the case in all camps for a while now, though Intel's refresh cycle is currently fast enough for this not to be an issue. |
#14 |
Hypermodder
So since the 8000 series will be for OEMs and will just be rebranded 7000s, I wonder if that means they'll just skip to 9000s for their actual new GPUs or make up some new numbers in the 8000 range just to confuse the crap out of people more.
Any news on new GPUs?
__________________
Sent from my PC using a keyboard |
#15 |
Multimodder
How disappointing. I thought there would be 'brand new' releases for retail :/
#16 |
Hypermodder
The current generation of APUs (Trinity) is produced using a 32 nm process, so Richland will be quite an upgrade, considering they will retain the 100W TDP after shrinking to 28nm. The CPU cores will use less power and/or will probably run at a higher frequency, and the GPU is GCN-based, as opposed to VLIW4 in Trinity.
#17 |
Supermodder
Well, if they're going to hawk re-names, I'll just stand there and tell people the AMD 8800 cards are licence built versions of Nvidia 8800s from 2006.
Someone will believe it... |
#18 | ||
Kill_All_Humans
Proof 1 - See in the following image from the presentation, "Richland" is shown as being 32nm, the same as "Trinity". Proof 2 - AMD says that "Richland" is "currently shipping to OEMs", which means that it has been in production for quite a few months for the wafer to be started and baked, the die packaged, and the finished APU sent to OEMs. It isn't being made at TSMC and GloFo 28nm isn't ready for production. Therefore, logically, it is 32nm. If "Richland" is A10-6800K, then it is 32nm. If it isn't, then A10-6800K isn't "Richland". Everyone saying 28nm has been referencing Fudzilla. He seems to be wrong. Quote:
No Steamroller and no GCN. More Fudzilla-branded FUD.
__________________
Main Rig: Amiga A1200 - Motorola 68EC020@14.2MHz + 68030@50MHz Acc. Card - Lisa Graphics - 2+8MB RAM - 80MB HDD
LAN Rig: Amiga A500 - Motorola 68000@8MHz - Denise Graphics - 512+512KB RAM Last edited by Gareth Halfacree; 8th Jan 2013 at 23:17. Reason: Merged double-post. |
#19 | |
WIIGII!
bit-tech Staff
__________________
#20 | |
Kill_All_Humans
Who is also claiming GCN for the core. I'd be really careful with claiming that, because "Richland" is looking like a refined "Trinity" rather than a new core, with the claimed performance increase possibly due to a larger/higher clocked GPU rather than a new GPU. I would be very surprised at GCN showing up so soon. EDIT: A bit of hunting and I found the 2013 Client Roadmap (PDF) on the AMD website. "Richland" is 32nm with 2-4 Piledriver cores and "2nd Generation DX11 GPU", which is as far as I can count is VLIW4 (VLIW5 being the 1st and GCN being the 3rd). Three versions: desktop, notebook (35w) and Low Voltage (17-25w). This close to release, if it was GCN it would say GCN, as it does for the 28nm Kaveri, Kabini and Temash APUs.
__________________
LAN Rig: Amiga A500 - Motorola 68000@8MHz - Denise Graphics - 512+512KB RAM Last edited by Adnoctum; 9th Jan 2013 at 00:27. Reason: Extra info |
| Tags |
| 28nm, a10-6800k, amd, apu, ces 2013, hsa, kabini, kaveri, radeon hd 8000, richland, soc, system on chip, temash, trinity |
| Thread Tools | |
