Reply
Thread Tools View Mode
Old 9th Jan 2013, 06:46   #1
do}{tor
What's a Dremel?
do}{tor's Avatar
do}{tor has yet to learn the way of the Dremel
project [Leonidas Beard]
"Tonight we dine in hell"©
System:
CPU: Intel i7 3960ES
MOBO: ASUS Rampage IV Extreme
RAM: Corsair Dominator Platinum 4*4Gb
SSD: Crucial M4 128Gb
HDD: WD 1*640 CB; 1*1,5Tb CG; 1*2Tb CG
VGA: 3*GTX 580 1,5Gb
Sound Card: Creative X-FI Titanium HD
PSU: Corsair AX1200
CASE: CaseLabs M10 + Extended top + Pedestal
_________________________________
Water:
Rad#1: TFC MONSTA Extreme
Rad#2: TFC MONSTA Lite
Rad#3: TFC MONSTA Lite
Rad#4: EK-CoolStream RAD XT (360)
Pump#1: DDC 1T
+ EK-DDC Dual TOP
Pump#2: DDC 1T
CPU block: EK HF Nickel Plexi
VGA block: EK-FC580 GTX Acetal+EN
FANS: Noiseblocker BlackSilentPRO 140mm, 1700rpm
CONECTORS: Monsoon, EK, Bitspower
LIQUID: Mayhems Blood Red
CONTROL: Lamptron Touch, Koolance TMS-200
I welcome you comrads! I write to you from the cold mother Russia
At once I ask me to forgive for my English, but I promise to try diligent
The idea on creation of this project arose in me very long. Initially everything was planned to make with the Cooler Master Cosmos PURE case, but for a number of reasons, work was constantly postponed. And once I was lucky to take hold from CASE LABS, namely M10 in white color To it were bought in addition a pedestal and extended top
Chief assistant always nearby
Also the period of long thoughts at the choice of a project subject came. Options was much, but everything united them availability of blood, a large amount of blood So I came to a subject of droppers, tubes, and other hospital attributes, but what there was my disappointment when I casually came across one of the projects of the present most beloved by me, namely the White Silence project
And again I fell into the abyss of thoughts...
Then I was come to mind by idea to devote the project of Slavic mythology. At detailed studying of the weapon of Slavs, I started finding certain similarities to a cold weapon of ancient Sparta... and here upon me dawned...HERE IT, I exclaimed! IT IS SPARTAAAAA!!!
Then received a clip from the beloved wife for shouts in the middle of the night
The history about 300 Spartans is one of my darlings, and how it was shown in Zack Snyder's movie of "300" adequately loud applause
I several times revised the movie, finally like idea and started a choice of the most spectacular moments, for the purpose of sketch creation.
And I came to 3 options:
1.
2.
3.
The third since there is more than dynamics and action was chosen.
Well and because my friend is engaged in an aerographics I was allowed to his equipment and work began:
In parallel with drawing, the lateral window was transferred to a laser engraving, here that appeared as a result:
The photo in a subject will be more better a bit later
And again painting...
If very long not to leave the room it is possible to catch very qualitative hallucinations
By the way, I decided to paint everything, a fitting's, water blocks, radiators, painted everything that came to hand... the cat managed to evade
In intervals between painting I entertained myself clothing of wires:
On fans stickers with the "300" logo were made:
The hardware assumed to an upgrade:
And again case...
With each portrayal the case starts coming to life, and it is all the second varnish coat
I couldn't avoid a blood subject:
Now I solve a problem of installation of tanks and I sew wires:
By the way here the established lateral window so looks:
The computer configuration, all stuffing and components of cooling I will add a bit later, unfortunately very much there isn't a lot of free time
All of happiness
do}{tor is offline   Reply With Quote
Old 9th Jan 2013, 09:15   #2
Sn00k3r
Minimodder
Sn00k3r's Avatar
Sn00k3r has yet to learn the way of the Dremel
niiiiice Airbrushing
Sn00k3r is offline   Reply With Quote
Old 9th Jan 2013, 10:50   #3
do}{tor
What's a Dremel?
do}{tor's Avatar
Sn00k3r
thx
Just the friend came around on a visit, brought gifts, I love such unexpected visits
Old 9th Jan 2013, 19:19   #4
OcSurfe
Uber Noob
OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.
I loved that caselabs case as stock,
what youve done to it is brilliant!.
cant wait to see all the internals in!
OcSurfe is offline   Reply With Quote
Old 10th Jan 2013, 04:08   #5
do}{tor
What's a Dremel?
do}{tor's Avatar
OcSurfe
As on me, so CaseLabs does excellent cases, but for me they as a blank sheet as a panel, it is possible to do anything, the main thing is the imagination and "straight arms". Here I also decided to add in it a little the inner world
And any brilliant demands a facet
Old 10th Jan 2013, 22:37   #6
ALS
Minimodder
ALS's Avatar
ALS has yet to learn the way of the Dremel
У Джеральда Батлера просто эпические роли получаются.
Пока что с экранки, но смысл, думаю, понятен )))
__________________
TinyBlackBox (Jr.)
ALS is offline   Reply With Quote
Old 11th Jan 2013, 14:00   #7
do}{tor
What's a Dremel?
do}{tor's Avatar
ALS
It is a little new things. Normally to test it didn't turn out since DDR isn't compatible on height to CM V10
Well and some samplers of a logo and holders of the tank:
My chief assistant constantly watches me
Old 14th Jan 2013, 09:16   #8
do}{tor
What's a Dremel?
do}{tor's Avatar
On days off continued to be engaged in production of holders. As the computer in the sorted condition should be drawn in the old manner. I will make some options, I will leave that will be pleasant more.
As faced a small problem when fastening tanks, it is necessary to think how to connect them to the top radiator:
They will be connected in parallel among themselves from above and from below by means of сristal-links:
Old 14th Jan 2013, 09:36   #9
Si_the-dude
Multimodder
Si_the-dude's Avatar
Si_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on you
Sub'd, can't wait to see more! Looks awesome!
Si_the-dude is offline   Reply With Quote
Old 14th Jan 2013, 13:31   #10
patara
life is wonderful
patara's Avatar
patara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremel
do}{tor Hello I am glad to see you,very interesting work,too it is very interesting that will turn out
__________________
patara is offline   Reply With Quote
Old 14th Jan 2013, 15:49   #11
AciD_RaiN
Multimodder
AciD_RaiN's Avatar
AciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run Crysis
Very nice airbrushing
AciD_RaiN is offline   Reply With Quote
Old 15th Jan 2013, 11:35   #12
do}{tor
What's a Dremel?
do}{tor's Avatar
patara
I am glad you to see too! I hope it will turn out to realize all ideas!
AciD_RaiN
thx
I decided to polish bp for CPU, here result of an hour of work
Old 15th Jan 2013, 13:02   #13
patara
life is wonderful
patara's Avatar
work very interesting when there will be the following party of a photo?
__________________
Old 16th Jan 2013, 05:45   #14
do}{tor
What's a Dremel?
do}{tor's Avatar
patara
Now I waiting for the remained components for final assembly, approximately plan to finish assembly on the first week of February, the test for a leak and the first inclusion there will be carried out, and after it there will be an organized professional photoset. Now, as you see, I am engaged in any trifles, I will cut today the controler of fans
Old 16th Jan 2013, 16:19   #15
Nikkop
Multimodder
Nikkop's Avatar
Nikkop has yet to learn the way of the DremelNikkop has yet to learn the way of the Dremel
THIS IS MADNESS!
Madness? THIS IS PURE AWESOME!
Nikkop is offline   Reply With Quote
Old 16th Jan 2013, 19:17   #16
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Bloody awesome!
Cat:
1= "Don't paint me!"
2="put the brush down..."
3="Don't even try it!"
4="I said, Don't paint me!!!"
Cheapskate is offline   Reply With Quote
Old 17th Jan 2013, 09:33   #17
do}{tor
What's a Dremel?
do}{tor's Avatar
Nikkop, Cheapskate
Hmm, I didn't expect that with placement of tanks there will be any difficulties, but so even it is more interesting
By the way here such here clip-on earrings turned out, made for the future of 8 mm of plexiglas
Old 22nd Jan 2013, 11:50   #18
do}{tor
What's a Dremel?
do}{tor's Avatar
The panel for fixing of couple of tanks with a logo, and as a substrate for the TMC-200 controler was made
Old 7th Feb 2013, 04:58   #19
do}{tor
What's a Dremel?
do}{tor's Avatar
Few new photos
Old 7th Feb 2013, 06:50   #20
GotMod?
Minimodder
GotMod?'s Avatar
GotMod? has yet to learn the way of the DremelGotMod? has yet to learn the way of the DremelGotMod? has yet to learn the way of the Dremel
That's bloody awesome!!!:thumb
Keep up good work!
__________________
'Monochrome' Lian Li V600FB - Finished
GotMod? is offline   Reply With Quote
Reply
Tags
300, aerographics, caselabs, sparta, water cooled
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
