#1 |
Post moar ponies.
bit-tech Staff
Xigmatek Midgard II Review
http://www.bit-tech.net/hardware/cas...rd-ii-review/1
A £50 case with all the features of a much more expensive chassis.
#2 |
No disassemble!
Would you say it's possible to mount a 45-50mm thick rad in the roofspace and mount exhausting fans underneath? Depending on the layout of your motherboard, it looks possible from the pics.
I do like this case - there's a lot on offer for the money.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes! 2500K|Gene-Z|8GB|670|X-Fi|V1200+|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|360 GTS|240 UT60 |
#3 |
Ghost In The Machine
By the looks of the mounting screw points for the MB I would doubt it as they seem to be as far to the edge as they can go. I'll wait for BT to confirm though... :-)
__________________
Motherboard - ASUS P5K Premium CPU - Q6600 @ 3GHz - Arctic Freezer 13 GPU - Palit 9600GT @ Clock 750MHz - Mem 1100MHz - Shader 1850MHz RAM - 6GB Corsair PC2-6400 DHX @ 960MHz
OS - Windows 7 Ultimate (64bit) |
#4 | |
No, seriously, wtf is a dremel?
bit-tech Staff
#5 |
If not Dogbert666, would it be possible to contact/request for a larger roof space unit instead to accommodate water cooling rads? Maybe even as a separate purchase although this would increase the overall cost and therefore affect the overall value.
__________________
#6 | |
No disassemble!
I'm thinking that 120mm fans might fit, albeit overhanging the motherboard, I've done this before, in a different case. A lot depends on clearance for VRM sinks, the EPS 12v connector and possibly ram slots. It looks like it would be easy enough to mod it, by removing the mesh and making a raised area from other mesh.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes! 2500K|Gene-Z|8GB|670|X-Fi|V1200+|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|360 GTS|240 UT60 Last edited by Spreadie; 9th Jan 2013 at 14:28. Reason: sh!tty grammar |
#7 |
@Spreadie: Fare enough if you have to tools and the know how. I don't though. :-(
__________________
#8 | |
Good news everyone!
__________________
2500K | Corsair H55 | HIS 7950 | 8GB XMS3 | 128GB Crucial M4 | Samsung 2TB | ASRock H77M-ITX | Corsair CX500M | White Bitfenix Prodigy | Dell U2311H | Creative T6060s | Ducky G2 Pro TKL (Reds) | Logitech G500 Why. |
#9 | |
No disassemble!
Damn you, Shirty, damn you! I will have my revenge!
![]() Quote:
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes! 2500K|Gene-Z|8GB|670|X-Fi|V1200+|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|360 GTS|240 UT60 Last edited by Spreadie; 9th Jan 2013 at 11:46. |
#10 |
Good news everyone!
Touché
Nice case for the money by the way, but I'm still happy with my sleepy little P182
__________________
#11 |
Minimodder
There's plenty of room for a radiator even with standard philips screws. Use a slim 30mm radiator along with Scythe's 12mm fans and you have 8mm clearance left over!
http://www.scythe-usa.com/product/ac...12_detail.html http://www.frozencpu.com/products/15...?tl=g30c95s160 |
#12 |
This brings up an interesting idea... How would 2 of those 12mm fans (doubled up) do compared to a single 25mm fan? Would they cause wind turbulence and would that have a negative effect?
__________________
#13 |
No disassemble!
Those Slipstream fans have zero static pressure and poor airflow = absolutely useless for a radiator, unfortunately.
__________________
#14 |
Uber Noob
i quite like the case,
looks very shinobi-esqe |
#15 |
Multimodder
Haha! I thought that was an 8 track sticking out of the top on the first page!
#16 | |
bit-tech Staff
#17 |
No disassemble!
Thanks for taking the time to go back and check it out, Dogbert. It is appreciated.
__________________
#18 |
Good news everyone!
Rep for going the extra mile Matthew
__________________
#19 | ||
bit-tech Staff
#20 |
What's a Dremel?
Great review, definitely a case to look when I get around to my next build.
On a side-note it's interesting the BT found the air cooling of the Corsair 200R to be so poor. I've just been reading a review of the 200R over at HardOCP, who found the air cooling to be excellent compared to other budget cases. Obviously there will be methodological differences between websites as to how they test air cooling, but it seems odd that their conclusions can vary so wildly? |
| Thread Tools | |
