Reply
Thread Tools View Mode
Old 9th Jan 2013, 20:47   #1
flix
Minimodder
flix's Avatar
flix has yet to learn the way of the Dremelflix has yet to learn the way of the Dremelflix has yet to learn the way of the Dremelflix has yet to learn the way of the Dremelflix has yet to learn the way of the Dremel
Aprire - Lian Li PC-7HX -- VOTING ONLINE-- final pics
Hey guys,
I want to enter the Lian Li Contest so I bought an Lian Li PC-7HX.
There is just one Problem, there are still 9 days left.
This is what I've done so far.
I think this weekend will be very hard.
I'd rather let the pictures tell, so let me just say that the theme of the mod is Lamborghini. I really like these cars and I let myself inspired by especially the Lamborghini Aventado and Reventon.
Here some pics of the original case:
The finish is actually to nice to destroy, but who cares? :eleph:
Big thanks to my girlfriend and a friend of mine which helped out some times working on the case.
Now I'm very proud to name the sponsors of this project:
Caseking supports this project with some nice stuff from Bitfenix.
Thanks a lot
I hope you have fun while reading this worklog and I'm happy for every feedback
__________________________________________________ ________________________________________________
Now lets start with the first real update about what I did so far!
At first I disambled all the stuff I didn't need, that was a lot But I didnt take pictures.
Second step: I cutted some angle sections:
These parts were mounted on top of the case. But why? :P
After that, I began to cut out some plexiglass.
After cutting it, I arrange the parts...
...and began to glue them together:
Some parts were bended by using a heat gun:
Adjusted, ground and mounted:
Continued the glueing:
Now it looks like that:
The top of the case must be adjusted to fit the All in One Watercooler from Enermax:
Now it's time for the highlight of this mod.
What would a Lamborghini mod would be without some gull-wing doors?
I will use some gas springs which are normally used for furniture.
The bracket on the sidepanel:
At the end some pics of the working sidepanels:
I hope you like it.
flix is offline   Reply With Quote
Old 9th Jan 2013, 21:02   #2
siliconfanatic
Car lover and Speed Junkie
siliconfanatic's Avatar
siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.
nnnnnnnnnniiiiiiiiiiiiiiice. the idea you had for the scoops, with actual "channels" gives me a just the solution ive been looking for for the sidepanel im planning. nice touch with the doors too.
__________________
Originally Posted by quizz_kid View Post
Blackalize it!
I *am* the guy who loves too many threads to bump them all.
siliconfanatic is online now   Reply With Quote
Old 9th Jan 2013, 21:42   #3
dream1
Multimodder
dream1's Avatar
dream1 has yet to learn the way of the Dremel
Wow very nice i like the sidepanels. keep it up
dream1 is offline   Reply With Quote
Old 9th Jan 2013, 23:28   #4
exexs
Multimodder
exexs's Avatar
exexs has yet to learn the way of the Dremel
Wooow! very nice panels! Gonna follow this one x)
__________________
Support and comments for my FIRST worklog are appreciated: http://forums.bit-tech.net/showthread.php?t=228161
exexs is offline   Reply With Quote
Old 10th Jan 2013, 01:04   #5
Sissilisko
Multimodder
Sissilisko has yet to learn the way of the Dremel
Well that's cool :P
__________________
Finished:
-Mini-PC http://forums.bit-tech.net/showthread.php?t=248203
unfinished:
none!
Sissilisko is offline   Reply With Quote
Old 10th Jan 2013, 02:43   #6
siliconfanatic
question: will the left side-panel end up becoming a functional scoop? blowing more air into the case?
__________________
Blackalize it!
Old 10th Jan 2013, 07:06   #7
Sn00k3r
Minimodder
Sn00k3r's Avatar
Sn00k3r has yet to learn the way of the Dremel
Wuhuuu, thats what i call fancy Sidepanels
subbed
Sn00k3r is offline   Reply With Quote
Old 14th Jan 2013, 20:04   #8
flix
Minimodder
flix's Avatar
At the weekend I started with the front. First I cutted some plexiglas and aluminium bars and screwed it together:
Mounted on the case:
Filed it :
Didn't take a lot of pictures these days, but it was every time the same kind of work: cutting, glueing and filing the plexiglass.
I continued with the front:
Cutting this parts by using a scrollsaw:
Started to grind the front and mounted it on the rest of the case:
Some other Hardware I am going to use:
I love this card
Still a lot of work to do...
Old 14th Jan 2013, 20:14   #9
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
That l00ks insanely cool Flix! love the shapes you have created
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 14th Jan 2013, 20:24   #10
exexs
Multimodder
exexs's Avatar
You've got some impressive acrylic skills my friend x)
__________________
Old 15th Jan 2013, 20:12   #11
flix
Minimodder
flix's Avatar
Thanks a lot.
Update time
The front is nearly done.
Tomorrow I won't go to university... deadline is comming :shocked:
At first I want to mount the fan controller inside but I didn't quite know how. So i decided to mount it at a "standard" place.
I don't like to see it all the time so I need a cover. I used some tiny magnets to hold it. Works great.
This is how it looks at the moment:
Hope you like it, see you tomorrow
Old 15th Jan 2013, 20:24   #12
sui_winbolo
Computer Technician
sui_winbolo's Avatar
sui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysissui_winbolo can run Crysis
Oh wow, amazing customization. Can't wait to see more!
__________________
SUI-OMEGA
:: Intel i5-2500K | ASUS P8Z68-M Pro | Corsair Vengeance LP 8GB RAM | XFX 6870 1GB | WD Black 1TB HDD | Corsair Pro 650w PSU | Lian-Li Mini Tower ::
sui_winbolo is offline   Reply With Quote
Old 16th Jan 2013, 23:54   #13
siliconfanatic
Lookin good! and im guessing that only the smaller scoops/intakes will be functional from all that bondo. or is your psu not balls enough to power enough fans to sound like the actual car
__________________
Blackalize it!
Old 17th Jan 2013, 08:38   #14
dreps
Multimodder
dreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremel
very nice looking mod! cant recognize the original
dreps is offline   Reply With Quote
Old 17th Jan 2013, 09:08   #15
jamsand
Hypermodder
jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!jamsand - it's over 9000!!!!!!!!1!1!1!!!
subb'd the mother subbin sub out of this
jamsand is offline   Reply With Quote
Old 17th Jan 2013, 18:26   #16
siliconfanatic
rep to you, rep to logger, have a little cherry bomb rep!
__________________
Blackalize it!
Old 18th Jan 2013, 08:29   #17
flix
Minimodder
flix's Avatar
Thx to all
@ siliconfanatic: just the fins in the middle are for air intake
I have no idea what you two are talking about, I'm no native speaker as you can see on my posts But it sounds like you like it
Here the Update:
Actually I wanted to be done by now but filling and grinding is such a time waster...
Nothing exciting to see, just some small blocks of plexiglass. They will hold the fins on the front.
First coat of primer, just to see where I need to fill again:
Yesterday I broke some parts...
So I needed to fix that. That was really discouraging, but now its done
Bended the mesh for the front:
The top cover is also cutted and glued::
Startet to paint:
Front is nearly done:
Old 18th Jan 2013, 08:54   #18
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!
Looks great.
__________________
Cosmos S Reaper
L.R.E.C.
Scorpio - under construction
Arya-under construction
Pranja is online now   Reply With Quote
Old 18th Jan 2013, 10:41   #19
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
Flat black always nice !
k.3nny is offline   Reply With Quote
Old 19th Jan 2013, 00:33   #20
flix
Minimodder
flix's Avatar
Thats it
Still some small things to do (for example lightning) but I'm satisfied.
Next week the voting starts, I will post the link here
Good night
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
