Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th Jan 2013, 09:11   #1
Baz
Post moar ponies.
bit-tech Staff
Baz's Avatar
Baz should be considered for presidentBaz should be considered for presidentBaz should be considered for presidentBaz should be considered for presidentBaz should be considered for presidentBaz should be considered for presidentBaz should be considered for presidentBaz should be considered for presidentBaz should be considered for presidentBaz should be considered for presidentBaz should be considered for president
Ozone Rage 7HX and Rage ST Reviews
http://www.bit-tech.net/hardware/per...e-st-reviews/1
Matt tries out a pair of headsets from Ozone.
Baz is offline   Reply With Quote
Old 10th Jan 2013, 09:19   #2
SinxarKnights
Multimodder
SinxarKnights has yet to learn the way of the Dremel
Perhaps I missed it, but how is the mic sound quality?
SinxarKnights is offline   Reply With Quote
Old 10th Jan 2013, 11:10   #3
Dogbert666
No, seriously, wtf is a dremel?
bit-tech Staff
Dogbert666's Avatar
Dogbert666 - it's over 9000!!!!!!!!1!1!1!!!Dogbert666 - it's over 9000!!!!!!!!1!1!1!!!Dogbert666 - it's over 9000!!!!!!!!1!1!1!!!Dogbert666 - it's over 9000!!!!!!!!1!1!1!!!Dogbert666 - it's over 9000!!!!!!!!1!1!1!!!Dogbert666 - it's over 9000!!!!!!!!1!1!1!!!Dogbert666 - it's over 9000!!!!!!!!1!1!1!!!Dogbert666 - it's over 9000!!!!!!!!1!1!1!!!Dogbert666 - it's over 9000!!!!!!!!1!1!1!!!Dogbert666 - it's over 9000!!!!!!!!1!1!1!!!Dogbert666 - it's over 9000!!!!!!!!1!1!1!!!
Mic sound quality in calls with friends was absolutely fine. Again it's not professional level audio but we didn't have any problems
Originally Posted by Article
We experienced no problems with voice clarity and the active noise isolation did a good job of eliminating loud background noise such as typing.
Hope that helps!
Dogbert666 is offline   Reply With Quote
Old 10th Jan 2013, 12:47   #4
TheDodoKiller
Getutech, Eh? What's that?
TheDodoKiller's Avatar
TheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on youTheDodoKiller - may the hammer of Bindi be bestowed on you
I will never buy an Ozone product again. I've owned 2 headsets from them previously, an Ozone spark, and a set of Ozone Strato evo's.
The first set, the spark's microphone broke after 6 months use- contacted ozone support, and not a dickie bird out of them.
The Strato evo's left channel broke after 6 months as well- again contacted ozone support, and heard nothing from them.
They both felt well built when I bought them, but they soon disintegrate.
My advice would be to avoid like the plague.
__________________
- AMD 1090T OC'd at 4.1 Ghz - Asus Crosshair IV Formula - Reference Asus 6950/70 - Silverstone FT02 B-W - Kingston HyperX 3K 128GB SSD - Samsung F3 1TB - Kingston HyperX 1600 Ram 4GB - Coolermaster V8 -
TheDodoKiller is offline   Reply With Quote
Old 10th Jan 2013, 15:02   #5
Baz
Post moar ponies.
bit-tech Staff
Baz's Avatar
We've not been too impressed in the past either; hopefully these new headsets can help them kick-on, as the Rage ST is really good for the price.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
