Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th Jan 2013, 10:59   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!
Microsoft unveils IllumiRoom gaming technology
The TV's no longer the limit for the game world.
http://www.bit-tech.net/news/gaming/...0/illumiroom/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter
bit-tech news correspondent, Custom PC columnist
I'm a filthy freelancer! Hire me!
Gareth Halfacree is online now   Reply With Quote
Old 10th Jan 2013, 11:02   #2
GeorgeStorm
Aggressive PC Builder
GeorgeStorm's Avatar
GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.
At times that looked incredible, at others more of a gimmick but still, might keep my eye on this.
__________________
"Anyone who just plays games for fun is a n3rd" - Jörge "I should be in prison for what I'm thinking right now" - Splooshiba
My flickr - My blog it'sfilmnotmovie
GeorgeStorm is offline   Reply With Quote
Old 10th Jan 2013, 11:06   #3
SchizoFrog
Ghost In The Machine
SchizoFrog's Avatar
SchizoFrog has yet to learn the way of the Dremel
How does it not project across the TV screen and therefore overlay it?
__________________
Motherboard - ASUS P5K Premium
CPU - Q6600 @ 3GHz - Arctic Freezer 13
GPU - Palit 9600GT @ Clock 750MHz - Mem 1100MHz - Shader 1850MHz
RAM - 6GB Corsair PC2-6400 DHX @ 960MHz
OS - Windows 7 Ultimate (64bit)
SchizoFrog is offline   Reply With Quote
Old 10th Jan 2013, 11:08   #4
Gareth Halfacree
WIIGII!
bit-tech Staff
I'll let the article answer that question:
Originally Posted by The Article
The scanning system also detects the size and position of the TV set, ensuring that the projector doesn't attempt to wash out its image with a picture of its own while creating a perfectly-centred illusion of immersion for the player.
__________________
Old 10th Jan 2013, 11:14   #5
Bloody_Pete
Technophile(and yes, thats 724Mb/s)
Bloody_Pete's Avatar
Bloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for president
I'd find it distracting personally...
__________________
i5 3570k @ 4.6GHz (1.28v) on custom water loop/ Watercooling how-to, Asus Maximus 5 Gene, 16GB Corsair Vengence 1600MHz (2 black, 2 red), Sapphire Radeon HD 5870, 128GB Crucial M4, 3 x Samsung F1 1TB in RAID 5, Xigmatek Elysium, Enermax Revolution 85+ 850W, Corsair K60, Corsair SP2500 speakers, Dell U2311H & Asus VK222W.
Bloody_Pete is offline   Reply With Quote
Old 10th Jan 2013, 11:15   #6
SchizoFrog
SchizoFrog's Avatar
Right... so I'll ask again. HOW does it not project across the screen? Does it produce white light across it rather than the images? Would that not affect the TV and produce a reflective white light on the TV?
__________________
Old 10th Jan 2013, 11:23   #7
Gareth Halfacree
WIIGII!
bit-tech Staff
It doesn't project anything across the TV - why would it? The projector will use DLP and simply turn a rectangle the size and shape of the TV black.
__________________
Old 10th Jan 2013, 11:29   #8
mi1ez
Hypermodder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
I like the idea of this, but the amount of extra GPU grunt it must take would surely make it impractical? Certainly for an XBOX.
Would love to give it a try though!
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 10th Jan 2013, 11:42   #9
blacko
Multimodder
blacko has yet to learn the way of the Dremel
well its running on a 360...so....yeah extra gpu may not be needed.
blacko is offline   Reply With Quote
Old 10th Jan 2013, 11:48   #10
Gareth Halfacree
WIIGII!
bit-tech Staff
Perhaps for an Xbox, but an Xbox 720? One thing that jumps out of the video is that the IllumiRoom image is quite clearly of a lower quality compared to the main picture. As well as running at a lower resolution - as far as you can tell from the video, anyway - the textures are significantly simpler. In some examples - the outline environment, the effects-only section, the snowdrop and star segments - there are no textures at all.
That's likely how the trick is done: after all, if the IllumiRoom could produce an image as good as that of the TV, you wouldn't need the TV at all...
__________________
Old 10th Jan 2013, 12:18   #11
steveo_mcg
STILL ALIVE
steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.
Its only filling your peripheral vision, it doesn't need to be hi res or very detailed just enough to blend from the display. It looks very cool but I expect MS will come up with some way of making a mess of it prior to general release.
__________________
ook
steveo_mcg is offline   Reply With Quote
Old 10th Jan 2013, 12:22   #12
sniperdude
Supermodder
sniperdude's Avatar
sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.
looks awesome
__________________
2500k @4.1Ghz /BeQuiet Dark rock advanced / Gigabyte Z68 UD4 /8GB Corsair Vengeance /MSI twin frozr GTX 670 /Audigy 4 Platinum Pro /128GB+64GB Crucial M4's /Antec P182 /BeQuiet Dark Power Pro 650W.
sniperdude is online now   Reply With Quote
Old 10th Jan 2013, 12:29   #13
Guinevere
Mega mom
Guinevere's Avatar
Guinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpit
Wonderful idea because everyone has a hi-def projector aligned to project at the entire wall.
It's a tech demo, with the tech itself a very basic extension and twist on projection mapping tech we've all seen elsewhere, including Sony for their PS3 ads blended with a bit of Philips Ambilight
http://vimeo.com/34605168#
http://www.youtube.com/watch?v=MAZcDHIIXDs
This "unveiling" is not a real product and it will never be a real product. It's totally impractical as anything other than a "Aren't we clever" demo.
Guinevere is offline   Reply With Quote
Old 10th Jan 2013, 12:34   #14
Flibblebot
Gimp dog!
Flibblebot's Avatar
Flibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpit
If you've got a projector, why not just play games on that...?
__________________
My uber-system: 66Mhz 486DX2, 8Mb RAM, 20Mb hard drive, 256 colour VGA adaptor (goes all the way up to 800x600!), keyboard AND serial mouse
Flibblebot is online now   Reply With Quote
Old 10th Jan 2013, 12:38   #15
GeorgeStorm
Projectors aren't that great to play games on, need a darkish room etc for best performance.
I don't think they're claiming everyone is going to have it tomorrow? It's a potential product?
It's far better than Ambilight, and more realistic than the PS3 thing as far as I can see?
__________________
Old 10th Jan 2013, 12:40   #16
Gareth Halfacree
WIIGII!
bit-tech Staff
Yes, because it would be impossible for Microsoft to strap a Kinect sensor - £82 - to a short-throw pico-projector - £75 - and sell it as a £160 add-on product. What madness would that be?!
__________________
Old 10th Jan 2013, 13:32   #17
theshadow2001
Ultramodder
theshadow2001's Avatar
theshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for president
I think the effects coming off the screen look cool. But when it simply extends the screen it looks a bit meh.
theshadow2001 is online now   Reply With Quote
Old 10th Jan 2013, 13:34   #18
schmidtbag
Supermodder
schmidtbag has yet to learn the way of the Dremelschmidtbag has yet to learn the way of the Dremel
I wouldn't consider this technology to be anywhere near as gimmicky as touchscreens, on the other hand, I'd rather use the object recognition feature for a projector being the main display rather than have a TV along with a projector. That way people can could make a spherical room or something and have their game surround them. It would also allow things like movies to work, not just games. I think this has an awesome potential but I don't see anyone buying a projector (which tends to be more expensive than kinect) JUST so they can see fire and snow flakes out of their peripheral vision.
schmidtbag is offline   Reply With Quote
Old 10th Jan 2013, 13:48   #19
Blackshark
Multimodder
Blackshark has yet to learn the way of the Dremel
Gosh have projectors really come down that much in price? What an old fart I am, remembering buying a projector that did 1024 XGA for 1200 GBP 6 or 7 years ago.
I agree with the thinking that some of the effects were great. I especially liked when the flame and laser shots went outside the TV. That was clever. The picture above sucks as did some of the effects. And I am not sure quite how much the marketing department have messed with that end video, I suspect quite a bit. You would also need a pretty 'dark' room - the only way projectors can cope with lighter rooms nowadays are the tech built in to the pull down blinds. Normal home walls and furniture will be a whole mixture of colours, shades, materials, textures ..... A bit like the Philips ambilight TV tech. Its ok, good in a few cases, not great in most.
Blackshark is offline   Reply With Quote
Old 10th Jan 2013, 14:13   #20
blacko
Multimodder
i remember seeing this a while back and i thought it was going to be some sort of VR / knightmare.
how wrong was i!
Reply
Tags
console gaming, gaming, illumiroom, kinect, microsoft, microsoft research, projector, xbox, xbox 720
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
