Old 12th Jan 2013, 07:03   #1
thechoozen
Hypermodder
thechoozen's Avatar
thechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysis
Stark PC 7 HX
Hy @ all
this is our entry for the Lian Li PC 7H Contest, i know itīs already close to the deadline...but lets see what we can do with it in the hurry of time.(2 weeks)
First the unboxing & disassembling....
after that we started to make the first prototype of the sidepanels...
then we started to work on both sidepanels....
and the 2nd sidepanel....
after cutting out the first parts out of the sidepanel....we made the next prototypes ....this time.... a few Fan/Radiator Grills....
as next, we made a grill for the 2nd sidepanel...(maybe we will make the final version a bit smaller than the prototype)
then we made a few parts for the front...just to figure out in which combination we?re going to use them later...
after that we started to print out the first part which will be used on the front of the case....
beside that we made a few smaller preparations ...like cutting out a few mesh stripes and things like that...
(the mesh will be used behind the stark industries logos....)
(both stripes will be sanded, so that we get rid of those anodizing...)
thechoozen is offline   Reply With Quote
Old 12th Jan 2013, 08:51   #2
ASPHIAX
Beyond Complexity Lies Simplicity
ASPHIAX's Avatar
ASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the Dremel
NICE !!!!
Good luck on the compo!
__________________
Current Build : BORG COSMOS II
Current build : 2001 - A Case Modyssey
Finished build : IMPERIAL AT-AT
Finished Build : USS EURISKO - Intrepid Mark II Class
www.asphiax.wordpress.com
ASPHIAX is offline   Reply With Quote
Old 12th Jan 2013, 08:57   #3
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Looks like a great start love he theme too mate!
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 12th Jan 2013, 09:37   #4
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!
Seems as good start of an epic build.
__________________
Cosmos S Reaper
L.R.E.C.
Scorpio - under construction
Arya-under construction
Pranja is offline   Reply With Quote
Old 12th Jan 2013, 10:23   #5
330td
Multimodder
330td's Avatar
330td has yet to learn the way of the Dremel
It's gonna be a great project
330td is offline   Reply With Quote
Old 13th Jan 2013, 16:58   #6
thechoozen
Hypermodder
thechoozen's Avatar
thanks a lot m8īs!!!
in the last days we continued the work on the case....first we started to sand down the anodizing of the mesh pieces....
then we added a first layer of paint on the printed frame for the front....
then we put it in itīs place, so that we could take a few measurements for the next parts...
after getting all the informations we needed, we could print out those "A" Shaped pieces and make a first prototype of a frame for the front....
and last but not least we started to cut out the first frames and grills out of metal...
Old 16th Jan 2013, 05:07   #7
thechoozen
Hypermodder
thechoozen's Avatar
time for the next update:
in the last days we continued to prepare all parts which are needed to continue the work on the outside of the case....
Old 16th Jan 2013, 06:48   #8
dreps
Multimodder
dreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremel
looking good mate
dreps is offline   Reply With Quote
Old 16th Jan 2013, 19:33   #9
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
I like that you have 3d printing now, but it seems odd to print a 2.5d part with it. Kinda like buying a Ferrari and driving 30.
Cheapskate is offline   Reply With Quote
Old 17th Jan 2013, 05:47   #10
thechoozen
Hypermodder
thechoozen's Avatar
hehehe , yeah youīre totally right....buuuut we have it only for a few weeks now (i think 2 or 3) and we are still experimenting with the right settings etc. so weīre just happy that we got it working that far....everything else (like full 3d printing) comes later when we know better what we do
and now, itīs time for the next update:
yesterday we couldnīt make that much progress as we wanted...so we have a tough programm scheduled for today....but i think we will finish it on time...:up:
we already prepared the next metal / plastic pieces which are needed to finish the outside...beside that we already started to prepare the hardware to be moved in...
Old 17th Jan 2013, 07:32   #11
Editor22
E22.BIZ
Editor22's Avatar
oo an Eisberg... those things are so damn sexy! looks like that's just the cooler though? great use of the printer mate
__________________
Store: E22
Old 17th Jan 2013, 23:45   #12
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Awesomeness in a 2 week mad dash modathon.
Waynio is offline   Reply With Quote
Old 18th Jan 2013, 03:29   #13
thechoozen
Hypermodder
thechoozen's Avatar
thx m8īs!!
@Editor22....yes itīs only the cooler/pump/res...but weīre hoping that it will perform well with a good 2x120mm radiator in the loop....
yesterday we prepared all the plexiglas pieces which we need to assemble everything on the case ....
we also made the last cuts into the 2nd sidepanel....
Old 18th Jan 2013, 07:18   #14
Editor22
E22.BIZ
Editor22's Avatar
Thats looking brilliant mate. Love the front so far
__________________
Store: E22
Old 19th Jan 2013, 05:22   #15
thechoozen
Hypermodder
thechoozen's Avatar
thx m8!!
time for the last update: (during the contest...i think we will work on a few details later...),,,
Old 19th Jan 2013, 13:12   #16
jrs77
theorycrafting
jrs77's Avatar
jrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for president
There he strikes again. Another quality-mod from thechoosen
Could you tell us more about the CM Eisberg? How does it perform?
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB]
jrs77 is offline   Reply With Quote
Old 26th Jan 2013, 04:03   #17
thechoozen
Hypermodder
thechoozen's Avatar
thx m8!
Sure, up to now...we could say that the CM Eisberg is working really good for a cooling solution like this....we couldnīt make any stress tests up to this point but it idles around 30 ° with a 2x120mm Rad attached.
We run it with the resistor cable attached so that the pump is running really silent....a little bit louder than a Laing Pump but really not much.
I think we will run a few benchmarks in the next days...then i can tell you more about the performance of the Eisberg....
Finally the Voting for the Lian Li Contest has gone Live...and here is a link to it...
Old 26th Jan 2013, 07:02   #18
siliconfanatic
Car lover and Speed Junkie
siliconfanatic's Avatar
siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.
0_0 finally a build name stark themed after its name! confusing relief..
Fast log, but good god the best looking yet!
__________________
Originally Posted by quizz_kid View Post
Blackalize it!
I *am* the guy who loves too many threads to bump them all.
siliconfanatic is offline   Reply With Quote
Old 26th Jan 2013, 07:26   #19
atc95
Need help with scratchbuild!
atc95's Avatar
atc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpit
Looks amazing and great theme idea.
I never knew the cm eisberg came as just a res/pump block, may have to use one in future projects.
__________________
i5 3550 // gigabyte g1 sniper m3 // xfx 7950 dd @ 1ghz // 2x4gb C. Vengeance // samsung 256gb 830 // 750gb scorpio black // silverstone tj08be // enermax ets t40 tb // ocz modXstream pro 700w // Dell u2412m // IBM 17" tft.
Xbox PC mod (nearly finished): a10 5800k @ 4.6ghz, h100i, msi fm2 a75ia, 8gb samsung greens, 256gb sandisk ultra!
atc95 is offline   Reply With Quote
Reply
Tags
babetech.de, bt-custompc.de, casemod, lian li, stark pc 7 hx
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
