Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 12th Jan 2013, 22:27   #1
modd1uk
Corsair Fan
modd1uk's Avatar
modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!
LED Light bulb advice
Anybody have any recommendations/warnings ? After kitting out the house with LED bulbs and just wanted to know what to get/what to avoid, just the standard bayonet fitting.
__________________
Corsair 800D :: ASUS P8P67-EVO :: i5 2500K :: 8GB Corsair Vengeance :: MSI Twin FrozrII GTX 570 :: Corsair HX520 :: Corsair H100 :: Samsung 830 256gb :: Samsung F3 :: Samsung F4
Originally Posted by loftie View Post
^+1
Energy saving light bulb agrees with the incandescent bulb.
modd1uk is offline   Reply With Quote
Old 13th Jan 2013, 10:57   #2
ch424
Design Warrior
ch424's Avatar
ch424 is a hoopy frood who really knows where their towel is.ch424 is a hoopy frood who really knows where their towel is.ch424 is a hoopy frood who really knows where their towel is.ch424 is a hoopy frood who really knows where their towel is.ch424 is a hoopy frood who really knows where their towel is.ch424 is a hoopy frood who really knows where their towel is.ch424 is a hoopy frood who really knows where their towel is.ch424 is a hoopy frood who really knows where their towel is.ch424 is a hoopy frood who really knows where their towel is.ch424 is a hoopy frood who really knows where their towel is.ch424 is a hoopy frood who really knows where their towel is.
The Ikea ones are really cheap and the couple of reviews I've seen say they're good? No idea about lifespan though.
ch424 is offline   Reply With Quote
Old 13th Jan 2013, 11:26   #3
TaRkA DaHl
Ultramodder
TaRkA DaHl's Avatar
TaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpit
Only thing I can advise of is that you need to make sure you don't get ones that are too powerful, I got ones that were 50w equivalent (GU10's) for the spot lights in my kitchen and they are seriously bright, should have got 30w equivalent ones.
Also, watch what colour they give off, there are options for brilliant white to off white ones, my misses was a bit fussy with the colour the first ones I got gave off (too white lol)
TaRkA DaHl is offline   Reply With Quote
Old 13th Jan 2013, 11:33   #4
jizwizard
stop your grinning and drop your li
jizwizard's Avatar
jizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpit
right this is where i should excel as its what i do for a living.
makes to go for in order of preference
bell http://www.belllighting.co.uk/
philips http://www.philips.co.uk/c/-/19964/cat/
osram http://www.osram.com/osram_com/trend...jsp?mkturl=led
these are my top three. if you want them on a dimmer then there is not alot that would beat a bell lamp and they work great on a 400w dimmer switch.
to avoid
kosnic- we keep these in stock but they are being sent back to the manufacturor as we have had loads come back faulty after about 1 month
anything cheap and chinese on ebay.
what you want is an led that can put out 4w thats a 35w equiv or a 5w thats equiv to 50w
for home use i would suggest a warm white colour which is 3500k or normally stated as an 835
anything higher and it will make it look cold and industrial looking.
if you spot anything give us a shout and ill try and help you out as much as possible or i could sell you some lol
__________________
Bitfenix Prodigy / Asus p8z77-I deluxe / 2700k@5.2 / Samsung 2x4gb @ 2400mhz /
Hx1050 (overkill) / Gtx570 (soon to be 690) / 2x64gb M4 / WD 3tb book / BenQ 2410t
G19 / G27 / and some watercooling for good measure
jizwizard is offline   Reply With Quote
Old 13th Jan 2013, 11:38   #5
Nexxo
There is no rep for awesomeness.
Moderator
Nexxo's Avatar
Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.
And keep in mind that they still get fairly warm.
Jizwizard: question. I have 50W 12V halogen downlighters in my kitchen, each hooked to their own in-line 12V transformer. I assume that I can use the same transformer for 12V 4-5W LED downlighters?
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust
"Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust
Nexxo is offline   Reply With Quote
Old 13th Jan 2013, 12:21   #6
jizwizard
jizwizard's Avatar
how many are you running in total. obviously there a g5.3 cap on the lamp
__________________
Old 13th Jan 2013, 12:22   #7
jizwizard
jizwizard's Avatar
and there called lamps not bulbs lol. bulbs are what you put in the ground
__________________
Old 13th Jan 2013, 19:13   #8
modd1uk
Corsair Fan
modd1uk's Avatar
Jizwizard - Firstly that name made me lOL. And you seem like you know what you're talking about, il get a list together and be in touch .
__________________
^+1
Old 14th Jan 2013, 01:33   #9
kingred
Surfacing sucks!
kingred's Avatar
kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!
Having had the main manufacturers one on test, I prefer the OSRAM ones out of aesthetics, performance and efficiency. Suggesting anything more may void an nda of mine.
kingred is offline   Reply With Quote
Old 14th Jan 2013, 07:43   #10
Cabe6403
Supreme Commander
Cabe6403's Avatar
Cabe6403 should be considered for presidentCabe6403 should be considered for presidentCabe6403 should be considered for presidentCabe6403 should be considered for presidentCabe6403 should be considered for presidentCabe6403 should be considered for presidentCabe6403 should be considered for presidentCabe6403 should be considered for presidentCabe6403 should be considered for presidentCabe6403 should be considered for presidentCabe6403 should be considered for president
This. I bought an LED bulb for my room. I wanted the 50W equivalent one but they didn't have any left so I just bought the 30W equivalent and it's more than bright enough. The 50W one would have been far too bright.
__________________
Retina MacBook Pro || 2.3Ghz i7 || 16Gb RAM || 256Gb SSD || 22" Dell Monitor || Logitech MX Revolution || Creative T20's
I never seen nothin' like you before
I can kick you higher than you can kick me
I can kick you way up into a tree
Cabe6403 is offline   Reply With Quote
Old 14th Jan 2013, 08:10   #11
jizwizard
jizwizard's Avatar
Nothing is set in stone at the minute as to what manufacturers can stipulate there led lamp is the equivalent to so there is a lot bullshit flying around. Some say there 5w is an equivalent to a 50w, some say there 6w is the equivalent. Alot of manufacturers are overpowering there leds which obviously decreases the life of the lamp
__________________
Old 14th Jan 2013, 08:37   #12
kingred
Surfacing sucks!
kingred's Avatar
Cheaper manufacturers will be overvolting the LEDS anyway.
As to equivalents, you should be concentrating on lumen output, and colour temperature instead of equivalent wattage otherwise you will fall for the same bag of tricks they used with CCFL's.
Now they are a blight...
Old 14th Jan 2013, 08:41   #13
jizwizard
jizwizard's Avatar
True true. Work for osram by any chance?
__________________
Old 14th Jan 2013, 08:51   #14
sniperdude
Supermodder
sniperdude's Avatar
sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.sniperdude is the Cheesecake. Relix smiles down upon them.
ahh these things again LOL notice my tone.....that's because I live in the dark these days
Why? you might ask
Simples, because I have energy saver bulbs in every room LOL.
The brightest one I have found to date is this and its the only one that's actually white light and not yellow ( ment to be as good as 60W)
http://www.wilkinsonplus.com/light-b...T=bulb%20light
please if you know any better let me know
__________________
2500k @4.1Ghz /BeQuiet Dark rock advanced / Gigabyte Z68 UD4 /8GB Corsair Vengeance /MSI twin frozr GTX 670 /Audigy 4 Platinum Pro /128GB+64GB Crucial M4's /Antec P182 /BeQuiet Dark Power Pro 650W.
sniperdude is online now   Reply With Quote
Old 14th Jan 2013, 09:05   #15
Flibblebot
Gimp dog!
Flibblebot's Avatar
Flibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpit
I picked up an Osram cfl warm white bulb for 60p in my local bargain store (Home Bargains). It"s a 100W equivalent bulb (actually 35W I think), and is the best CFL bulb I've used so far. Bright enough from startup, warm colour - it's made me rethink ecobulbs.
I"d be interested to see how the LCD replacement spots work - I've got 10x 50W GU10s in my kitchen that burn electricity. £10 a bulb is a little rich for me at the moment though!
__________________
My uber-system: 66Mhz 486DX2, 8Mb RAM, 20Mb hard drive, 256 colour VGA adaptor (goes all the way up to 800x600!), keyboard AND serial mouse
Flibblebot is online now   Reply With Quote
Old 14th Jan 2013, 09:12   #16
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.
to avoid
This is all the advice you'll need, and is pretty much ecactly the same thing that I would have said. +rep for some great advicve Jizwizard
I'm doing this in our kitchen in the next couple of months, as well as converting the garage from a double 8' fluorescent fitting to 4x 6' single fittings for better light coverage. I'm going to be using OSRAM warm white LED lamps in the kitchen to replace 12 halogen fittings and hopefully reduce the amount of power that they use
Unicorn is offline   Reply With Quote
Old 14th Jan 2013, 09:24   #17
steveo_mcg
STILL ALIVE
steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.
How much cooling do these need? Are they ok in normal fittings? I've got some mains voltage halogens I've been considering replacing.
__________________
ook
steveo_mcg is offline   Reply With Quote
Old 14th Jan 2013, 09:33   #18
TheStockBroker
King Battletoad
TheStockBroker is a hoopy frood who really knows where their towel is.TheStockBroker is a hoopy frood who really knows where their towel is.TheStockBroker is a hoopy frood who really knows where their towel is.TheStockBroker is a hoopy frood who really knows where their towel is.TheStockBroker is a hoopy frood who really knows where their towel is.TheStockBroker is a hoopy frood who really knows where their towel is.TheStockBroker is a hoopy frood who really knows where their towel is.TheStockBroker is a hoopy frood who really knows where their towel is.TheStockBroker is a hoopy frood who really knows where their towel is.TheStockBroker is a hoopy frood who really knows where their towel is.TheStockBroker is a hoopy frood who really knows where their towel is.
I'm down for 36 LIFX smartbulbs (Kickstarter - multiple pledges) - These will be the beginning of my smart-home revolution when I buy my first house in the next few months! I can't wait!
Why? you might ask
Don't confuse energy saving with LED... They're worlds apart!
__________________
Fractal Define XL / Asus Maximus V Gene Z / 3570k i5 @ 4.8Ghz / Corsair H80 / 8GB Corsair Vengeance 1600Mhz DDR3 / EVGA GTX 680 FTW 4GB / Asus Xonar DX / 512GB OCZ Vertex 4 / Seasonic X-650 / Dell U2711
TheStockBroker is offline   Reply With Quote
Old 14th Jan 2013, 09:47   #19
Flibblebot
Gimp dog!
Flibblebot's Avatar
Your in-ceiling halogens should have some heat shields and fire protection - I can't see led bulbs giving off more heat than a mains voltage halogen' so you should be okay.
__________________
Old 14th Jan 2013, 09:50   #20
jizwizard
jizwizard's Avatar
Unicorn may I suggest some t5 lamps for that extra saving! There equiv to t8 is 28w-36w 35w-58w
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
