Reply
Thread Tools View Mode
Old 13th Jan 2013, 01:25   #1
Andreas | Brodholm
Multimodder
Andreas | Brodholm's Avatar
Andreas | Brodholm is a hoopy frood who really knows where their towel is.Andreas | Brodholm is a hoopy frood who really knows where their towel is.Andreas | Brodholm is a hoopy frood who really knows where their towel is.Andreas | Brodholm is a hoopy frood who really knows where their towel is.Andreas | Brodholm is a hoopy frood who really knows where their towel is.Andreas | Brodholm is a hoopy frood who really knows where their towel is.Andreas | Brodholm is a hoopy frood who really knows where their towel is.Andreas | Brodholm is a hoopy frood who really knows where their towel is.Andreas | Brodholm is a hoopy frood who really knows where their towel is.Andreas | Brodholm is a hoopy frood who really knows where their towel is.Andreas | Brodholm is a hoopy frood who really knows where their towel is.
Model 01 | by Brodholm
Welcome!
I thought I would share a project I have been working on for a few years!
I hope you will enjoy the log!
New to the log?
You can easily get up to speed by checking THIS gallery!
The gallery above is a compact version of the Full album with only some milestone pictures.
Tip! Click a picture and you will get a zoomed view in the same window.
Be sure to check out the thread after you are done and comment on what you think!
You can also use the "View Author's Posts" function built into the forum.
Andreas | Brodholm is offline   Reply With Quote
Old 13th Jan 2013, 11:28   #2
Andreas | Brodholm
Multimodder
Sponsors
Old 13th Jan 2013, 11:32   #3
Andreas | Brodholm
Multimodder
Introduction
Hello everyone, I have always been thinking about creating an account here at Bit-Tech but I never got to it. I have been browsing around here many times but never made an account. I have been over at XS for a long time and some of you might have seen me there. But now it is finally time to join you over here!
And I thought, what better way then to do a build log here! Hope I am welcome here and that you will enjoy the log!
History behind the design:
About 5 years ago I decided that I was going to water cool my computer. Back then I had a Antec P180, not exactly the perfect chassis for water cooling your components. I looked at a lot of different chassis but I was never really happy with any of them. So I started sketching on my own design. First they were really awful, but as time progressed I got better and better at drawing. Early drawings was in MS-paint. I then moved on to Google Sketchup and finally Autodesk Inventor. I have probably gone through about 30 different designs until I finally decided on this one. This will be my first custom designed chassis and it will also be my first ever water cooled system!
Goal:
To design a chassis specifically for water cooling that is able to handle high-end components and still be quiet. And at the same time have a clean and stylish look that does not get old after a few months.
Progress
#1: Planning and Designing.
#2: Constructing Parts.
#3: Assembly of Chassis.
#4: Completing Chassis. <--- I am here right now!
#5: Water Cooling.
#6: Components.
#7: Modifying
#8: Installing and Testing.
#9: Finishing Touches.
#10: Final Pictures and Summary.
Specifications
Old 13th Jan 2013, 11:33   #4
Andreas | Brodholm
Multimodder
Gallery link! I can recommend watching the pictures on Imgur if you want bigger pictures. You can click a picture for zoomed version without opening a new window. Otherwise you can just watch them normally here on Bit-tech!
Youtube clip of the laser cutter!
Old 13th Jan 2013, 11:35   #5
Andreas | Brodholm
Multimodder
Old 13th Jan 2013, 14:06   #6
Andreas | Brodholm
Multimodder
Old 13th Jan 2013, 14:08   #7
Andreas | Brodholm
Multimodder
Old 13th Jan 2013, 16:02   #8
Andreas | Brodholm
Multimodder
Old 13th Jan 2013, 16:16   #9
Zsolt Guriga
Multimodder
Zsolt Guriga's Avatar
Zsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run Crysis
man this is perfect,and the rendering....i ve got no words to say
Zsolt Guriga is offline   Reply With Quote
Old 13th Jan 2013, 16:26   #10
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
I'm interested! loving the work so far
__________________
Project log Mocha70
Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2
Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
Burnout21 is offline   Reply With Quote
Old 13th Jan 2013, 16:34   #11
siliconfanatic
Rep whore/ Car lover/ Speed Junkie
siliconfanatic's Avatar
siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.
Nice work! Just be a little less... detached and professional, and you might get more comments
i personally hate it when it seems more like a journal than a log.
__________________
Hard to explain to someone who has no clue. Or doesn't believe you. It's a daily struggle being in pain or feeling sick on the inside while you look fine on the outside. Please put this as your signature for at least 1 hour if you or someone you know has an invisible illness (Pancreatitis, Crohn's, PTSD, Anxiety, Bipolar, Depression, Diabetes, LUPUS, Fibromyalgia, MS,Lupus, ME, Arthritis, Cancer, Heart Disease, Epilepsy, Autism, etc.) " Never judge what you don't understand.
siliconfanatic is offline   Reply With Quote
Old 13th Jan 2013, 16:44   #12
Rodrigo Vicentini
Multimodder
Rodrigo Vicentini's Avatar
Rodrigo Vicentini has yet to learn the way of the Dremel
wow Nice word =D professional tools rules =D
Rodrigo Vicentini is offline   Reply With Quote
Old 13th Jan 2013, 17:47   #13
Andreas | Brodholm
Multimodder
Thanks! Its really nice to have a good set of machines. Some of them are more or less only good for really big stuff.
Thanks for the feedback! I really appreciate it! I know what you mean, Its a bit cold and detached right now. I will try and work on that! Maybe I should just use normal text instead? That makes it much less "professional" at least
Right now there are catching up posts. But after the next post It will be "live" or what I should say. Usually I am in the workshop all day and when I get home I edit the pictures and present them this way.
Old 13th Jan 2013, 18:22   #14
Axoxenon
Do it right the first time
Axoxenon has yet to learn the way of the Dremel
Subscribed! Its always fun with some heavy machines ^^
Axoxenon is offline   Reply With Quote
Old 13th Jan 2013, 18:32   #15
GotMod?
Minimodder
GotMod?'s Avatar
GotMod? has yet to learn the way of the DremelGotMod? has yet to learn the way of the DremelGotMod? has yet to learn the way of the Dremel
Hi Andreas! Glad to see your project here!
Keep up the amazing work!
Definately subd! )
__________________
'Monochrome' Lian Li V600FB - Finished
GotMod? is offline   Reply With Quote
Old 13th Jan 2013, 18:45   #16
Andreas | Brodholm
Multimodder
It's now "live"
Next step is to sand everything down with 240grit paper and then glassblast everything. It will be interesting to see if I can manage to get an even surface
Old 13th Jan 2013, 19:29   #17
vils
Multimodder
vils's Avatar
vils has yet to learn the way of the Dremel
Very nice build. A bit jelous on your tech resources, I've built all my comps in the kitchen with hand tools...
__________________
Current project: Facit
Visit my sponsors:
Intel Microsoft Noctua
vils is offline   Reply With Quote
Old 13th Jan 2013, 19:33   #18
Si_the-dude
Multimodder
Si_the-dude's Avatar
Si_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on youSi_the-dude - may the hammer of Bindi be bestowed on you
Speechless. It's everything I've been looking for in a case. I'm really jealous of the tools and toys you have available Subscribed!
__________________
i7 4770k - Corsair H110 - Gigabyte G1 Sniper M5 - Gigabyte GTX 780 SLI - Corsair Vengeance 16gb - Corsair 350D - Seasonic P1000w - OCZ Vertex 4
Si_the-dude is offline   Reply With Quote
Old 13th Jan 2013, 20:56   #19
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for president
Damm. That CNC really kick a**. Nice work!.
__________________
_Cosmos S Reaper_ _L.R.E.C._ _Scorpio_
_Arya_-under construction _ROG Crawler_
Pranja is online now   Reply With Quote
Old 14th Jan 2013, 13:43   #20
Julien Pod
What's a Dremel?
Julien Pod has yet to learn the way of the Dremel
Very promising !!!
Julien Pod is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
