#21 |
Multimodder
Very nice!
__________________
Inverted 600T - OCN Mod of the month July 2012 CM Test Bench V2 - Cooler master mod competition 3rd prize Rig of The month December - Guru3D Nice articles of the test bench: Here and here |
#22 |
theorycrafting
Full metal-shop pr0n
![]() I'm planning to build a case myself currently, but I have to go without the set of tools you're equipped with
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB] |
#23 |
Modder
Thanks for the nice comments! Really inspiring!
I will try to post a update as soon as possible!!! |
#24 | |
Modder
Update #8 All parts
#25 |
Do it right the first time
It looks very nice indeed!
Did you laser cut and bended the I/O bracket aswell? Sure could use one later on ^^ |
#26 | |
Modder
#27 |
theorycrafting
Seeing how nice the I/O came out, what would you charge for a µATX I/O ? As this is actually the part I'm not able to make myself this accurately.
__________________
#28 |
Multimodder
![]() ![]() ![]() ![]() :jawd rop:![]() ![]() Just amazing men i love good solid looking hard metal work.
#29 | |
!Well planned, well performed and well doned. Im asking the same as jrs77, any possible way of getting one?
#30 |
Do you even mod, bro?
Amazing work. Even with the access you have to all the machinery, your talent shines through!
Subscribed!
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG |
#31 |
Modder
Thanks for the comments!
The I/O shield is really tricky to produce since I have to do them manually, and since I do not work at the workshop and I study at another town I think it will be hard. Also its kinda expensive to laser cut things. Then you would have to make a lot of them, and I still think they would be kinda expensive then The workshop is really nice. There is a few things that i miss though. Like a water jet/laser cutter a CNC miller and a press break suited for these kind of things. Then you could actually produce this design relative "cheap". But as it is right now, I have to order stuff from other companies and its very pricey!!! I have no idea how I am supposed to afford to fill this chassis up with components
#32 |
I've got wood
This is gorgeous, I love the case hinge by the way!
#33 |
theorycrafting
I see. Thanks for consideration anyways
__________________
#34 |
Modder
#35 |
Car lover and Speed Junkie
Wicked. And as for the Marking amuminum, thats why brushed metal is so awesome
![]() and good god make me an i/o bracket... stock stinks like alu turd! Course we're here so ccomplaint is invalid
#36 | |
I belive theres still possible to get the motherboard tray from Lian Li. Pretty cheap but not as fancy as yours ![]() And for your CNC milling concerns, just holler and i might be able to help you out |
#37 | |
theorycrafting
Ordering from UK or US would be possible, but you don't really wan't to pay the shipping.
__________________
#38 | |
I dont know where you are located but Im pretty sure I saw it availible at a swedish website.
Can check when Im back home. Sorry for OT. Quote:
#39 |
Is the daddy!
really nice results!
__________________
Project log Mocha70 Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2 Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
#40 | ||||
Modder
![]() Yeah, brushing is nice, although glass-blasting looks better in my opinion! It gives such a nice finish! Quote:
![]() Quote:
If anyone have questions you can always ask them! I will not mind at all, and I will try to answer if i can Thanks! |
| Thread Tools | |
| View Mode | |
