Old 13th Jan 2013, 16:39   #1
oma95to
What's a Dremel?
oma95to has yet to learn the way of the Dremel
FreshOut
Hi everyone!
I'm new here, i'll post my mod FreshOut with i go to the Lucca Modding Contest.
Now the work log
My intention was to create from new a 2 floor pc, like the antec one. So I started with the base from some plates and started it.
As you could see, some pieces (like the mobo support) are taked by some old pc
To cover the front of the case i used some plexyglass
The days goes on, and the works too.
For the support of the Motherboard i used some PVC
After i made the support for the 20cm fan over the Motherboard
The reuse the plexyglass for the front panel between the floor and the Motherboard
After some days packages arrived.
The list that what i bought:
Aquatuning 1
-Sharkoon kaltlicht kathoden twin blau x 2
-vandalismuaster 19mm aluminium schwarz 1 blu e 1 rosso
-phobya interruttore led blu x5
-gelid wing 9 uv blue
-gelid 2ing 12 pl blue
-cooler master megaflow 200 blue led
Aquatuning 2
-24 pin uv blue
-4 pin molex femmina e maschio uv blu
-6+2 pin PCI-E uv blu x2
-8 pin uv blu
-4 pin uv blu
-4 pin molex 90° uv blu x2
-Fan Power Connector 4pin PWM maschio e femmina x5
Drako
-Corsair rubber grommets
-Lamptron button/swicht connection cable x3
Nils
-Pin-Remover by MOLEX - The Original
-Pin-Remover 4-Pin - Save My Wallet
-Sleeve SMALL - WHITE x4
-Sleeve SMALL - B-MAGIC x1
-Sleeve SATA - B-MAGIC x1
-Heatshrink SMALL - BLACK x5
-Heatshrink SATA - BLACK x1
-Cable-Management-Clip SMALL - BLACK
-Cable-Management-Clip MEDIUM - BLACK
-Cable-Management-Clip BIG - BLACK
-Cable-Management-Clip JUMBO - BLACK
-SATA Power-Connector THROUGH
-SATA Power-Connector END
-MDPC Crimping-Tool
After the sleeving begins
After weeks, the works went on.
After too many weeks the works went on.
For the base "feet" i used some rubber
After i paint the components, with blue, white and grey
And the up continued to arrive
After i make some basilar circuit for the fan and neon
And his cover
The last sleeve
The mounting
Finally here is the finish work
Here we are
Thank for watching
I hope to return again soon
Bye Omar
oma95to is offline   Reply With Quote
Old 14th Jan 2013, 15:57   #2
AciD_RaiN
Multimodder
AciD_RaiN's Avatar
AciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run CrysisAciD_RaiN can run Crysis
Not bad I've been to Lucca Italy (if that's the Lucca you are talking about) and it's without a doubt the most beautiful place I've ever been too Good luck mate
AciD_RaiN is offline   Reply With Quote
Old 14th Jan 2013, 19:23   #3
oma95to
What's a Dremel?
Thank you man it's a beatiful historical city
good luck you too
Old 14th Jan 2013, 20:27   #4
oma95to
What's a Dremel?
good luck you too
Old 14th Jan 2013, 22:11   #5
Razarach
Multimodder
Razarach's Avatar
Razarach has yet to learn the way of the DremelRazarach has yet to learn the way of the DremelRazarach has yet to learn the way of the Dremel
Nice build. Great job.
Razarach is offline   Reply With Quote
Old 14th Jan 2013, 22:20   #6
oma95to
What's a Dremel?
Thank you so much
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
