#21 |
Do it right the first time
Wow! Very nice welds and such a nice, clean and perfectly awesome welding table!
And the case looks great too by the way
#22 |
Multimodder
Heavy metal !!!!
#23 | |||||
Supermodder
Thanks Ace_finland and the workshop aint mine.
![]() Quote:
![]() Quote:
![]() Quote:
Thanks a lot Cheapskate and now im wondering what crazy designs you have in mind. ![]() Quote:
Now im gonna show you my secret weapon.![]() Try to beat that if you can. ![]() Quote:
![]() Thanks dream1.
__________________
Completed Projects Project Desk Art - Project Flipmode - Project The Next Level In progress Project P42 |
#24 |
Keep calm & mod on. =)
You make perfection look so easy
looks awesome. ![]() ![]() Excellent to see you making something new already.
#25 |
Supermodder
Thanks Waynio and yes i cant sit still.
__________________
#26 |
Supermodder
Update 1. 19 Jan 2013
Today i made a little progress again.I started working on the backside of the case. First i cutt a plate and made the little pieces i need to get the right angles.The i spotwelded the pieces together. ![]() ![]() ![]() Finished welding and some sanding. ![]() ![]() This is done so far the holes for the i/o shield and psu comming later.Then it was time to make the bottom cover. First i cutt a plate and bend it. ![]() ![]() After that i made a mount bracket. ![]() The holes are for M5 weld nuts. ![]() Then i weld the weld nuts. ( sounds funny )![]() ![]() ![]() ![]() Then i welded the mount bracket inside the bottom cover. ![]() This is how it looks so far. ![]() This was it for today. ![]() Thanks to my sponsors. ![]()
__________________
#27 |
llama eats dremel
Impressive work!
forgive me the ignorance, but could you elaborate in what weld nuts differ from normal nuts...?
__________________
my English may not be as good as I think it is... |
#29 |
I've got wood
That work table is cooler than a penguins' chilly bits. Love it!
#30 |
↓ Don't trust that face!
It usually involves a toilet seat and superglue.
__________________
#31 | |||
Supermodder
![]() Quote:
Hahaha
__________________
#32 |
Supermodder
Update 2 - 26 Jan 2013.
Today i made the handle bars and the top cover.This time its more pictures and less talking so enjoy the pictures i would say. First i made the handle bars.For this i used 2mm stainless.First i cutt al the pieces i need and then welded en finished them. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The handle bars are ready so its time to make the top cover.For this i used 1.5mm steel.First i cutt al the pieces i need and then bend,weld and finshed them. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Then i mounted the handle bars to the cover. ![]() ![]() ![]() Test fitting. ![]() ![]() ![]() ![]() This was it for today. ![]() Thanks to my sponsors. ![]()
__________________
#33 |
Multimodder
Awesome stuff Paslis!
#34 |
Multimodder
I like it!
You got real nice metal working skills.. |
#36 |
Those would look so cool as a vent cover...
__________________
#37 |
It looks great! How big is it?
#38 |
Supermodder
Thanks tp148.
![]() Thanks a lot mister. ![]() Haha thanks a lot mate. ![]() I have to agree on that one cheaps. ![]() Thanks and the dimensions are 500x340x350.
__________________
#40 |
Professional Sleever & Modder
Totaly amazing work Pascal!
Your metal skills are the best i have ever seen and still keep us more and more stunned by your incredeble work! Fantastic ! |
| Thread Tools | |
| View Mode | |
