Reply
Thread Tools View Mode
Old 21st Feb 2013, 17:31   #61
NoobNeb
Herp a derp
NoobNeb's Avatar
NoobNeb has yet to learn the way of the Dremel
I think every word of praise possible has already been used but damn this really is good work now just let us see that case again
__________________
bedibop
NoobNeb is offline   Reply With Quote
Old 22nd Feb 2013, 08:16   #62
Korvus
May contain traces of sanity.
Korvus's Avatar
Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!
Originally Posted by Paslis View Post
[snip]
[snip]
Very nice! very professional looking
__________________
Current Rig: Intel 3570K | Asus Z77 Sabertooth | 8GB Corsair Vengeance 1600 RAM | Crucial M4 120GB SSD | 2TB Seagate Barracuda 7200 | EVGA GTX680 SC Signature Editon | Asus Xonar D2X | Corsair HX850W | Fractal Design Define XL R2 (Black)
Cooled by: Aquaero 5 Pro | Alphacool NexXxos XP3 | Alphacool Monsta 240 | Laing D5
Current build
Korvus is offline   Reply With Quote
Old 22nd Feb 2013, 12:32   #63
Paslis
Supermodder
Paslis's Avatar
Paslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run Crysis
Thanks a lot NoobNeb and this weekend an update of the case again.
Thanks Korvus.
__________________
Completed Projects
Project Desk Art - Project Flipmode - Project The Next Level
In progress
Project P42
Paslis is offline   Reply With Quote
Old 22nd Feb 2013, 12:34   #64
Waynio
Tetrep
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
They turned out very nice Paslis.
Hmmm can't help but look at my own & think how could they look better.
Waynio is offline   Reply With Quote
Old 22nd Feb 2013, 19:00   #65
craig - toyoracer
Supermodder
craig - toyoracer's Avatar
craig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremelcraig - toyoracer has yet to learn the way of the Dremel
Another great mod.
__________________
octTower
craig - toyoracer is offline   Reply With Quote
Old 22nd Feb 2013, 19:32   #66
matiss
Multimodder
matiss's Avatar
matiss has yet to learn the way of the Dremel
Very nice work on those cards. Do you have temps from before and after the mod?
__________________
live on air fridays 20-22 @ radio.XES Gothic, Darkwave, Electro, Metal, Rock & Death
matiss is offline   Reply With Quote
Old 23rd Feb 2013, 07:04   #67
Paslis
Supermodder
Paslis's Avatar
Thanks Waynio and go for it mate now im curious what you gonna make of them.
Originally Posted by craig - toyoracer View Post
Another great mod.
Thanks craig.
Thanks matiss and no i dont have temps from before and after because i used the same dimensions as the stock coolers so i guess temps will be the same.
__________________
Completed Projects
In progress
Project P42
Old 23rd Feb 2013, 13:21   #68
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Very nice mate!
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 24th Feb 2013, 12:52   #69
Paslis
Supermodder
Paslis's Avatar
Thanks a lot mate.
__________________
Completed Projects
In progress
Project P42
Old 24th Feb 2013, 13:05   #70
Paslis
Supermodder
Paslis's Avatar
Update 5.
Did some work again and this time i worked on the frame of the case.Because some people are asking me how big the case is i made a few pictures of the dimensions of the case.
Length 510 mm.
Width 390 mm.
Height 440 mm.
Time to do some work.First i made the cover that will be mounted to the front.The top and sidepanels will be mounted to the cover.
First i cutt a plate and bend,drilled,sanded and mounted it to the front.
Then it was time to work on the frame.This time i lett the pictures do the talking.
Some sanding.
Testfit for the looks.
This was it for today.More to come.
Thanks to my sponsors.
__________________
Completed Projects
In progress
Project P42
Old 24th Feb 2013, 17:06   #71
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
So, "some progress" means half the case gets built? You are holding back so the Pope doesn't lose too badly, aren't you?
Cheapskate is offline   Reply With Quote
Old 25th Feb 2013, 11:53   #72
Paslis
Supermodder
Paslis's Avatar
Hahaha well it really was some progress. Im not holding back and i think when Pope does an update his project is almost finished by then.
__________________
Completed Projects
In progress
Project P42
Old 25th Feb 2013, 12:02   #73
Waynio
Tetrep
Waynio's Avatar
Probably true I'm expecting a big sweep of updates at any time so no holding back.
Both doing awesome modding/creating, fun stuff this race, cool idea.
Oh & latest update.
Old 25th Feb 2013, 13:02   #74
p0Pe
gief cake?
p0Pe's Avatar
p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!
Just found my charger! So
__________________
p0Pe is offline   Reply With Quote
Old 25th Feb 2013, 18:19   #75
Cheapskate
Cheapskate's Avatar
Pregourd planet?
Old 25th Feb 2013, 18:23   #76
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!
Prepare Space?
__________________
Cosmos S Reaper
L.R.E.C.
Scorpio - under construction
Arya-under construction
Pranja is offline   Reply With Quote
Old 25th Feb 2013, 18:42   #77
Waynio
Tetrep
Waynio's Avatar
Prepare saturn??? hmmmm.
Prepare rings, preparing my space lol.
Preparing my update for the planet.
Last edited by Waynio; 25th Feb 2013 at 18:42. Reason: Preparing my update for the planet. :)
Old 25th Feb 2013, 18:44   #78
JoshH
Minimodder
JoshH has yet to learn the way of the Dremel
Prepare your ring..umm!
Anyway, looks super cool man! Love it!
JoshH is offline   Reply With Quote
Old 26th Feb 2013, 13:09   #79
Paslis
Supermodder
Paslis's Avatar
Oh & latest update.
Thanks a lot Waynio and yeah its fun doing a race.
Originally Posted by Cheapskate View Post
Pregourd planet?
Originally Posted by Pranja View Post
Prepare Space?
Prepare Uranus.........hmmm..............
Thanks a lot JoshH.
__________________
Completed Projects
In progress
Project P42
Old 28th Feb 2013, 17:55   #80
Cheapskate
Cheapskate's Avatar
Apparently you might need some bulletproof underpants...
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
