Reply
Thread Tools View Mode
Old 10th Feb 2013, 13:29   #41
BCMods
Minimodder
BCMods has yet to learn the way of the Dremel
Nice one mate
BCMods is offline   Reply With Quote
Old 10th Feb 2013, 17:25   #42
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
Thnks
k.3nny is offline   Reply With Quote
Old 13th Feb 2013, 22:09   #43
k.3nny
Hypermodder
k.3nny's Avatar
GPU update!
XFX4870 - HD5870 Voltage Tweak
Needed to redo the pci plate, need a little more sanding, but ok for the test
Up and running
I love how easy the GPU drain works, just open it and the juices flow ! almost the entire loop in 30 seconds empty <3
See u on the next hardware update !
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
