#1 |
WIIGII!
bit-tech Staff
VIA announces APC Rock, Paper
APC 8750 replacements boast more power.
http://www.bit-tech.net/news/hardwar...c-rock-paper/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter bit-tech news correspondent, Custom PC columnist I'm a filthy freelancer! Hire me! |
#2 |
Multimodder
Any deatails on the APC Scissors?
__________________
DFI LT-X48-T2R, Intel Q6700k @ 4.2GHz, Arctic Cooler 7, OCZ 4GB (2x2GB) PC2-8000C5 1000MHz ReaperX HPC, 500G SAMSUNG SATA2 HD501LJ, CORSAIR HX 520W MODULAR PSU, XFX HD7850 2GB Black Edition |
#3 |
Biding my time...
...APC Lizard...APC Spock?
#4 |
Minimodder
Or you could just buy a Raspberry pi.
#5 |
WIIGII!
bit-tech Staff
Trouble with the Raspberry Pi is it's ARMv6 - which the APC 8750 was, too. The APC Rock, APC Paper (and the wonderful open-source Olimex A13-OLinuXino) are Cortex-class ARMv7 devices - which makes them significantly more powerful than the Pi. It also means they can run software the Pi cannot: there's still no workable build of Android for the Pi, nor can it run any version of Ubuntu newer than 9.04 - both software packages that work fine on Cortex-class processors.
Basically, if you don't care about performance or compatibility and you're on a budget, buy a Pi; otherwise, hold out for a Cortex-class chip.
__________________
#6 | |
Supermodder
#7 | |
Supermodder
#8 |
CPC_refugee
Delete
__________________
Don't do today what you can put off until tomorrow Battlefield 3 adidan_uk BF3 Stats i7 3770 3.4GHz // Asus P8Z77-M // Scythe Big Shuriken // Gainward 570 Phantom // 8Gb G.Skill Ripjaws 1600MHz // 250Gb Samsung 840 // 650W Be Quiet Dark Power Pro // Lian Li V351b Apache Filled // Samsung T220 22" // W7 64 |
| Tags |
| android 4.0, apc, apc 8750, apc paper, apc rock, arm, cortex-a9, microcomputer, raspberry pi, via apc, wm8750, wm8950, wondermedia |
| Thread Tools | |
