Reply
Thread Tools View Mode
Old 18th Jan 2013, 01:28   #1
HammerForged
Minimodder
HammerForged's Avatar
HammerForged has yet to learn the way of the Dremel
Case Labs ST10 Project "HardLine"
Welcome Everyone!
I am new here to Bit-Tech. I have been active on a couple other forums but never here so I thought I should share this new build with you all. Hopefully you will subscribe and follow along!
After much tinkering and playing around with my TJ07 learning the tricks of the trade I've decided to start a new build!
The main goal of this build is to move from my cramped TJ07 to the larger Case Labs ST10 and refine my modding skills along the way. I currently plan for the build to have a black, red, and polished nickel theme. I look forward to everyones comments and suggestion to help make this build awesome!
Sponsors:
Components:
  • Case Labs ST10 LINK
  • Intel i7-3770K
  • Asus Maximus V Formula
  • EVGA GTX 680 4GB
  • 16GB Corsiar Dominator Platnium 1866mhz
  • Samsung 840 Pro 256GB Raid 0
  • WD Black 1TB
  • Seasonic 1K Platinum
  • Asus VG278HE
Water Cooling:
  • Black IceŽ GTX Gen Two Xtreme 480 (x2)
  • Koolance CPU-370
  • Aquacomputer AquagraFX GTX 680 - Nickel Plated
  • Laing D5 Pumps (x2)
  • Koolance PMP-450/S Rev.2.0 (x2)
  • Corsair SP120's (lots)
  • Corsair AF120's (x5)
  • Lamptron FC8
  • Koolance NZL-CU10 (just google it )
Update Log:
Most Recent Photo:
So heres the start of the mod:
With the ST10 it allows for multiple 480mm radiator placements. Either one up top, front, or the bottom. For the setup I'm going for there will be a 480mm on the top and bottom which will require the PSU to be relocated. Here is how that will happen:
PSU Mounting Bracket
PSU Blanking Plate for the stock location.
Finished setup of how the PSU will be installed
HammerForged is offline   Reply With Quote
Old 18th Jan 2013, 03:58   #2
p0Pe
gief cake?
p0Pe's Avatar
p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!
Always nice to see a caselabs mod But please read the rules
__________________
p0Pe is offline   Reply With Quote
Old 18th Jan 2013, 04:11   #3
HammerForged
Minimodder
Whoops! Sorry about that. I will post more here in just a little bit!
Edit: Updated the first post. Sorry for being such a idiot guys. New to bit-tech. Hopefully the pics seem to be sized okay. If not please let me know. Thanks!
Old 18th Jan 2013, 05:28   #4
p0Pe
gief cake?
p0Pe's Avatar
No problem and welcome The rules are just in place to ensure that we have some progress to watch, and not just text
Plans, actual progres or maybe some renders will make a good start
__________________
Old 18th Jan 2013, 07:24   #5
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
oo another Case Labs mod... cant wait
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 19th Jan 2013, 20:14   #6
HammerForged
Minimodder
More updates today!
Started off by installing the PSU blanking plate. I plan on buying a larger PSU cord and running it from the front mounted PSU behind the back panel and out this hole.
And then there are the Corsair AF120 fans. Talk about blowing some money
These mount in the Flex Bay 120mm fan mounts. These flex bays really make it easy to change components in and out. There is any number of combinations that could be used here. The flex bays can be loaded up with hard drives or another 480mm radiator. The options that they offer are definitely impressive.
Flex Bays Removed:
Fan mounting in the Flex Bays:
Flex Bays installed:
Not sure if anyone can help me out here but do you all have any suggestions for wiring up all the fans to one FC8? A bunch of Y's?
The 2 Black Ice 480 rads are on there way and I am going to mount those up with the Corsair SP120's.
If anyone has any comments or suggestions please feel free to let me know!
Old 19th Jan 2013, 20:36   #7
faugusztin
I *am* the guy with two left hands
faugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for president
Use Phobya 3-pin to 4x3-pin adapters ?http://www.aquatuning.co.uk/product_...----black.html
There is a 3x,6x and 9x fan adapter too.
__________________
Cerberus Core i7-2600K Asus P8Z77-I Deluxe GSkill RipjawsX 2x8GB DDR3-1600CL9 watercooled EVGA GTX670 Samsung 830 256GB Bitfenix Prodigy Seasonic X-460 Windows 8 Pro
Prometheus Xeon E3-1235 Asus P8B WS GSkill RipjawsX 2x4GB DDR3-1333CL7+2x8GB DDR3-1333CL9 Coolink Corator DS Force 3 240GB+4xWD30EFRX+2xWD20EARS+6xWD20EARX Nanoxia DS1 Seasonic X-460 Ubuntu 12.04
faugusztin is offline   Reply With Quote
Old 19th Jan 2013, 20:42   #8
HammerForged
Minimodder
Okay. Thank ya. Thats what I had originally planed on using but I just wanted to make sure that was the best way to go about it. I have seen where others have actually daisy-chained them together but the Corsair wiring doesn't allow for that with much ease.
Old 19th Jan 2013, 20:46   #9
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!
I would not recommend doing that-you might burn fan controller that way.
Two fans per channel is fine, but really wouldn't recommend more.
__________________
Cosmos S Reaper
L.R.E.C.
Scorpio - under construction
Arya-under construction
Pranja is offline   Reply With Quote
Old 19th Jan 2013, 20:58   #10
faugusztin
@Pranja: There is no way for him to burn out the fan controller that way. Reason ?
http://www.corsair.com/us/cpu-coolin...twin-pack.html
0.13 A per fan in case of the Performance Edition. That is 4x0.13x12=6,24W total for 4 fans.
http://www.lamptron.com/products/vie...Controller_FC8
Power Output:Up to 30 watts per channel
So the 4 fans will use 1/5th of the rated power consumption one fan controller channel.
__________________
Old 19th Jan 2013, 20:58   #11
HammerForged
Minimodder
I will be using the Lamptron FC8 and its rated for 30 watts per channel. So doing a little math using the .18 amps @12v the SP120's drawl I should be fine. Works out to be around 2.2 watts per fan. I have seen a burnt up Lamtpron FC and it was not a pretty sight. I think Im going to have around 21 fans so hopefully 3 per channel will be okay.
EDIT: Ha! Faugusztin we had the same idea!
Old 19th Jan 2013, 21:06   #12
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
B NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run Crysis
Not true,its a 30w per channel FC,capable of powering 8 fans if the wattage is right
I have 4 SP 120's per channel on a FC5
The start draw is around 3w for each of those fans,the quoted specs are running specs.
You need to bare that in mind when choosing a controller
B NEGATIVE is offline   Reply With Quote
Old 19th Jan 2013, 22:49   #13
Pranja
Fenrir The Wolf
Pranja's Avatar
Ok, then no problem.
I seen some burned conrollers-don't know specs of them,but not a pretty sight.
__________________
Cosmos S Reaper
L.R.E.C.
Old 20th Jan 2013, 07:13   #14
p0Pe
gief cake?
p0Pe's Avatar
If your fancontroller burns from handling 3 fans, then you have bought a shitty fancontroller
__________________
Old 20th Jan 2013, 09:16   #15
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
More often than not,its the crap wiring harness that will give out first....Yes Phobya,im looking at you...
Old 20th Jan 2013, 19:17   #16
HammerForged
Minimodder
Im glad you said something about this because I probably would of picked up the Phobya harness but I'll be checking out the Bit Fenix ones now. I guess the gauge of the wire was just too small to handle the current load.
Old 20th Jan 2013, 19:41   #17
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Exhibit A
This had 4 Corsair SP120's on it.
Blew the controller then caught fire.
Old 22nd Jan 2013, 23:43   #18
HammerForged
Minimodder
Just a little bit of an update today!
Got the Black IceŽ GTX Gen Two Xtreme 480mm radiators in. Snapped a few pictures for everyone to look at. I know the glossy finish doesn't really match the mate black of the case but I'm hoping it won't throw off the look too much
I went with a higher FPI radiator so I could actually take advantage of push pull. Won't be too much of an improvement but it made more sense than using a low FPI radiator in push pull so hopefully it was the right decision!
Old 29th Jan 2013, 19:22   #19
HammerForged
Minimodder
Just a little bit of an update, no pictures.
I picked up the 1/2" type M copper pipe last night. I was able to get it in straight lengths so no straightening for me! Originally I wanted run 3/8" but the local place only stocked 3/8" in coils.
I placed the order for the Koolance stuff as well. Originally submitted it through PPC but because of lack of stock they just sent the order directly to Koolance. Should work out fine.
Does anyone have any experience in bending nickel platted copper? I'm considering getting the pipe plated then bending it up. The shop I talked to said it would make plating much easier and that as long as I didn't go over 90 degree bends it should be fine but I am still hesitant. Thanks for the help!
Old 29th Jan 2013, 19:54   #20
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
I got away with doing it with chrome,you should be ok.
Ideally it would be plated afterwards.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
