#1 |
Administrator
bit-tech Staff
Asus ROG Vulcan Pro review
#2 |
I *am* a Dremel
In the future can you please include in a spec sheet of the headphone. I really want to see some specs on hz <> khz, db/m, drive size etc.
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. In 1982 I was addicted to Lady Bug and played it in the local arcade (every day) And yes i'm proud I did that! |
#3 |
Hypermodder
If i remember rightly, the Vulcan needed a battery for the ANC, does the pro need a battery too?
__________________
Sent from my PC using a keyboard |
#4 |
Multimodder
I have the original Vulcan following advice from Bit-Tech and I love it. It took me a while to get used to not being able to hear myself properly when talking on skype etc. after owning a Razer Carcharias, but the sound quality and comfort are awesome.
#5 | |
I *am* a Dremel
If these sort of things matter to you then you should probably just avoid these gamer headset things.
__________________
http://img195.imageshack.us/img195/1466/goldie.gif |
#6 |
Has an Avatar avatar
I bought the vulcans on recommendation from bit-tech and the mic quality is terrible. Anyone in voice chat lobbies with me can hear an echo, and no 'listen to this device' is not on.
Not really impressed.... Sound quality and ANC is pretty good, but I would've liked a better review on this considering my Steelseries 4H headset is just as good.
__________________
Compy Mark V Intel Core i5 2500K // ASUS P8P67 Pro // 8GB DDR3 Cosair XMS // ASUS GTX580 DirectCU II // Antec 750W // Antec 1200
#7 | |
Hypermodder
__________________
#8 |
The mic quality is fine, it just picks up on the voices of whomever is on voice chat with me, but not the ambient noise of the game we're playing (which is often the same volume). As I say, I don't get this issue with my cheap headset. I've also had soundcards in the past where the line in was so quiet I had to use the line in on my motherboard instead.
Drives everyone else mad, doesn't bother me a great deal (apart from their whining).
__________________
#9 |
Hypermodder
Mine only does it with one pair of headphones - note headphones not headset. That's why I suggested it might be the card. Hell I've even had my PC pick up from the air and transmit a foreign radio station down teamspeak which I couldn't hear. Had to do a mic test to actually hear it!
Yea my soundcard is weird....
__________________
#10 |
Diagnosis: ARMAII-Holic
I prefer the normal audio jack inputs like the original vulcan. USB variatns tend to break easier if you accidently stand on the cable or get up and move too far from your computer, whereas the jacks normally just pull out without damage. That aside seems like a re-release to bring the price back up again as the original has fallen somewhat. Get the original vulcan in my opinion as its exactly the same and the sound you get will still be the best in a gaming envrionment together with its comfort etc.
| Thread Tools | |
