Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 18th Jan 2013, 10:33   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!
Intel's Otellini talks profits, 14nm and Haswell
Earnings hit by slowing PC sales.
http://www.bit-tech.net/news/hardwar...ntel-q4-2012/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter
bit-tech news correspondent, Custom PC columnist
I'm a filthy freelancer! Hire me!
Gareth Halfacree is offline   Reply With Quote
Old 18th Jan 2013, 10:44   #2
Griffter
Supermodder
Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!
M....$
Griffter is offline   Reply With Quote
Old 18th Jan 2013, 12:12   #3
Alecto
Minimodder
Alecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the Dremel
"Zion" being Xeon for the uninformed ?
Alecto is offline   Reply With Quote
Old 18th Jan 2013, 12:15   #4
Gareth Halfacree
WIIGII!
bit-tech Staff
Hah! I'd blame my spellchecker, but that one's entirely my fault. Fixed, ta!
__________________
Old 18th Jan 2013, 14:41   #5
Zurechial
Elitist
Zurechial's Avatar
Zurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run Crysis
I'm pinning my next big upgrade on Haswell to replace my i7 920 and X58 so I really hope the desktop chips are A: worth the wait despite a lack of competition for Intel in the high-end and B: On-time and concurrent with mobile parts, rather than being delayed in favour of pushing new parts for the tablet/ultrabook fad.
I was sorely tempted by Ivy Bridge because of the power-hungry nature of my i7 920 and the lack of SATA3/USB3 on my early X58; but I just couldn't justify it with Haswell around the corner.
Intel better deliver on more than just battery life!
__________________
Main: CM Cosmos II <-> Core i7 920 @ 4GHz <-> EVGA GTX 580 <-> GA-EX58-UD5 <-> 6GB DDR3 <-> Samsung 840 Pro <-> Crucial M4 <-> Xonar D1 <-> Dell U2410 <-> HP ZR24w
Laptop: Core i7 2670QM<-> GTX 570M <-> 8GB DDR3 <-> Crucial M4 <-> XMG P511
Zurechial is offline   Reply With Quote
Old 18th Jan 2013, 16:27   #6
rollo
I Mod, Therefore I Own
rollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for president
Intels shares have took a battering since these results were posted down 6% and still going at last check.
They have made less money this quater than they did last year in the same quater. And with a slowing pc market i dout results will improve for next quater so i guess the shareholders are correct for once.
Also intrested in Haswell to replace an i7950 gaming build but will want to see some actual performance benifits in the games i play to really make me intrested in an upgrade.
rollo is offline   Reply With Quote
Old 18th Jan 2013, 18:43   #7
MrGumby
CPC 464 User
MrGumby's Avatar
MrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run Crysis
From everything i keep reading regarding Haswel, power consumption appears to be the headline. With very little mention of performance increases. I remember thinking the low tdp of the ivybridge quads would make for some awesome overclocks, but heat density and heatspreader issues put paid to that.
Still be interesting to see how haswel turns out.
MrGumby is offline   Reply With Quote
Old 19th Jan 2013, 08:35   #8
fluxtatic
Supermodder
fluxtatic has yet to learn the way of the Dremel
From what I've read so far, I doubt you'll see much difference in performance. You'll see it in power consumption, mostly. Will it be worth a $500 platform (motherboard and processor alone, naturally) upgrade? Depends on how much you care about power consumption, I suppose. The 950 is a 130W processor at just over 3GHz. It's not terribly unrealistic to think a comparable Haswell will be slightly faster, with a TDP around half that of the Nehalems. SB quads were 95W at 32nm, IB is 77W at 22nm, so I could see Haswell quads around 65W, easily.
In practical applications, I don't recall any SB or IB processors being much more than incremental upgrades over the previous generations of the Core i series. Native USB3 will there (as it should have been in IB, imo) and IB already has PCIe 3.0, iirc. Unless you have or want a quad-SLI system, though, even PCI 2.0 isn't nearly maxed out.
Assuming Steamroller is AM3+, I'm sticking with AMD for a while longer. Next full build I do, though, I'll take a long, hard look at Intel for the first time ever.
fluxtatic is offline   Reply With Quote
Old 19th Jan 2013, 11:23   #9
Jimbob
Minimodder
Jimbob has yet to learn the way of the Dremel
[quote=Zurechial]I was sorely tempted by Ivy Bridge because of the power-hungry nature of my i7 920 and the lack of SATA3/USB3 on my early X58; QUOTE]
I was in the same boat but caved in and upgraded the other week. The 920 served me well running at 3.9GHz for years but the lack of S-ATA 3 was a pain and the lure of the 3770K was too much. Compared to the 920 the 3770k is amazing, overclocks higher, runs much cooler nice little upgrade but I certainly see you're point I'm sure when Haswell turns up I'll have wished I waited!
Jimbob is offline   Reply With Quote
Old 20th Jan 2013, 14:02   #10
djzic
Bokehlicious!
djzic's Avatar
djzic has yet to learn the way of the Dremeldjzic has yet to learn the way of the Dremeldjzic has yet to learn the way of the Dremel
I'm hanging on to a Q8300 waiting for Haswell, I realize the performance might not be that much greater but I would like to build a passive build if possible so TDP is important. If there is not a significant difference in TDP or performance I'll simply get IB for cheap while stock's cleared out
__________________
Check out my build: the Shuttle.
Q8300. 8gb XMS2. ATI 4650.
Thermalright AXP-140. Samsung SpinPoint 1TB.
1U 300w PSU. Shuttle Case. MDPC-X Sleeving.
djzic is offline   Reply With Quote
Old 21st Jan 2013, 07:31   #11
Xir
Xir's Avatar
Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!
Very profitable plus stock buyback and still the stockprice is so low...
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus something 1920x1080
Xir is offline   Reply With Quote
Old 21st Jan 2013, 09:08   #12
runadumb
Supermodder
runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.
I'm also in the same boat, although I got into the 920 a bit late (was waiting on SB then gave up after the millionth delay) so I have SATA3.
I'm still not sure if its needed. The only thing that I feel really pushes my processor and makes me feel its too slow are emulators but the lower power consumption is very tempting.
runadumb is offline   Reply With Quote
Reply
Tags
14nm, atom, cpu, financial, haswell, intel, paul otellini, processors, system on chip soc, tri-gate
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
