#1 |
bit-tech sponsor
Project: FrozenCPU: Billet Pron Bench; Updated Today!
Our retailer, FrozenCPU has been retailing Mnpctech products for one year now. We're both celebrating 12 years of business! I was honored when Frozen approached us about creating a custom "FrozenCPU" theme PC Thank you guys for the comments and staying tuned! The kind folks at Corsair were generous to send us their new Force GS SSD 240 GB and two 16 GB packs of Dominator DDR3 to utilize in our build. Awesome! Thank you Corsair!!!!! FrozenCPU wanted their PC to be jaw dropping, unique and utilitarian. highlights from the build videos that will be on Mnpctech's YouTube Channel Another wicked custom PC build by Mnpctech.com! Here the Mnpctech products that will be featured in the build! ![]() Mnpctech Machined Aluminum "Grooved" Case Feet here, http://www.frozencpu...d_-_Silver.html ![]() Mnpctech Machined Aluminum "480" radiator with rotating grill inserts here, http://www.frozencpu...m_-_Silver.html Time to feed da Milll! The side walls will draw in plenty of cool air. The two walls are milled from .5" thick 6061 billet. The back plates are machined from 1/8" thick. The two 480 radiators will reside behind these. The "BIG F" will be mounted on the side walls. The chassis width is just under 23" The lower front bezel, for optical drive bay, power switch, power and HD activity LEDS. Update: 1/22/13 Tech Station floor was milled from 1/4" sheet of 6061 SSD cage mounting holes Chassis back plates with jaw line ![]() The grills were inspired by Mnpctech's machined aluminum "480" radiator grill with rotating grill inserts here, http://www.frozencpu...m_-_Silver.html 480 radiator grill machined from 3/16" sheet, inspired by Mnpctech Machined Aluminum radiator grill with rotating grill inserts, sold by frozencpu here, The sidewalls are .5" thick and will have Round Modders Mesh will be attached to the inside of the walls. ![]() We'll go over all of the bare surfaces of the aluminum parts to remove small scratches with 3M Red Scotchbrite Pads ![]() The Tech station will host two 480 radiators in the rear cavity. We revised Mnpctech 480 machined aluminum radiator grill design slightly for the build. We're utilizing two Aquacomputer Aqualis 450ml Reservoirs from Frozencpu. (approx. 80 x 80 x 170 mm) These measure 70mm in diameter and made from Borosilicate glass, so they're scratch resistant! There is no color absorption in this glass, so dye colors look more vibrant. 70mm Borosilicate glass tube. Aquacomputer's form-fitting D5 pump adapter, #34044 Mounting solution for the two Aqualis reservoirs, all aluminum design devised by Cheaps. The ribs will be held in place with machined rods, which is next stage! Update 2/5/13 The cover will be opened with a Linear actuator arm. It's powered by electric motor with gear drive inside that extends single arm back and forth. We debated about using two Linear actuators, one on each side, but decided to try one arm first and install 2nd, if needed later. Mounting hardware included with Firgelli actuator. We will be making our own mounting brackets. Order page for Firgelli L16-P Use the L16-P as linear servo by purchasing an LAC board. Pricing: $80 per unit for switches or feedback. $10 per unit discount when you buy 10. Save $20 when you purchase with an LAC board. The L16 is a scaled up version of the L12 with a larger motor for faster speeds and heavier loads. Standard options include: three stroke lengths and three force/speed combinations(gear ratios). Each actuator has 2 internal limit switches to shut off the power once the end of stroke is reached. These switches cannot be moved. All our actuators come with a hardware kit for mounting. Update 2/7 machined rods were finished yesterday... the rods will join the 30x ribs that make the top cover these spacers will go between each of the 30 ribs in the cover... Updated 2/13 Finished the individual parts for the Motherboard I/O. Mounting posts and swing arm, which will hold down the I/O brackets on the GPUs. .... Actuator arm arrived this week, I'll try and get those pics taken and posted soon! Update 2/14/13 The actuator arrived. I'll be installing it this weekend. Here is all of the details and links to Firgelli. Firgelli L16 Actuator Data Sheet Firgelli L16 Actuator. Standard options include: three stroke lengths and three force/speed combinations (gear ratios). Each actuator has an internal linear potentiometer that provides position feedback. We have 3 more parts to make, actuator extension arm and two cover ribs for the ends. So while I wait for those, I worked on the boring, but necessary stage of the build, cleaning up all of the milled pieces. I dismantled the chassis so I could clean and remove minor scratches or the manufacturer ink stamp on the surface of the aluminum. I'm using 3M red Scotchbrite pads to remove any small scratches or marring to the surface of the aluminum. This is "very Fine" version and it's also a great alternative to sandpaper for prepping PC cases for painting. You can also use these 3M Scotchbrite pads for deburring Steel, Acrylic or Plastic. ![]() I've been editing videos mostly this week, I took a mental break yesterday to install our machined alum case feet onto the Tech Station. ![]() Frozen retails Mnpctech's Aluminum "Grooved" Case Feet here, http://www.frozencpu...d_-_Silver.html Update 3/1/13, Billet Motherboard tray We're looking into adding a gas charged spring to the other side, just as added precautionary measure, in case the actuator ever failed. Several people expressed interest in making ATX version of the CNC Machined Aluminum Motherboard Tray. I'm looking into contracting another shop to make these, so I don't have a cost confirmed yet, but here is what the proposed kit would look like and include, One Mainboard Tray with four large opening for PSU cables and connections. One Rear I/O Shield Plate with & PCI slots. Two triangular Motherboard brackets that connect Mainboard Tray to I/O Shield. Two reinforcement brackest for triangular motherboard brackets. Nine Motherboard Stand-off risers. Finish is brushed bare Aluminum. Includes 6/32 tapered flat head stainless machine screws. ![]() ![]() ![]() ![]() ![]() More updates soon Last edited by mnpctech; 4th May 2013 at 13:00. |
#2 |
Do you even mod, bro?
Lovely stuff! I'm so jealous of your tools!
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG |
#3 |
Fenrir The Wolf
Bill,Bill,Bill...
Bill for president. ![]() Allready looks awesome.
__________________
Cosmos S Reaper L.R.E.C. Scorpio Arya-under construction ROG Crawler-under construction |
#4 |
Multimodder
It looks great!
#5 |
dat steak
Awesome stuff Bill
#6 |
Do it right the first time
I'm loving it!
#7 |
Keep calm & mod on. =)
#8 |
Is the daddy!
awesome!
__________________
Project log Mocha70 Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2 Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
#9 |
Hypermodder
Awesome. You're bringing this next weekend, right?
__________________
Mosquito Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC |
#10 |
*learning english*
awesome!!! milling machine is my sweetest dream
__________________
10 re-plan "SuperBestBuild Of My Dream" 20 have a sleep 30 goto 10 |
#11 |
↓ Don't trust that face!
![]() OK, Waynio, you got me.
__________________
#13 |
What's a Dremel?
Oh man Bill, that's lookin so good... Now every retailer is going to want their own
#14 |
theorycrafting
Allways getting a little sad to see those workshops with CNCs and all that stuff. I could really need those tools, as I'm not able to build any of my ideas without them and that's where I could buy 1.5mm aluminum sheets for €15 per m²
![]() Nevertheless, another great case by Bill
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB] |
#15 |
@Jrs77 - Apparently, you need a drinking buddy who's also a machinist.
Since I don't drink, I had to buy my own machine.
__________________
#16 |
theorycrafting
Yeah, can't really afford a 3-axis CNC for machining sheetmetal
__________________
#17 |
Fenrir The Wolf
Don't buy-make one (good old engineering saying).
You can easily go with 1500 $ cost for that machine. Or even less.
__________________
#18 |
Master Modder
Sharp design Bill. I look forward to seeing this come together.
__________________
JAllen Labs GT1000- 3770K, 32GB Dominators, MSI 570GTX, Samsung 840 Pro 256GB SSD, 4 drive RAID 0 and 3TB storage in a Silverstone Fortress GT03, Logitech G9X Gaming mouse on Razer eXact Mat, Custom built Fostex studio monitors, Yamaha amp, Onkyo Tuner and Garrad turn table. |
#19 |
bit-tech sponsor
as soon as I get chance, I'll edit more pics...
@Parge, Good to hear from you! Thanks for the comment ![]() @Pranja, I don't think anyone wants that position, but thank you for tuning in. @Hukkel, Thank you for posting your comment, more to come! @Mankz, Thanks buddy, should be pretty sweet when it's finished. @Axoxenon, Great, cheaps and I have been wanting to build one for over a year now.... @Waynio, I thought same thing...LOL ![]() @Burnout21, good to hear from you again, stay tuned for more billet pron to come @Mosquito, maybe just the frame, and the midwest mod event is starting to shape up, lutr0 customs just confirmed hes attending, to do sleeving demo, anyone else from Midwest here @Vetalar, indeed, just dont ever forget to feed it everyday! ![]() @p0Pe, thank you! we love your killer projects! @Andrew_K, if they dont mind waiting...lol ![]() @jrs77, thank you for the post! and look at cnc routers, much cheaper for getting started @maestro0428, Thank you, cheaps and I seem to connect well on these collaborations, this our 3rd to make it from drawing to reality. and great hearing from you!
__________________
Shop Our Case Mod Store We Ship International Orders! Client Builds / FIREFLY PC / DISTRICT-9 PC / Official STAR TREK PC / WOLFENSTEIN PC / LANBOY APOCALYPSE PC / CodeMasters DiRT Showdown PC |
#20 |
There is a rumor going around that someone ran out of 1/8" sheet and has started making parts in 1/4".
She's going to be a TANK.Which reminds me...My tentative name for this project was, "The Bulldozer."
__________________
| Tags |
| evga titan sli, evga x79, tech bench, tech station, test station |
| Thread Tools | |
| View Mode | |
