Old 20th Jan 2013, 10:39   #1
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
B NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run Crysis
RSurvivo2
Hey Guys,I have a new build log to share!
I have always had a soft spot for Group B rally cars,The 'Killer' B's were the most awesome bits of kits ever to grace motorsport,but due to some accidents they were disbanded
Group B was a set of regulations introduced in 1982 for competition vehicles in sportscar racing and rallying regulated by the FIA. The Group B regulations fostered some of the quickest, most powerful and sophisticated rally cars ever built and is commonly referred to as the golden era of rallying. However, a series of major accidents, some of them fatal, were blamed on their outright speed and lack of crowd control. After the death of Henri Toivonen and his co-driver Sergio Cresto in the 1986 Tour de Corse, the FIA disestablished the class, which was replaced as the top-line formula by Group A. The short-lived Group B era has acquired legendary status among rally fans.
Group B had few restrictions on technology, design and the number of cars required for homologation to compete—200, less than other series. Weight was kept as low as possible, high-tech materials were permitted, and there were no restrictions on boost, resulting in the power output of the winning cars increasing from 250 hp in 1981,the year before Group B rules were introduced, to there being at least two cars producing in excess of 500 by 1986, the final year of Group B. In just 5 years, the power output of rally cars had more than doubled!
This is a bit of a tribute for the (in my eyes) finest of all these 4x4 rocketships....The RS200!!
And in its road going form...
And a little demo of how good this cars really is!
http://www.youtube.com/watch?v=hP-peuYguL8
The basis for this build is the White Survivor kindly sent to me from Bitfenix with the loop provided by Aquatuning.
This case suits my theme brilliantly with its white curves and solid construction.
Lets have a look inside?
200mm exhaust fan
First thing to do is remove all the bays,I will be fitting all the FC and whatnot internally so i can get clean lines on the outside.
A simple way of getting rid of rivets without drilling is to use a chisel and hammer..
Put the flat edge on the surface that the rivet is one and give it a wallop,the rivet will be cut like butter!.
Very easy to do,very good for tight access areas!
The loop will comprise of Alphacool kit,CPU block,GPU block and rads.
The CPU block
The GPU block
And the Backplate
None of my builds would be complete without Magoo adding his creative input which in this instance requires walkies..
Thanks to
for letting me have some fun with this build.
and
For providing the cooling.
B NEGATIVE is online now   Reply With Quote
Old 20th Jan 2013, 10:51   #2
elAwesome
Multimodder
elAwesome's Avatar
elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.
Oh yes
Those Group B were awesome, accelerating better off road than a Bugatti Veyrom onroad
Let's see what you make out of this case, I'll be following!
elAwesome is offline   Reply With Quote
Old 20th Jan 2013, 11:14   #3
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Sounds like an awesome project and theme man.
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 20th Jan 2013, 11:17   #4
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Originally Posted by elAwesome View Post
Oh yes
Its going to look good!
First thing is to flip the mobo tray to the right way up,R-ATX is truly cheesecake.
Old 20th Jan 2013, 11:25   #5
Editor22
E22.BIZ
Editor22's Avatar
DAMN RIGHT!
__________________
Store: E22
Old 20th Jan 2013, 11:30   #6
The_Crapman
MD of Mutant Zombie Armies Inc
The_Crapman's Avatar
The_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpit
Saaaweeeeeet!. Group b is very sadly missed and the RS200 is probably my favourite, but it's a close call between that and the quattro. Ken Block's Fiesta in Gymkhana 3 was very reminiscent of a group b car. Small, lightweight, 650bhp and a noise to tingle your dangly bits. Va-rooom!
Anyhoo, can't wait to see where this goes. Mod on!
__________________
Project: RAt MoD:CPU:i5 3570K, Motherboard:ASUS Maximus 5 Gene, GPU:Gainward GTX 670 Phantom, Cooler:Modded Antec Kuhler 620, RAM:4GB 1600MHz G.Skill RipjawsX CL6, HDD: WD Raptor 150GB , PSU: Enermax Revolution 1050W Case: Antec P182, How to Get a FREE (sort of) Hard Drive and Other Small Parts.
The_Crapman is online now   Reply With Quote
Old 20th Jan 2013, 11:36   #7
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
You have talking to Coolmiester havent you? We have argued about this since forever,he is a diehard Quattro fan.
I love the killer B's,they should re-introduce this class now safety is improved.
Dat Quattro whistle on gear change from the wastegate is audio pron.
Anyone have a cheap case that they want to do in the Quattro or Lancia style for a Group B faceoff?
Old 20th Jan 2013, 15:44   #8
The_Crapman
Even Pikes Peaks has been safetyerised, with the whole run being tarmac now. Sad times :-(
__________________
Old 20th Jan 2013, 16:18   #9
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
Oh hello.
Here, have my subscribe.
Mankz is offline   Reply With Quote
Old 20th Jan 2013, 19:43   #10
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
I know,very sad times...
Pikes is still the last bastion of power crazy rallying tho.
http://www.youtube.com/watch?v=rTe3Zxvz0Io
950bhp RS200....
Originally Posted by Mankz View Post
Oh hello.
Why thank you,there will be cake at the end.
Old 20th Jan 2013, 23:39   #11
Hanoken
Modder
Hanoken has yet to learn the way of the Dremel
well this is a pleasant surprise... man my respect for you just increased even though I'm one of the younger gen peeps, I adore the group b rally races XD, now days I just watch the pike peaks since the wrc doesn't hold much excitement (same with f1 after senna died) all I can say is good luck, sub'd, and kudos to you
__________________
Current Rig: i7 920 oc @ 3.5 GHZ, Evga X58 SLI FTW3, 24 Gb G Skill Sniper Ram @ 1600 Mhz
Evga 670 GTX FTW SLI
Need to build something new soon... I'm thirsting for a new build
Hanoken is offline   Reply With Quote
Old 21st Jan 2013, 09:35   #12
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Thanks for you kind comments,stick around...the DREMEL cometh!!
Old 21st Jan 2013, 10:16   #13
Mankz
dat steak
Mankz's Avatar
Seeing as you're a fellow Londoner, I'm holding you to that..
Old 21st Jan 2013, 10:25   #14
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Sarf landan massive!
Be aware that you will have to go thru certain checks before being allowed in the presence of His Imperial Majesty Mr Magoo.
and biscuits,you cant forget those....
Old 21st Jan 2013, 13:35   #15
Hukkel
Multimodder
Hukkel has yet to learn the way of the DremelHukkel has yet to learn the way of the DremelHukkel has yet to learn the way of the Dremel
tsk tsk tsk, everybody knows there is one ONE Group-B champion:
But since you know what group B is I will forgive you :P
Have a great build man !
Hukkel is offline   Reply With Quote
Old 21st Jan 2013, 15:37   #16
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Audi and Lancia would beg to differ.....
Old 26th Jan 2013, 11:12   #17
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Found some G1/4 Banjo bolts......
These with the copper tube I use,or maybe even braided hose, would really carry the Rally theme off,Just need to find some that are better to look at.......
I was hoping to find some with a more automotive look
Old 31st Jan 2013, 13:16   #18
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
Ok,this update is about flipping the tray and having a look at what space i have.
ATX....not cool.
I am a fan of R-ATX and with this case its simple to do.
Drill out all the rear panels rivets and get the tray out.
Flip her over and slide it in.
TA DAAH!
All the rivet holes line up,its only the top of the case where I need drill fresh holes.
Test fit the rad? Yeah,why not.
It fits.
The bleed port on the top has just volunteered to be the new drain.
That mesh over the fans has to go...
I wont be using the Corsair fans,I will be using BitFenix Spectre PRO's,I used them to get a rough idea of how it all fits.
Rough cut the grill out,this is being replaced with mesh covering the whole open section.
Filed and fitted.
Get the trusty donkey PSU in for a test fit.
I will be using a 2013 Corsair GS600 for this build,dont need massive power this time round.
More updates coming soon,I need to get some work done on Arctic Water first tho.....
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
