#1 |
Minimodder
Folding rig suggestions please?
Hi All
I have managed to get my hands on an old Dell Poweredge 1900 server and was wondering what way I could utilise it to get the most folding points possible. The spec is as follows: 2 x Xeon 5150 @ 1.6GHZ 16Gb DDR2 PC5300 ECC RAM 2 x 320 GB SAS drives 2 x 250GB scsi hard drives I am intending on using it as a base for learning VM Ware ESXi 5.1 but I would like to combine that with perhaps making the VM's folding clients as well. Should I use Linux VM's or Windows as I would rather run Linux as I believe that to be the best OS. Meanwhile I shall look at what others are doing in the server folding world for some inspiration. As always thanks for any help provided.
__________________
#2 |
Cheesecake Nom Nom
ive just checked your Xeons out and it says on intels website they run at 2.66GHz
![]() Ubuntu will net you the most points at folding... check out THIS Thread on the [H]ard forum its what i used to set up my Duel Xeon rig
__________________
2x Xeon 5620 @ 3.8GHz under water ![]() 3770k @ 4.8GHz, Custom loop, 7970 OC'd |
#3 | |
Minimodder
Guess I must have the model number wrong, should be the 5110 I reckon I already use Ubuntu on a Phenom X2 555 running the smp client. Will check out the links and thanks for the help.
__________________
#4 |
Multimodder
I like instruction 3;
Go get a sandwich. OK then.
__________________
| Thread Tools | |
