Reply
Thread Tools View Mode
Old 20th Jan 2013, 23:26   #1
shinji2k
Multimodder
shinji2k's Avatar
shinji2k is a Super Spamming Saiyanshinji2k is a Super Spamming Saiyanshinji2k is a Super Spamming Saiyanshinji2k is a Super Spamming Saiyanshinji2k is a Super Spamming Saiyanshinji2k is a Super Spamming Saiyanshinji2k is a Super Spamming Saiyanshinji2k is a Super Spamming Saiyanshinji2k is a Super Spamming Saiyanshinji2k is a Super Spamming Saiyanshinji2k is a Super Spamming Saiyan
Project Malin *update 2/9*
Project Malin
Concept
I ended up with an extra i5 so I decided to do something simple to keep me busy during the winter. mITX seemed the way to go so I picked up some more parts and I was ready to go.
According to the internet, Malin can mean "little strong warrior".
Components
  • i5-3570 (non K)
  • ASRock H77M-ITX
  • 150W PicoPSU
  • X-25M 80Gb
  • Noctua NH-L9i
shinji2k is offline   Reply With Quote
Old 20th Jan 2013, 23:37   #2
shinji2k
Multimodder
shinji2k's Avatar
Update #1
Pile O' materials
These will be the sides.
Pieces of 1/2" to join everything together.
Sometimes hand tools just work better.
Old 20th Jan 2013, 23:44   #3
shinji2k
Multimodder
shinji2k's Avatar
Update #2
These will be countersunk eventually.
Cut the mid-plate.
Time for the bottom. More flat head screws are on the way so ignore the random hardware.
Case feet from an old Lian-Li case.
Cut the top panel. Nice spacers are on the way too, just using washers for now.
Picked up some maple for the front and back.
Threaded inserts for joining everything.
Here's where it sits for now.
I don't have much time during the week so hopefully there will be an update next weekend.
Old 21st Jan 2013, 14:31   #4
GuardianStorm
Ultramodder
GuardianStorm's Avatar
GuardianStorm has yet to learn the way of the Dremel
Very nice so far, subscribed
__________________
Sites: My Site :: My blog
Tools: Project Log Previewer
Curent Projects: Dark Vortex
Finished Projects: Yarrrbox :: Laptop Stand :: Bench PSU MK2 :: FS2
Guides: How To Bend Metal
GuardianStorm is offline   Reply With Quote
Old 21st Jan 2013, 14:38   #5
Mankz
5318008
Mankz's Avatar
Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.
Pweety.
Mankz is offline   Reply With Quote
Old 21st Jan 2013, 17:23   #6
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for president
Nice work. Reminds me of the Mini-HTPC I built.
Mosquito is offline   Reply With Quote
Old 21st Jan 2013, 18:04   #7
Editor22
E22 | Hex-Gear
Editor22's Avatar
Editor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming Saiyan
What a wonderful start! look forward to seeing the progress
__________________
Stores: E22 | HEX GEAR
Social: Youtube | Facebook
Projects: Evolution | K2 MK1 | 21
Editor22 is offline   Reply With Quote
Old 22nd Jan 2013, 00:33   #8
shinji2k
Multimodder
shinji2k's Avatar
Thanks!
Originally Posted by Mankz View Post
Pweety.
Hopefully it turns out as nice as yours!
I hope you aren't disappointed.
I've already had a bit of a rethink. I was set on hiding as many screws as possible and made a lot design choices based on that, but then I have four right on top where everyone can see. That top panel is only there to mask the fan intake and cover the screws holding the side rails on so I think I will make another piece but just mount it with magnets.
I was also set on a minimalist, modern look but I've been thinking of adding some small accents. Some art deco-ish alu inserts in the wood may work and/or something on the side rails. It'll still be sleek and simple but I'm hoping to give it some character. I'll play around and see if any of my ideas actually look good outside of my head. Thanks for reading!
Old 22nd Jan 2013, 01:08   #9
Ream
Multimodder
Ream's Avatar
Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!Ream - it's over 9000!!!!!!!!1!1!1!!!
Looks real nice, would sit rather pretty nest to my TV.
Cant wait to see the finsihed photos.
Ream is offline   Reply With Quote
Old 22nd Jan 2013, 02:23   #10
exexs
Multimodder
exexs's Avatar
exexs has yet to learn the way of the Dremel
Boner alert
__________________
Support and comments for my FIRST worklog are appreciated: http://forums.bit-tech.net/showthread.php?t=228161
exexs is offline   Reply With Quote
Old 22nd Jan 2013, 16:50   #11
dream1
Multimodder
dream1's Avatar
dream1 has yet to learn the way of the Dremel
Wow ooks good so far
dream1 is offline   Reply With Quote
Old 23rd Jan 2013, 08:39   #12
shinji2k
Multimodder
shinji2k's Avatar
Originally Posted by exexs View Post
Boner alert
I'm flattered?
Me too
I'd love to show you more but it's way too cold right now to be out in the garage, my little propane heater won't do much.
Old 23rd Jan 2013, 21:19   #13
morgansk
I've got wood
morgansk has yet to learn the way of the Dremel
Very nice - and good to see some wood.
morgansk is offline   Reply With Quote
Old 23rd Jan 2013, 22:22   #14
Ream
Multimodder
Ream's Avatar
Can you see exexs from where you are.
Old 23rd Jan 2013, 23:32   #15
Sissilisko
Multimodder
Sissilisko has yet to learn the way of the Dremel
that's really nice
__________________
Finished:
-Mini-PC http://forums.bit-tech.net/showthread.php?t=248203
unfinished:
none!
Sissilisko is offline   Reply With Quote
Old 25th Jan 2013, 01:54   #16
maestro0428
Master Modder
maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.maestro0428 is a hoopy frood who really knows where their towel is.
Seen a lot of SFF Pcs lately. Liking this so far. Ill be watching.
__________________
JAllen Labs GT1000- 3770K @ 4.5ghz, 32GB Dominators, ASUS 660GTX OC SLI, Samsung 840 Pro 256GB SSD, 4 drive RAID 0 and 3TB storage in a Silverstone Fortress GT03, Logitech G9X Gaming mouse on Razer eXact Mat, Custom built Fostex studio monitors, Yamaha amp, Nvidia Surround 3x23.5 AOC LED LCDs
maestro0428 is offline   Reply With Quote
Old 29th Jan 2013, 03:50   #17
shinji2k
Multimodder
shinji2k's Avatar
Update #3
I prefer to have the countersink the same diameter of the screw, but I didn't feel like buying a countersink to fit my 6-32 screws. So I made my own. Grabbed a cheapo from a local hardware store and ground it down to 0.300".
Used it to countersink everything and install the mobo standoffs.
I also went ahead and finished counterboring the screws for the front and back panel.
Time for the cpu intake.
There should be just enough space under the mobo to mount two 2.5" drives. I'll probably only be using the one ssd but there was room for a second, so why not.
Rabbiting bit ready to go. Don't try this at home! I purchased a mini mill for cheap but it's back-ordered so I won't be able to use it for this project. I wish I had it for this.
I ended up redoing the wood pieces. It was really hard to get everything lined up when I installed the threaded inserts. I cut the new ones slightly oversized and will trim them down later.
It started to get late so that's it for now. It'll be pretty warm the next couple days so I hope to get some more done.
__________________
Current Projects:
Loricatus In progress!
Malin On hiatus for a bit
Baby Moon Complete!
Old 29th Jan 2013, 14:15   #18
dream1
Multimodder
dream1's Avatar
LOL me "ooks" good.
Old 29th Jan 2013, 16:12   #19
Mankz
5318008
Mankz's Avatar
That HDD mount is awesome.
Old 30th Jan 2013, 03:56   #20
shinji2k
Multimodder
shinji2k's Avatar
Update #4
I squeezed in a little modding today. First up is finishing the hdd mount. Since I prefer to keep all my fingers, I made a jig to route the other side.
I had to order more 1/8" to redo the top and it came in today. I never bothered to show how I made the other panels so I'll walk you through my technique. First, a rough cut with the jigsaw.
Then to true up the edges, a belt sander at a 45 deg angle works wonders. Just move side to side with it and you end up with a nice edge.
I also received my neodymium magnets. I'll wait until I decide on how I finish the aluminum to glue them on to the top panel, but here's how it'll work.
I also trimmed down the new wood pieces.
I still need to do some fine tuning and cut out the I/O panel, but it's starting to come together
Thanks for reading!
__________________
Current Projects:
Baby Moon Complete!
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
