#21 |
This and that
This design is so beautiful. It's simple yet so stylish and unique. Really loved the recessed rear panel.
__________________
Current Bit-Tech project log: [Inet 001 - Codename Mono] [Curreal] - [Simplicity] - [Purple Haze] - [Red Wine] - [Malay] - [Nano] |
#22 |
Supermodder
#23 | |
Minimodder
Thanks! I don't know if I can handle all this praise.
__________________
Current Project: Malin |
#24 |
Minimodder
Update #5
I had a bit of time so I finally got around to installing the Noctua. I've been using the computer for a while without a case so the stock cooler was already installed.
I've been trying desperately to take better pictures with my cheap point and shoot. ![]() ![]() ![]() ![]() Isn't it cute? ![]() ![]() I've taken worse pictures I guess. Unfortunately, I'm going to need some slightly taller mobo spacers. I never had a set idea for the hdd mount and it ended up a little taller than I originally planned for. But that's fine since then the cpu fan will sit right up against the top panel and it'll be able to draw in cool air through the top slot without any problems. I'll have to figure something out temporarily so I can start on the i/o panel.
__________________
#25 |
give your head a wobble
very nice work! what sise psu are you going to use?
__________________
mozart tx case(11x120mm fans),intel i7 920@4ghz(20x200)1.28v,asus rampage extreme 2,6gig corsair ram(3x2gig),2xati hd5870 crossfire,titan fenrir hsf,enermax revolution 1250w psu,1x120gig ssd 4x1tb hdd,x-fi elite pro soundcard,dell 2405fpw 24"lcd,zboard merc k/board,cyborg rat 7 mouse,win7 64bit Last edited by that_du^de; 1st Feb 2013 at 18:15. Reason: wrong post |
#27 |
Minimodder
Update #6
I was finally able to dedicate some more time to modding.
First I cut the opening on the rear wood panel, but I managed to not take any pictures. You'll see it later anyway. Then I started on the i/o panel. ![]() ![]() That scroll saw is a cheap POS but it's a lot better than using a coping saw. ![]() After a serious filing session I ended up with this. ![]() And more threaded inserts. ![]() ![]() ![]() ![]() ![]() Crap, totally forgot about the power jack. There are also a few places that need tweaking on the i/o panel. That'll just have to wait until next time.
__________________
| Thread Tools | |
| View Mode | |
