#1 |
Administrator
bit-tech Staff
Fractal Design Core 3000 review
#2 |
I Mod, Therefore I Own
No Filters, No USB3.
Where'd this box come from, the 90's?
__________________
SN25P A64 3700+ (San Diego) 2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T X1800XT 512mb Sapphire 200GB Samsung SP2004C 24" Asus something 1920x1080 |
#3 |
No, seriously, wtf is a dremel?
bit-tech Staff
Ha. There are dust filters for both the PSU and entire front section, as was mentioned and photographed :P but the lack of USB3 is a shame, yes.
#4 |
What's a Dremel?
Why do so many cases omit a cutout for the 8 pin power cable? It ruins the look of an otherwise neat cabling job. I agree about the lack of USB3 front connector support & filters...both should be standard on any modern case.
#5 |
WIIGII!
bit-tech Staff
I was looking at the Core 3000 for a proposed eight-core build - my desktop's in a Define Mini, and I have few complaints other than the lack of a hard drive activity light. If I do end up building another machine, the Core 3000 is certainly high on the list - it's a damn sight cheaper than the Define Mini, for a start...
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter bit-tech news correspondent, Custom PC columnist I'm a filthy freelancer! Hire me! |
#6 |
Multimodder
I had the same problem of very tight side panels in my Core 1000 seems that it's a problem with the design they use for both cases.
__________________
Main box: FX 6300 @4.2GHz, 8GB Value RAM, Nvidia GTX 470, Corsair Force GT 90GB, Silverstone PS07, Win7 |
#7 |
You'd have to consider it's more about keeping costs down than a design flaw, the 1000 is £30, what do you want for £30? I'm not saying I wouldn't like them, the 1000 is a cracking little case and I'd happily pay a few quid more for some more space (read, any space and a cutout or two) behind the mobo tray.
__________________
I request you to interact on this forum in a streetwise style without going against the Data Protection Act. |
#8 |
Minimodder
So that's the Midgard II and Core 3000 reviewed in the space of less than a fortnight, just as I'm trying to put together a budget build! Good going, BT - now I've just got to decide whether the Core 3000's better cooling and lower price outweighs the Midgard II's USB 3 and better cable routing...
#9 |
Modder
Personally I find the Core 3000 the better looking case out of the two but the wiring issue is a little off putting. Does anyone think there would be any issues in taking a dremel to the motherboard tray?
__________________
C2D E8400 (@3600), Biostar I45 T-Power motherboard, 2x 2Gb 1066 OCZ Reaper, Powercolor HD5850 (stock speed with Accellero S1.2 heatsink), Coolermaster 500W PSU |
#10 |
I'm insane, not stupid.
I don't see why you couldn't mod the chassis to perform better- that's what we're all here for after all
__________________
ASUS P8Z77-M PRO | INTEL CORE i5 2500K @ 4.3GHZ | EVGA GEFORCE GTX 670FTW | CORSAIR VENGENCE DDR3 1600MHZ 2x 4GB | SAMSUNG SPINPOINT F3 1TB | TITAN FENRIR | ACER PREDATOR | WIN 7PRO x64
#11 |
What's a Dremel?
I got it 2 weeks ago and i'm happy, i'm still running a q6600 so no USB 3 isn't an issue, till i upgrade.
build quality is nice. @MrJim, there is a cutout for the cpu power, but not all power supplies have a long enough cable...i'm guessing that's why they didn't route it round the back. |
#12 |
Hypermodder
I've got the Core 3000, baught it the stat of the month. Lack of USB3 on the top doesnt really bother me too much as I dont own any USB3 devices.
As for the Cutout it is a bit of a pain not to have a hole up the top but its been mentioned by sniperdude to run the cable through the CPU backplate hole and up over the top of the board of which could be a solution. However with the top fan in its default place there is not much room to work with regards to cabling. |
#13 |
bit-tech Staff
Just to reiterate what's been added to the article, the USB 3.0 version of the Core 3000 which is listed on Fractal's site will be launching in the coming months with a UK MSRP of £54.95. The review and score for the regular Core 3000 remains unchanged, however.
#14 |
USB 3.0 version still isn't sold, is it?
__________________
#15 |
bit-tech Staff
#16 |
Thanks,
also sorry, i've been reading so many case reviews, i got them mixed up, i thought the review was older
__________________
| Thread Tools | |
