Reply
Thread Tools View Mode
Old 21st Jan 2013, 20:08   #1
Marquee
Mac Pro Modder
Marquee's Avatar
Marquee has yet to learn the way of the Dremel
Umbra Aqua - Mac Pro (Motherboard tray designing 4.19.2013)
Project Umbra Aqua
Objective:
1) Convert a MacPro 2006 case to accept modern computer hardware.
2) Create a cooling solution that can surpass what is required of it.
The cooling system that is required is a custom water cooling loop, which consists of three radiators in series. In order to achieve this, the case must be modified to fit a mATX motherboard; this will provide enough space to fit the third radiator.
I got my hands on a mac pro 2006. I knew when I saw it, I had to get back into modding. I have always loved the g5 case. I did some research and found that there was many ways of turning the mac pro into an atx or matx. Route I am taking is a blend of many of them. The key difference is in my conversion phase I am not going to keep all the Apple wiring system, front panel, and mounting. What I decided to do was use a donor case to get all pc mounting systems and parts.
TO DO LIST
  • take apart mac proDone
  • strip lian li caseDone
  • exterior cutting90% Done
  • design water coolingDone still tweaking
  • mount mother board tray
  • mount water cooling50% Done
  • wire the case
  • paint
  • order Pc hardware
  • I NEED A NAMEDone- Umbra Aqua
-1/30/2013- I found a name I would like to use. Umbra Aqua, its latin for shadow water. How I came up with the name? Well the case is silver and I am so far planning to paint it two tone silver. So I guess you can say I went from shades to shadow. There you have it, Umbra Aqua
I picked up a Lian- li pc600f for $69 which had:
-mother board tray
-120mm x2 fans
-140mm fan
-front wiring with usb 3.0
Now the Mac Pro. This was a working Mac Pro.
It toke me about 1 hour to get to this point
Time to strip the lian li
Window one
window 2
This is to create a frame to mount the water cooling too.
I am going to cut from here for the front panel
So as you can see the Lian li case was great to harvest from.
I have ordered my water cooling set up for phase one of the cooling.
Monsoon Free Center Compression Fitting - 3/8"ID x 5/8"OD - Modders 6 Pack Chrome
Alphacool VPP655 Variable Speed Pump - HF Top Edition
Alphacool NexXxoS UT60 Full Copper Dual 120mm Radiator
XSPC 240mm Radiator Gasket
Reusable Radiator Template
Phobya Balancer 150 Reservoir - Silver Nickel
Marquee is offline   Reply With Quote
Old 21st Jan 2013, 21:01   #2
Telefonskaft
Minimodder
Telefonskaft has yet to learn the way of the Dremel
Looks like you've got a good start! Hope this turns out well, I love Mac mods!
__________________
Lurking
Telefonskaft is offline   Reply With Quote
Old 22nd Jan 2013, 12:27   #3
Marquee
Mac Pro Modder
Marquee's Avatar
I am actually having a hard time deciding if I should mount the motherboard lower in the case, this will mean in the future I can put a full atx board. The problem is that in my ideas for phase two of the water cooling, I would like to mount a 280 rad on the bottom. But with a atx that wont work.
__________________
Umbra Aqua - Mac Pro Mod
Old 26th Jan 2013, 13:36   #4
Marquee
Mac Pro Modder
Marquee's Avatar
So the water cooling parts arrived. They look pretty sweet. I am still missing the pump top and stand. Its on its way and should be here by next week. I am going to be moving soon I am going to try to get all the cuts done for the water cooling frame before I move. After I move it might be a couple months before I swipe out the whole case again. I might just do my wiring in the mean time.
The whole lot.
The res is so sweet and has some weight to it.
I am still in shock how sweet the fittings look.
In these two photos you can see the space that is left after the mother board will go in. First is with rad fitting at the bottom and second photo is with the rad fitting at the top. I am almost 100% sure I will mount the res to the water cooling frame. But here is the photo just to see how much room I had before the tray.
I found something I want to change. The little stand under the rad is going to have to go. It looks ugly. Instead I will make a cover for the whole bottom to hide wires and bottom of the rad frame.
Old 26th Jan 2013, 20:02   #5
WhatTheTech
Macmodder Addict
WhatTheTech has yet to learn the way of the Dremel
I'm also doing a mac mod - can't wait to see how yours turns up!
WhatTheTech is offline   Reply With Quote
Old 6th Feb 2013, 01:23   #6
Marquee
Mac Pro Modder
Marquee's Avatar
Feb 5th frame and rad mount
So I left last time with being unhappy with the raised area under the rad. So lets just dive right back into the swing of things.
Drilling out the rivets
Took the plate off and realized I could reuse it upside down. As soon as I found the screws for it I found that was a no go. The screws were tiny like watch screws
So I made my own out of green acrylic.
Little bit of filing here
Now there is more room for that rad.
After I fit the rad. I was playing around and found that the old ram and CPU cover fit perfectly straight up. So I started thinking why not use them as the rad shroud. So once I get the rad mounted, that's next on my list.
The frame for my rad and water cooling.
I was so happy with my find I started working on it before the rad mounting was done.
__________________
Old 6th Feb 2013, 01:26   #7
Marquee
Mac Pro Modder
Marquee's Avatar
Using the line on the piece I drew out a cut out.
__________________
Old 6th Feb 2013, 01:47   #8
Marquee
Mac Pro Modder
Marquee's Avatar
A package came today. The missing pump top. I thought it was going to be the rounded corner version from the photos but I got the square one. What ever no biggie I am just happy its here to I can mark it up on the case.
Time to go back to the case. I dont get much time off and I am moving soon so I was a man on a mission today.
Tapped the piece I made.
I used the threads to line up the aluminum stock
Then drilled and tapped it.
Here I am lining up the frame to find the point to drill it. I also find the hard drive rack needed to be cut to clear the frame just a hair.
Drilled and tapped the two frames together.
__________________
Old 6th Feb 2013, 04:31   #9
Scirocco
Boobs, I have them, you lose.
Scirocco's Avatar
Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!
Love Mac Pro cases and it looks like you're off to a good start. I'll be watching.
__________________
"If she were any more of a bitch, she'd have puppies!" Victoria Chase, Hot in Cleveland.
Current project: La Fée Verte
Scirocco is offline   Reply With Quote
Old 6th Feb 2013, 11:18   #10
nagyizom
Supermodder
nagyizom's Avatar
nagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremel
Great start!
__________________
Current projects: Graphite 5 | Tydirium is on the way!
Previous mods:|Sandcrawler Mod| |Illuminated Mind|
Follow me on Facebook
nagyizom is offline   Reply With Quote
Old 15th Feb 2013, 07:13   #11
thegyufi
on air
thegyufi has yet to learn the way of the Dremel
please post the next photos !!
__________________
[project log] Apple Cube
thegyufi is offline   Reply With Quote
Old 15th Feb 2013, 14:05   #12
Marquee
Mac Pro Modder
Marquee's Avatar
This is some work I did on the front panel. I am going to moving in less the two weeks so I really got keep the mess to a minimum. BTW do you guys like the description of the picture to be on top of the picture or under the picture.
So for the front panel I will be using the Lian Li case. It has the cut out I need and USB 3.0. I really did't like the Mac front panel because it has fire wire which I never use.
Marked it up. Made my first cuts with a Dremal then cut with a jig saw.
Here I filed the piece. Then filed some more. When I thought I was done, I filed for ten more minutes.
I think it look good now. But I have a funny feeling that I am going to be filing it some more.
I cut a piece of acrylic to match this piece. I sanded it down. Then I started drilling the hole for the connectors. Did not go so well. Its ok though I didn't like the design any way.
I made a new piece that allowed the connectors to be flush with the front panel. I started glueing it together this morning. Nothing like the smell of J&B when you wake up.
__________________
Old 15th Feb 2013, 16:34   #13
AverageNinja
Tech-Kid
AverageNinja's Avatar
AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.AverageNinja is the Cheesecake. Relix smiles down upon them.
That's a tiny dual socket motherboard there
Also I see you're going to use monsoon fittings, nice choice!
AverageNinja is offline   Reply With Quote
Old 15th Feb 2013, 18:11   #14
KayinBlack
I Endure
KayinBlack's Avatar
KayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for president
What CPUs were on that motherboard, and was it junk?
__________________
I don't feed the trolls...
Quit chopping up the locals to make tools.-Cheapskate
KayinBlack is offline   Reply With Quote
Old 16th Feb 2013, 05:30   #15
Marquee
Mac Pro Modder
Marquee's Avatar
There was two dual core 2.66ghz xeons. They work, just don't have a use for them.
__________________
Old 19th Feb 2013, 20:27   #16
Marquee
Mac Pro Modder
Marquee's Avatar
19 Feb front panel/ psu done
So since the last time I posted I have got a little more work done and no packing. Which looking back is a little insane cause I am moving in 9 days now.
I was able to acquire a Corsair HX 1050 of kijiji for $140 CDN. I really like the Corsair psu's I got a HX 650 in my main rig right now. Its was great for overclocking my A10 to 4.6 so I thought it would be great in this build also. I would love to put Corsair AX in this build but lets be honest I don't got a money tree on my balcony.
The J & B weld is also now cured so I went to work on mounting the front panel to the case. I found there is still to much room between the button and the panel. So I am thinking either make a spacer to go on top of the button or cut more of the case. Right now I am leaning towards making a spacer.
So here I am lining up the holes to drill and tap the new piece.
Cut my hole on the case then filed down the edges
All done for now.
Now time to work on the psu.
So here you see the mounts were drilled to fit the new screws. I mounted the psu standing upward because I have designed it to be off the floor of the top.
Then I placed one of the apple rubber spacers under the psu before I rotated the case the right way.
You might have noticed I have placed the psu with the fan upward. There is two reasons for that. One is to keep the top area as its own thermal zone. Two is because then the psu wires that are hard wired in the psu will be facing away from visible side.
BTW I tried this time to place the description on top of the pic. Its easier to write this way. I hope its easier to read for you guys.
__________________
Old 20th Feb 2013, 16:00   #17
thegyufi
on air
good work on with your front panel, can't wait to see the final integration !
__________________
Old 20th Feb 2013, 16:23   #18
elAwesome
Multimodder
elAwesome's Avatar
elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.
I like where this is going!
elAwesome is online now   Reply With Quote
Old 20th Feb 2013, 16:33   #19
elAwesome
Multimodder
elAwesome's Avatar
double post, sorry
Old 20th Feb 2013, 16:34   #20
shrop
Hypermodder
shrop's Avatar
shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.
Nice start mate, will be watching this one, I loved G5 mods
__________________
Pexon PCs
Pexon @ GH
Steel Series 6G v2 w/ MX Black / Noppoo Choc Mini w/ MX Blues / Happy Hacking Keyboard Pro 2 Anthracite
shrop is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
