Reply
Thread Tools View Mode
Old 21st Jan 2013, 21:23   #1
Zsolt Guriga
Multimodder
Zsolt Guriga's Avatar
Zsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run Crysis
Project: The Apple/19.03.2013/Interior
I cordially greet you, and I want to welcome you to my new project,called The Apple
After the finish of Hello Kitty-project,I was thinking a lot about a new one,and I decided to mod an Apple G4 case, the very fact that the error of ATX motherboards, and other components of course, I found it a challenge
This mod would like to progress in the field of presentation and taken photos, which is quite far away, so to speak, from me
My goal is to create a compact mode (PC), which in appearance and performance meets the present day
HW used will be shown step by step, as currently only the i7 3770k own that will be the heart of this Project
In short I want to prove that not all the old stuff for the landfill and waste
I hope you will enjoy the new project, and that we will share impressions, ideas, and have fun
So lets start
A couple of pictures of the case and its condition :
Zsolt Guriga is offline   Reply With Quote
Old 21st Jan 2013, 22:01   #2
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for president
Super.
I ja već dugo tražim G5-icu da ju sredim ali nikako da nađem krepanu.
Baš me zanima kako češ srediti ovu četvorku.
__________________
_Cosmos S Reaper_ _L.R.E.C._ _Scorpio_
_Arya_-under construction _ROG Crawler_
Pranja is online now   Reply With Quote
Old 22nd Jan 2013, 03:48   #3
siliconfanatic
Rep whore/ Car lover/ Speed Junkie
siliconfanatic's Avatar
siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.
Why do I have a strong feeling that that hex nuts gonna end up as a fill port?
I always have liked the G4 case albeit more than the G5.
I'm gonna get flamed...... I'm gonna get flamed...
__________________
Hard to explain to someone who has no clue. Or doesn't believe you. It's a daily struggle being in pain or feeling sick on the inside while you look fine on the outside. Please put this as your signature for at least 1 hour if you or someone you know has an invisible illness (Pancreatitis, Crohn's, PTSD, Anxiety, Bipolar, Depression, Diabetes, LUPUS, Fibromyalgia, MS,Lupus, ME, Arthritis, Cancer, Heart Disease, Epilepsy, Autism, etc.) " Never judge what you don't understand.
siliconfanatic is offline   Reply With Quote
Old 22nd Jan 2013, 13:25   #4
Father-Time
Multimodder
Father-Time has yet to learn the way of the Dremel
Very interested to see how this goes, i have one in bits in my shed! They are a well made case alright. Will be good to see what you do with it, good luck!
__________________
Current Project : Server mod incoming!
Father-Time is offline   Reply With Quote
Old 22nd Jan 2013, 21:16   #5
Zsolt Guriga
Multimodder
Originally Posted by Pranja View Post
Super.
to nisam ni ja druže našao,ali sve u svemu ovo kućište mi je slađe od G5,jer je manji i kompaktniji
želeo bih da spolja sačuvam osobine fabričke koliko je moguće
Old 22nd Jan 2013, 21:21   #6
Zsolt Guriga
Multimodder
I agree with you,I like much more this case than the G5 too
So you think that the hex nuts gonna end up with fill port,hmmmgood idea,but lets wait and see
Old 22nd Jan 2013, 21:23   #7
Zsolt Guriga
Multimodder
Thanks,and Iam ipressed too with the quality of the case
Old 22nd Jan 2013, 21:29   #8
Zsolt Guriga
Multimodder
Lets back on the work
I started to disassemble the case,with the help of a picture what I founded on the web
Here is the pictures of the progres
First the side that opens
Old 22nd Jan 2013, 21:31   #9
Zsolt Guriga
Multimodder
And the other side
Old 22nd Jan 2013, 21:34   #10
Zsolt Guriga
Multimodder
And finally the case without cover
please let me say again,that this case is really exelent quality
Old 22nd Jan 2013, 21:44   #11
Razarach
Multimodder
Razarach's Avatar
Razarach has yet to learn the way of the DremelRazarach has yet to learn the way of the DremelRazarach has yet to learn the way of the Dremel
Odličan projekt. Svaka čast!
Razarach is offline   Reply With Quote
Old 22nd Jan 2013, 22:23   #12
exexs
Multimodder
exexs's Avatar
exexs has yet to learn the way of the Dremel
I have the same case in my attic! Wanted to do something with it, but eeh other projects ^^ Wanna follow what you'll do with it
__________________
Support and comments for my FIRST worklog are appreciated: http://forums.bit-tech.net/showthread.php?t=228161
exexs is offline   Reply With Quote
Old 24th Jan 2013, 15:51   #13
Zsolt Guriga
Multimodder
Hvala druže,pratim te i ja,super su ti ruke za drvo
Old 24th Jan 2013, 15:56   #14
Zsolt Guriga
Multimodder
Glad you have the same case,so welcome and follow this project,and the end if you liked it,you can do the same,or even better,with new ideas
Old 24th Jan 2013, 16:02   #15
Zsolt Guriga
Multimodder
The weather was so good in the morning, so I threw on the project
I plotted where and how to cut the bottom of the case,so I can turned it into atx case
and I decided to go a few steps further than pure measurement
Old 24th Jan 2013, 16:07   #16
Zsolt Guriga
Multimodder
Because of the good quality of case,I decided to use heavy artillery instead dremel
Old 24th Jan 2013, 16:16   #17
Zsolt Guriga
Multimodder
Redundant parts
Weather forecast
Roughing with rasp
Old 24th Jan 2013, 16:16   #18
nagyizom
Supermodder
nagyizom's Avatar
nagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremel
Great start! Looking forward to see what will you do with this case.
__________________
Current projects: Tydirium is on the way!
Previous mods: |Sandcrawler Mod| |Illuminated Mind| |Graphite5|
Follow me on Facebook
nagyizom is offline   Reply With Quote
Old 24th Jan 2013, 16:22   #19
Zsolt Guriga
Multimodder
Assembling,just to see how fit in
I need here additional processing,and after that im gonna glue it with two component liquid metal or i can use even epoxid
To be continued……..
Old 29th Jan 2013, 21:29   #20
Zsolt Guriga
Multimodder
Thanks my friend,and I cant wait to see yours G5,Ireally like it
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
