Reply
Thread Tools View Mode
Old 5th Feb 2013, 20:27   #41
Zsolt Guriga
Multimodder
Zsolt Guriga's Avatar
Zsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run Crysis
Originally Posted by nagyizom View Post
Maybe you can use more light when you take your pictures.. we can see more details
Thanks,and sorry for the quality of photos.it will never happend again
I promise
Zsolt Guriga is offline   Reply With Quote
Old 5th Feb 2013, 20:29   #42
Zsolt Guriga
Multimodder
Originally Posted by barry99705 View Post
If you want to repaint the graphite plastics, 90% iso alcohol will dissolve the paint. I cleared out my old one that way. We also used to clear out the original snow G3 macbooks that way, until they started making them with white plastic.
Yeah I gonna do it that way
Thanks for this,it is very useful for me
Old 5th Feb 2013, 20:30   #43
Zsolt Guriga
Multimodder
This morning again was great time to work outside
I started with the draft, exactly where I placed the bracket of the PSU,and I decided to place it where the optical drive was(anyway I don’t use optical drives)
With this move I limited the length of VGA to the motherboard width,maybe 20mm more than motherboard width can fit,but I think it will not cause any problem
As I told,the weather is really…………
Let's get to work
In-house workshop (when wife not at home)
Old 5th Feb 2013, 20:31   #44
Zsolt Guriga
Multimodder
From now seriously!!!!!!!!!!!
This PSU bracket,is from other old case
Cut with good old recipe, …..
Old 5th Feb 2013, 20:32   #45
Zsolt Guriga
Multimodder
Since it is not really a suitable place for mounting the bracket, because of that I decided to take the door
Bracket in place, visually monitoring ……….
Old 5th Feb 2013, 20:33   #46
Zsolt Guriga
Multimodder
The main tool ,to accept the nut M3
Old 5th Feb 2013, 20:34   #47
Zsolt Guriga
Multimodder
Unfortunately I not have PSU,I use just a house of older PSU
There are small problems arise,as you can see,I must cut them
Old 5th Feb 2013, 20:35   #48
Zsolt Guriga
Multimodder
I almost cut l 35mm, and a disc less
The PSU in place
To be continued…………..very soon
Old 6th Feb 2013, 09:15   #49
Father-Time
Multimodder
Father-Time has yet to learn the way of the Dremel
Thats a real snug fit!How will it impact on the plastic exterior?
Great work so far though i love it!
__________________
Current Project : Server mod incoming!
Father-Time is offline   Reply With Quote
Old 11th Feb 2013, 10:58   #50
Zsolt Guriga
Multimodder
I decided to check,and I started to assemble,I need to make something like fan grill on the top of the PSU,exactly on the plastic cover
Thanks my friend
Old 11th Feb 2013, 10:59   #51
Zsolt Guriga
Multimodder
A lot of things are done in the case, which would of course affect the external appearance, because I really like the case, I would not change it that much outside, as much as possible I keep the original look
So I decided to put together, and to check that the changes were necessary to the exterior
Old 11th Feb 2013, 11:00   #52
Zsolt Guriga
Multimodder
Here I ran into a problem
After cutting some parts, the situation has improved
Old 11th Feb 2013, 11:01   #53
Zsolt Guriga
Multimodder
And now its looking better
Old 19th Feb 2013, 17:35   #54
Zsolt Guriga
Multimodder
I worked a little on it, cut a hole for the vent (140mm) from the bottom, and installed PSU that I used,and the motherboard installed too,to see space between the PSU and the motherboard
So the VGA is have to be no longer than the motherboard,its about 245mm
But with the VGA what I planning its not gonna be problem to fit in
Also the SATA cable is perfect fit,I am going to use the 90 deg side to motherboard ,its going to be ok
We can see exactly how little space there is, PSU to the motherboard, but it's enough
Old 19th Feb 2013, 18:38   #55
elAwesome
Multimodder
elAwesome's Avatar
elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.
It's slowly getting into shape!
I like it
elAwesome is offline   Reply With Quote
Old 24th Feb 2013, 12:00   #56
Zsolt Guriga
Multimodder
I like it
Yes it getting into shape,but really slowly,without HW is work,I still not have VGA,SSD,RAM and CPU cooler,but I trying to get sponsors
I am glad you like it
Old 24th Feb 2013, 12:47   #57
Marquee
Mac Pro Modder
Marquee's Avatar
Marquee has yet to learn the way of the Dremel
Good luck on the sponsor's there hard to come by. Modding a mac is allot harder then it seems codos to you.
__________________
Umbra Aqua - Mac Pro Mod
Marquee is offline   Reply With Quote
Old 25th Feb 2013, 18:06   #58
Zsolt Guriga
Multimodder
Thanks my friend,Im gonna need it
I agree with you its really hard work to mod a mac,but it is the point
Old 26th Feb 2013, 02:49   #59
siliconfanatic
Rep whore/ Car lover/ Speed Junkie
siliconfanatic's Avatar
siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.
that 24pin is right next to the psu... You could do something with that Just ALOT of measuring, ALOT of wire cutting, ALOT of wire stripping, AND ALOT of soldering+crimping. Maybe some sleeving. The result would be a real clean, pretty wire bend.
Kudos to you on realising what was preventing the plastic from fitting. I'd have been sitting there -ing for hours on end.
__________________
Hard to explain to someone who has no clue. Or doesn't believe you. It's a daily struggle being in pain or feeling sick on the inside while you look fine on the outside. Please put this as your signature for at least 1 hour if you or someone you know has an invisible illness (Pancreatitis, Crohn's, PTSD, Anxiety, Bipolar, Depression, Diabetes, LUPUS, Fibromyalgia, MS,Lupus, ME, Arthritis, Cancer, Heart Disease, Epilepsy, Autism, etc.) " Never judge what you don't understand.
siliconfanatic is offline   Reply With Quote
Old 26th Feb 2013, 17:13   #60
Zsolt Guriga
Multimodder
Well my plan is to hide those wires of the psu,all of them,because I really love the clear look of pc cases,I think its going to be ok,you will see
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
