Reply
Thread Tools View Mode
Old 26th Feb 2013, 19:14   #61
Zsolt Guriga
Multimodder
Zsolt Guriga's Avatar
Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.
Yesterday I working a lot on project,cut the holes of the back of the motherboard tray,and also make the place where I gonna put the storage(HDD and the SSD)
There was a lot of chopping, drilling, into plexi parts, which are 6mm thick
Place of HDD and SSD is not completely finished yet because I plan to make the cover of a thin sheet and put under the lights, soon…
Making the background parent, which will be attached to the chassis:
Zsolt Guriga is offline   Reply With Quote
Old 26th Feb 2013, 19:16   #62
Zsolt Guriga
Multimodder
Work progress:
Old 26th Feb 2013, 19:16   #63
Zsolt Guriga
Multimodder
Where I gonna set the HDD and SSD is basically a standard place, which is gonna be rearranged:
First I did a cardboard template:
Old 26th Feb 2013, 19:17   #64
Zsolt Guriga
Multimodder
Then transferred to the plexi all of which will cut:
Next is a test :
Old 26th Feb 2013, 19:18   #65
Zsolt Guriga
Multimodder
Tightening with M3 screws :
There is still a cover to be done, then the lighting,to be continued,very soon…..
Old 26th Feb 2013, 19:46   #66
nagyizom
Supermodder
nagyizom's Avatar
nagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremel
Wow, this cover is really nice! Great idea.
__________________
Current projects: Tydirium is on the way!
Previous mods: |Sandcrawler Mod| |Illuminated Mind| |Graphite5|
Follow me on Facebook
nagyizom is offline   Reply With Quote
Old 1st Mar 2013, 21:04   #67
Zsolt Guriga
Multimodder
Thanks my friend,i am gonna make the complete interior like that
I know it will be complicate,but I am gonna do....
Old 1st Mar 2013, 22:54   #68
Father-Time
Multimodder
Father-Time has yet to learn the way of the Dremel
Nice idea, very well done too, Keep it up this is a really nice/good project!
What are the marks on the motherboard tray for, cable management?
__________________
Current Project : Server mod incoming!
Father-Time is offline   Reply With Quote
Old 9th Mar 2013, 09:12   #69
Zsolt Guriga
Multimodder
Thank you so much, I'm really glad you like it.
And yes the marks on the motherboard tray is for cable managment.
Old 19th Mar 2013, 19:38   #70
Zsolt Guriga
Multimodder
I work a little,I am sorry for the late update,but I have some problems
So lets get on the mod,well when I was started this project,I decided to make the complete interior of the case with plexi glass
I started with the back of the case,first like always the paper model,and after that if pass well,cutting the part of plexi glass
Here in the back side of case,I have the plan to make custom cover,for the exhaust air from the case
Old 19th Mar 2013, 19:39   #71
Zsolt Guriga
Multimodder
After this,I worked on the cable management,to hide the cables of the PSU
Old 19th Mar 2013, 19:39   #72
Zsolt Guriga
Multimodder
Distancers,to hold the distance between the plexi parts
Old 20th Mar 2013, 14:38   #73
Marquee
Mac Pro Modder
Marquee's Avatar
Marquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming Saiyan
I like that slotted wire management. What is the custom cover going to look like?
Marquee is offline   Reply With Quote
Old 20th Mar 2013, 15:17   #74
WaRn00b
bit-tech addict
WaRn00b's Avatar
WaRn00b is a hoopy frood who really knows where their towel is.WaRn00b is a hoopy frood who really knows where their towel is.WaRn00b is a hoopy frood who really knows where their towel is.WaRn00b is a hoopy frood who really knows where their towel is.WaRn00b is a hoopy frood who really knows where their towel is.WaRn00b is a hoopy frood who really knows where their towel is.WaRn00b is a hoopy frood who really knows where their towel is.WaRn00b is a hoopy frood who really knows where their towel is.WaRn00b is a hoopy frood who really knows where their towel is.WaRn00b is a hoopy frood who really knows where their towel is.WaRn00b is a hoopy frood who really knows where their towel is.
Wow... really like where this is heading!! Subbed!!
WaRn00b is offline   Reply With Quote
Old 28th Mar 2013, 00:07   #75
Zsolt Guriga
Multimodder
Thanks my friend,I not decided yet totally how its going to look like,first I am gonna draw it in Autodesk Inventor
Old 28th Mar 2013, 00:10   #76
Zsolt Guriga
Multimodder
Thanks man,really -really slowly getting in to shape,but it will be done
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
