Reply
Thread Tools View Mode
Old 18th Feb 2013, 11:28   #21
ALS
Minimodder
ALS's Avatar
ALS has yet to learn the way of the Dremel
Tony, Hello from Russia!
ALS is offline   Reply With Quote
Old 19th Feb 2013, 01:30   #22
swaggahurtz
2 c not what is but what can be....
swaggahurtz's Avatar
swaggahurtz has yet to learn the way of the Dremel
Originally Posted by ALS View Post
Thats gangsta
__________________
Red-e-Red m-blu rilo-1
blu2bitz
N.V.Green
Project Tony Montana current build
swaggahurtz is offline   Reply With Quote
Old 20th Feb 2013, 00:12   #23
swaggahurtz
small update. steady progress.
fixed the res, no leaks. the rad is good as well. the cpu block i reworked because the fittings were touching the copper on the back of the plate and still had a few more millimeters before sitting flush. so i added a third piece of plexi. the fitting are flush now and still not touching the copper and no leaks. i also added a few more blots to it. the pump, has been taken apart twice about to put it back together and test it again.
put the fan back together and check them out.
i have been so busy working the kinks out of the loop, i have not had time to sleeve the psu yet, but that will be next.
more soon. thanks.
__________________
blu2bitz
N.V.Green
Old 23rd Feb 2013, 19:17   #24
swaggahurtz
i got the psu all sleeved and ready. i went with paracord because the sleeving from the kit is see through. i will still be using some of it for the fans and leds wires.
installed
started putting on the front bezel.
no pics but i may have to go with anther pump. i do have a back up, hope to have that worked out by the end of the weekend.
in the mean time i put the rest of the case together.
next up wiring and installing the leds and switches, getting the pump together and the loop installed, then power on and rounding up some more hardware.
more soon. thanks for looking
__________________
blu2bitz
N.V.Green
Old 23rd Feb 2013, 19:25   #25
JoshH
Minimodder
JoshH has yet to learn the way of the Dremel
Certainly a novel idea, good workmanship too!
Looking forward to updates to follow
JoshH is offline   Reply With Quote
Old 24th Feb 2013, 21:49   #26
swaggahurtz
thanks man, definitely more soon.
__________________
blu2bitz
N.V.Green
Old 24th Feb 2013, 22:34   #27
Bladesingerz
Supermodder
Bladesingerz's Avatar
Bladesingerz has yet to learn the way of the DremelBladesingerz has yet to learn the way of the DremelBladesingerz has yet to learn the way of the Dremel
Very nice man, good attention to detail as well!
Bladesingerz is offline   Reply With Quote
Old 25th Feb 2013, 03:39   #28
swaggahurtz
thanks . ive always been impressed with thoroughness and out the box thinking in builds, still got alot of small thing to do. i got the most of the white leds in (led strip, no pics yet) and the wiring for most of the reds. still got to do the amber.
more soon.
__________________
blu2bitz
N.V.Green
Old 26th Feb 2013, 18:21   #29
swaggahurtz
small update steady progress.
got the white leds in the case.
i put it back together and checked the look out.
i decided to frost the mobo and psu back plates.
i also got the red leds wired and in the back plates, pics soon.
the leds for the feet and logo in the bezel.
more soon. thanks.
__________________
blu2bitz
N.V.Green
Old 11th Mar 2013, 14:05   #30
swaggahurtz
Been a little caught up the last week or so and haven't been able to to get much time into this project. But most of the leds are in and i am back on it this week.
more updates soon.
__________________
blu2bitz
N.V.Green
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
