Reply
Thread Tools View Mode
Old 26th Jan 2013, 10:54   #1
sntmods
Minimodder
sntmods has yet to learn the way of the Dremelsntmods has yet to learn the way of the Dremel
WIP: Sickrig002 Fractal R4 & AquaComputer
I have been a long time lurker and I am quite amazed at the works of computer art that you folks have shared with the world. I've been toying with a few concepts that I have "borrowed" from you kind modders so I can spruce up my own Fractal R4 Define and AquaComputer watercooling gear. Its been nearly 7 years since I was in big with this community and I'm happy to be back. =)
I may need a little help and some further ideas while I work on this project over the next few months. I have a little one on the way @ the end of July and I'm afraid I wont be able to find much time after that.
Most everything I've done so far is kind of a rough draft (mocked up with foam board) while I decide exactly what I want to do. Criticisms are very welcomed.
Hardware specs... Intel i7 3820, 4x4gb Corsair Vengeance, Asus Rampage IV Formula, EVGA 670 for the win, Samsung 128 SSD (mounted on backside of motherboard)
Im currently running a single Airplex Evo 240 radiator with a pair of Gentle Typhoons AP-30's running @ ~2000-2500rpm, Aquaero 5 LT, Aquastream XT, Original (Aluminum) Aquatube g1/8, Kryos HF & AquagraFX 680.
This was my idea of a watercooled "budget performance" gaming rig...
Anyways, the current (single) radiator is mounted in the front of the chassis, in the location that Fractal designed it for. What I want to do... I'm trying to source another Airplex Evo 240 so I can vertically mount the pair in a cross flow from side to side. In other words, the main side panel radiator acts as the intake while the radiator mounted next to the motherboard tray acts the the exhaust. Setting up the mount for this setup should be quite easy since I can use the already existing drive bays for support.
sntmods is offline   Reply With Quote
Old 29th Jan 2013, 08:00   #2
Muerlin
What's a Dremel?
Muerlin's Avatar
Muerlin has yet to learn the way of the DremelMuerlin has yet to learn the way of the Dremel
CPU block to reservoir could use an angled adapter (60 maybe?). The GPU Block to CPU Block looks okay. It might yutz up your look, but maybe just change them all? : P
Muerlin is offline   Reply With Quote
Old 29th Jan 2013, 11:38   #3
Vetalar
*learning english*
Vetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the Dremel
how this push-in fittings performs? how they work if... erm... _someone_ pull tubing hard? i plan to use same fittings (already bought) and very interested in it's "performance"
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is online now   Reply With Quote
Old 29th Jan 2013, 12:27   #4
dream1
Multimodder
dream1's Avatar
dream1 has yet to learn the way of the Dremel
Welcome back
dream1 is offline   Reply With Quote
Old 30th Jan 2013, 08:56   #5
sntmods
Minimodder
The push in fittings are awesome, I've pulled on them pretty hard and they still hold on. I've worked with them for years and I have never been let down.
I do need to get some G1/4 90 degree ones to get going on the side mounted radiator portion of the project.
Old 30th Jan 2013, 09:23   #6
Vetalar
*learning english*
[ot] i've bought 4 g1/4 for 12 мм OD tubing (pa12 rilsan)... now i have to make 120 mm ark (cpu to gpu) with tubing with min bending radius 85mm [/ot]
__________________
20 have a sleep
30 goto 10
Old 31st Jan 2013, 02:29   #7
sntmods
Minimodder
^ unless Im reading your words incorrectly, it seems like you should be able to make that arch.
Okay, so I need some help rigging up a work bench or use an available dremel tool attachment that can accurately cut/sand an 1/8" plastic sheet at a 45 degree angle at the ends. My goal is to create a beveled edge to only have one visible seam when 2 plastic parts meet. Holding steady with just my hands wont work as Im not a surgeon, this has to be a precise as possible. Unfortunately my local TAP plastic shop dont do bevel cuts at anything less than 1/4". =(
Any ideas?
Old 31st Jan 2013, 05:16   #8
Vetalar
*learning english*
well one can attach dremel to smth angled (45*) and advance plastic sheets under cutting weel
like this
and for tubing radius 85mm means _diameter_ 170mm and minimum "arc" is 170mm... and i can clearly see sand, boiling water and ice in my nearest future
__________________
20 have a sleep
30 goto 10
Old 31st Jan 2013, 09:13   #9
Muerlin
What's a Dremel?
Muerlin's Avatar
I love that, Vet.
That will work, but you will need a guide tacked on the board to keep the sheet from wiggling.
You could flip the horizontal orientation of the dremel if you have a contouring bit, but cutting would be my preferred choice, especially with a Tablesaw:
http://youtu.be/ccQI9urBkXQ
Note: Turning a wood saw in reverse can work, but it mostly just melts acrylic, so if you go the table saw route, use a proper blade.
Old 7th Feb 2013, 08:22   #10
sntmods
Minimodder
Minor update... I traded out the mocked up foam board for the high gloss white acrylic. I had a fun time using my newish Dremel Trio to notch out all the little slots to clear the rivets and whatnot in the steel chassis. I cant really move on from here till I get some Plug-in 90 degree fittings and I cant find anybody here in the US that carries them.
Old 14th Feb 2013, 07:04   #11
sntmods
Minimodder
Can anybody offer any suggestions for a design for a male to male 3 pin fan header connection that passes through a 1/4 sheet of acrylic?
male fan header - 1/4" acrylic - male fan header
Old 14th Feb 2013, 07:27   #12
Elenos
Minimodder
Elenos has yet to learn the way of the Dremel
Wow please make those images smaller!! Thought my screen had exploded!
Elenos is offline   Reply With Quote
Old 19th Feb 2013, 08:20   #13
sntmods
Minimodder
Okay, for me this is a big update.
I cleaned up the tubing which improved the flow a bit,
got the radiator cooling box properly assembled (glued together and bolted in),
2 x Corsair SP120 High Performance Fans on the intake side
2 x Gentle Typhoon AP-30 on the exhaust side
built, glued and set in place the psu cover
I still needs to build the removable cover between the psu cover and the radiator box. This will likely be a 2 piece deal to surround the tubing running into the pump and flow sensor.
I'm still trying to source another Airplex Evo 240 to improve those delta T's =)
Also, please don't mind the wiring mess, that's like the last thing I'll get to... eventually...
Old 19th Feb 2013, 16:51   #14
kelmannen
Supermodder
kelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremel
did you find those 90degrees 1/4" 12mm? to bad you're not in sweden, i've could have sold those to you :P
dunno which companies you have around your location, but anyone working with industrial pneumatic should have loads of those! (big filtration suppliers, like alstom and the likes) and most industrial plumbers to, they are very commonly used for air cylinders and pressure contro in industrial plants.l
__________________
Works as a tool retailer, glad if i can help someone with tool questions!
Hopes that i someday completes my first scratchbuild...
kelmannen is offline   Reply With Quote
Old 19th Feb 2013, 20:31   #15
sntmods
Minimodder
No luck finding them here in the US. Im willing to have them shipped in but I dont want to spend more than $10 on shipping for such small items. I even asked Aquatuning if they could just throw a few in a padded media packet but that was a no go. Normal shipping from them was too much. =(
The problem is that G1/4 and G1/8 is not in use in industry (from what I can see) in the US, we just have the American Standards. I've got away with using the straight fittings for now by swapping them around and only using the single radiator. Once I find that second Airplex Im going to have to find something cause I just wont have the room anymore inside the radiator cooling box.
Old 21st Feb 2013, 08:09   #16
sntmods
Minimodder
I should have taken more pictures but I do most of my work at night when its dark... with a 1000 watt work light.
Anyways, I decided to bore out the smaller 3.3mm ID hole in my AquaComputer flow sensor to match the outgoing side's 5.6mm. I just used a regular metal cutting bit and it did the job fine while clamped down.
When I re-installed the flow sensor I immediately saw a 10l/hour increase in the flow. Not bad for a few minutes work.
Old 25th Feb 2013, 10:44   #17
sntmods
Minimodder
Just an updated glamour shot. Im test fitting the pump cover (mid plate) so I can decide what adjustments I need to make.
Old 27th Feb 2013, 06:14   #18
sntmods
Minimodder
Got the pump cover midplate finished (for now). I used two 1/8 acrylic sheets sandwiched and glued together. It just drops into place and allows the front panel connectors and usb to pass through.
Old 27th Feb 2013, 07:45   #19
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Lovely work snt loving the push fittings
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 27th Feb 2013, 08:28   #20
Korvus
May contain traces of sanity.
Korvus's Avatar
Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!
Looking very tidy, some nice ideas too .. might have to borrow a few for my case
__________________
Current Rig: Intel 3570K | Asus Z77 Sabertooth | 8GB Corsair Vengeance 1600 RAM | Crucial M4 120GB SSD | 2TB Seagate Barracuda 7200 | EVGA GTX680 SC Signature Editon | Asus Xonar D2X | Corsair HX850W | Fractal Design Define XL R2 (Black)
Cooled by: Aquaero 5 Pro | Alphacool NexXxos XP3 | Alphacool Monsta 240 | Laing D5
Current build
Korvus is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
