Reply
Thread Tools View Mode
Old 27th Feb 2013, 08:42   #21
sntmods
Minimodder
sntmods has yet to learn the way of the Dremelsntmods has yet to learn the way of the Dremel
I cleaned up the wiring in the back
sntmods is offline   Reply With Quote
Old 27th Feb 2013, 12:47   #22
Hukkel
Multimodder
Hukkel has yet to learn the way of the DremelHukkel has yet to learn the way of the DremelHukkel has yet to learn the way of the Dremel
Nice build. But you, sir, need the power of cable sleeving
Hukkel is online now   Reply With Quote
Old 27th Feb 2013, 22:23   #23
sntmods
Minimodder
I've been wanting to order from Nils & MDPC but the timezone difference is getting the best of me. I'll get around to it someday Im sure, I just want to finish the exterior design first...
The top of the case was the first thing I worked on back in December and it never quite had the look that I wanted. I've been looking for ideas ever since.
Old 7th Mar 2013, 05:48   #24
sntmods
Minimodder
I decided to make a fan grill for the exhaust ports. It matches the exterior front panel for the case. I used an old AquaComputer Airplex radiator grill as a template. =) I think it turned out pretty nice.
I wanted to test fit it to make sure it looked right without putting in another 2 hours worth of work with the dremel and file. The sun went down anyways, so I'll have to finish it off another day.
Old 7th Mar 2013, 12:38   #25
Azariel
Multimodder
Azariel's Avatar
Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!
I applaud your patience Looking quite good I think!
Azariel is offline   Reply With Quote
Old 7th Mar 2013, 13:12   #26
Korvus
May contain traces of sanity.
Korvus's Avatar
Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!Korvus - it's over 9000!!!!!!!!1!1!1!!!
Looking good Where do you get your acrylic from?
__________________
Current Rig: Intel 3570K | Asus Z77 Sabertooth | 8GB Corsair Vengeance 1600 RAM | Crucial M4 120GB SSD | 2TB Seagate Barracuda 7200 | EVGA GTX680 SC Signature Editon | Asus Xonar D2X | Corsair HX850W | Fractal Design Define XL R2 (Black)
Cooled by: Aquaero 5 Pro | Alphacool NexXxos XP3 | Alphacool Monsta 240 | Laing D5
Current build
Korvus is offline   Reply With Quote
Old 7th Mar 2013, 21:30   #27
sntmods
Minimodder
We have some local stores called TAP Plastics out here in California, lots of stuff there... =)
Old 16th Mar 2013, 07:04   #28
sntmods
Minimodder
Im going to do a little painting on the ring for the Gentle Typhoon AP-30 to give it a more pleasing appearance, a corsair look alike. =)
And I screwed up the grill I was making by stressing the slots while I was shaping them with the cutting tool on the dremel. At this point I could try again and waste a whole day or just design one to be laser cut.
Old 17th Mar 2013, 04:55   #29
sntmods
Minimodder
Old 25th Mar 2013, 10:00   #30
sntmods
Minimodder
Little update March 25
So, after a few months of searching and being a little unlucky in sourcing a second Airplex Evo 240 I just decided it was time for an upgrade to two Alphacool Nexxxos XT45 240's (Full Copper). I replaced the previous single 240 radiator with a total of 480mm of cooling real estate and I am very pleased with the end results.
I used to have a Delta T resting @ about 12.4 degrees celcius while running the GT AP-30s @ 2500rpm, the Corsairs @ 2100. This was recorded while running Prime 95's Max Heat test with 8 workers & Heaven DX11 for the GPU. i7-3820 running @ 4.3GHz, an almost nothing overclock for the GTX670 cheesecake.
With the pair of Nexxxos I am resting @ 4.1 degrees, everything else being the same except the GT AP-30s which are now running @ only 2,000rpm, much quieter!
I am a little disappointed since the shipment from Germany didnt include the 90 degree fittings that I ordered and would have cleaned up the tubing in the radiator box.
Old 25th Mar 2013, 11:06   #31
jeckulz
Supermodder
jeckulz's Avatar
jeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremel
NICE WORK!!!
Lovely stuff
__________________
Intel i5 2500k @ 4.5Ghz / Dark Rock Adv. MSI Z68A-GD55
Asus Radeon HD6850 Direct CU @902Mhz 8gb (4x2) Corsair Vengance LP 1600Mhz
OCZ Vertex 4 128gb Seagate 320gb & Samsung 1tb
Coolermaster 600w Silent Pro Modded Lian Li PC-0700
jeckulz is offline   Reply With Quote
Old 29th Mar 2013, 04:16   #32
sntmods
Minimodder
The fan grill is done for now. If I try this again I'm definitely working with 1/4" acrylic rather than 1/8", but I'll use this for now.
More on this later, have to find a way to mount this as the side panel...
Old 29th Mar 2013, 04:16   #33
sntmods
Minimodder
Okay, its been a while since I mounted the second radiator and cleaned up the tubing. Thank you Aquatuning for getting those 90 degree fittings out to me. =)
Old 25th Apr 2013, 00:00   #34
sntmods
Minimodder
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
