Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 28th Jan 2013, 10:26   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
SanDisk Ultra Plus 256GB review
http://www.bit-tech.net/hardware/sto...256gb-review/1
brumgrunt is offline   Reply With Quote
Old 28th Jan 2013, 10:41   #2
barrkel
Multimodder
barrkel has yet to learn the way of the Dremel
The most interesting thing in these results, to my eyes, is the OCZ Vector's results in BootRacer. They've probably been in past reviews, but this is the first time I saw them.
Single-task benchmarks like sequential and random read and write clearly don't model the boot process well. That's a mix of random and sequential reads and writes. The drives are black boxes containing cache and logic; probe them with such simplistic tests, and it's reasonably easy for the logic to detect the test, and optimize cache for that use case. Assuming the logic can do this, all the benchmarks are testing then is the raw speed of the underlying hardware. The smartness of the logic itself is not being tested.
For example, in a read benchmark, no cache need be reserved for buffering writes; and vice versa.
But real-world use cases have a mixed set of reads and writes, of varying sizes. That's where the real test of the logic comes in. The logic needs to make hard decisions about how much cache to keep spare, and which to spend on optimizing reads vs writes. And it's likely that one drive which is best for boot times won't be as good as the best drive for launching apps, and that won't be the best one for a database cache.
We need better benchmarks. These benchmarks are too easy to game, and risk rewarding market to inferior products.
barrkel is offline   Reply With Quote
Old 28th Jan 2013, 11:10   #3
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
A prime SSD for modding and use in tiny builds methinks!
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 28th Jan 2013, 13:45   #4
Blackshark
Multimodder
Blackshark has yet to learn the way of the Dremel
Well, that and the photo showing that a 250Gb SSD fits in only a third the space of a standard 2.5 inch drive area!
Blackshark is offline   Reply With Quote
Old 28th Jan 2013, 14:51   #5
[USRF]Obiwan
I *am* a Dremel
[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.
So much money for a 3cm x 6cm strip of electronics inside a large empty box....
__________________
[USRF]Obiwan is offline   Reply With Quote
Old 29th Jan 2013, 19:40   #6
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
Originally Posted by [USRF
Obiwan]So much money for a 3cm x 6cm strip of electronics inside a large empty box....
And yet it's competitvely priced. I remember when the first round of SSDs came out in 2008/9 and they were worth close to their weight in gold. Mental, but then look at CPUs! almost nothing to them, but some are worth Thousands. its what it can do you for in the that you pay for, not what it is.
Baz is offline   Reply With Quote
Old 30th Jan 2013, 00:12   #7
MSHunter
Mod Master
MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.
Makes you wonder why mSATA is so much slower....
That and it would be cool if you could plug this guy directly too your motherboard.
__________________
Caved and bought a Gigabyte P35x V3 gaming laptop.
ex-PC: Silverstone TJ08B-E, 2500K, Corsair H80, 256 GB Samsung 830,GENE-Z , Corsair V. LP 16GB, Gigabyte 1.5GB GTX 580 Super Overclock. U2711
PC Audio: AKG 271 mk II + Samson Go mic. + Asus Xonar D2X
Amp: DENON PMA510AE, Speakers: TANNOY MERCURY F1
MSHunter is offline   Reply With Quote
Old 30th Jan 2013, 04:05   #8
toolio20
Modder
toolio20 has yet to learn the way of the Dremel
Whoa whoa whoa, wait...what TRIM "command" is the author referring to on the second page? I thought TRIM ran somewhat automatically, cued up when files are permanently deleted...some clarification would be greatly appreciated!
toolio20 is offline   Reply With Quote
Old 30th Jan 2013, 08:11   #9
haggisathome
Supermodder
haggisathome's Avatar
haggisathome has yet to learn the way of the Dremelhaggisathome has yet to learn the way of the Dremelhaggisathome has yet to learn the way of the Dremelhaggisathome has yet to learn the way of the Dremel
thats what i was thinking , for what it is its tiny ... runs off to open up my 60 gig ssd to see if its the same
haggisathome is offline   Reply With Quote
Old 30th Jan 2013, 08:37   #10
Harlequin
I Mod, Therefore I Own
Harlequin's Avatar
Harlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming Saiyan
you can force windows to run TRIM, just as using SSDTweaker can disable it -which is exactly what was written on page 2
__________________
They shall grow not old, as we that are left grow old:
Age shall not weary them, nor the years contemn.
At the going down of the sun and in the morning
We will remember them
Harlequin is offline   Reply With Quote
Old 31st Jan 2013, 19:00   #11
Acanuck
Modder
Acanuck has yet to learn the way of the Dremel
Not to be a grammar Nazi or anything, but the sentence:
"first allowing five restarts to allow Windows 7 to get it's caching together"
under the BootRacer section, should read
"first allowing five restarts to allow Windows 7 to get its caching together."
Otherwise, sound review. Glad bit-tech take benchmarking so seriously.
Acanuck is offline   Reply With Quote
Old 31st Jan 2013, 19:44   #12
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
Good spot! Fixed now, cheers.
Dogbert666 is offline   Reply With Quote
Old 1st Feb 2013, 00:52   #13
toolio20
Modder
Ahhhhh, page 2...yessss, I see now. I jumped straight to the "TRIM" section on the summary page. Thanks for the asked-for clarification!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
