Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 28th Jan 2013, 10:20   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!
Tranquil PC launches passive cases for Intel's NUC
All-aluminium design provides silent operation.
http://www.bit-tech.net/news/hardwar...tranquil-nuc/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter
bit-tech news correspondent, Custom PC columnist
I'm a filthy freelancer! Hire me!
Gareth Halfacree is online now   Reply With Quote
Old 28th Jan 2013, 15:45   #2
Sc0rian
Here comes the farmer
Sc0rian's Avatar
Sc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run Crysis
love fanlesstech, found the site through bit-tech, now watch it quite often.
This case looks awesome. Would like dual nic though!
__________________
\o/
Sc0rian is offline   Reply With Quote
Old 28th Jan 2013, 15:46   #3
faugusztin
I *am* the guy with two left hands
faugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for president
Complain to Intel. This is just a case .
__________________
Cerberus Core i7-2600K Asus P8Z77-I Deluxe GSkill RipjawsX 2x8GB DDR3-1600CL9 watercooled EVGA GTX670 Samsung 830 256GB Bitfenix Prodigy Seasonic X-460 Windows 8 Pro
Prometheus Xeon E3-1235 Asus P8B WS GSkill RipjawsX 2x4GB DDR3-1333CL7+2x8GB DDR3-1333CL9 Coolink Corator DS Force 3 240GB+4xWD30EFRX+2xWD20EARS+6xWD20EARX Nanoxia DS1 Seasonic X-460 Ubuntu 12.04
faugusztin is offline   Reply With Quote
Old 28th Jan 2013, 17:04   #4
jrs77
theorycrafting
jrs77's Avatar
jrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for president
Alltogether with the intel-board, some RAM and the mSATA SSD you're looking at a €600 fansless miniPC.
Not sure if woth it, but very nice.
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB]
jrs77 is offline   Reply With Quote
Old 28th Jan 2013, 17:20   #5
faugusztin
Well, Mac mini with the same CPU is 629€, so the price still wouldn't be that bad.
__________________
Old 28th Jan 2013, 21:57   #6
Combatus
Custom PC/bit-tech modding sections
Combatus's Avatar
Combatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for president
I'm very tempted by the D33217GKE - £200 for a Core i3 and super-tiny motherboard isn't bad. £99 for a case seems steep, but I suppose the Akasa Enimga cost over £60 so passive technology included isn't bad.
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES! | Mod of the Month March 2013 is here! Vote now!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 28th Jan 2013, 22:27   #7
faugusztin
But on other side the version with their own case is cheaper :
http://www.scan.co.uk/products/intel...r3-2x-hdmi-g-b
__________________
Old 29th Jan 2013, 10:19   #8
snootyjim
Ineptimodder
snootyjim has yet to learn the way of the Dremel
Of course it is.
Tranquil make virtually all of their cases now from solid aluminium, and basically turn the entire case into a massive heatsink.
Comparing it to a few bits of plastic glued together is pointless.
snootyjim is offline   Reply With Quote
Old 29th Jan 2013, 10:54   #9
FullThrottleRic
Minimodder
FullThrottleRic has yet to learn the way of the Dremel
The standard NUC chassis is actually a really nice bit of kit, the sides are (from what I can tell) aluminium and there's a steel inner frame too. It's only the top that's the shiny plastic to let the wifi in and out, overall it feels really solid and well made.
Also at idle the standard cooler is properly quiet, and when it does turn the fan up it's not really that loud
FullThrottleRic is offline   Reply With Quote
Old 29th Jan 2013, 11:19   #10
faugusztin
Of course it is.
I meant that as a reaction to Combatus and him thinking about the separate board and buying Akasa Enigma - which is IMO pointless. Either get the NUC in the original case, or the board & this Tranquil case.
__________________
Reply
Tags
aluminium, home theatre pc, htpc, intel, media centre, next unit of computing, nuc, passive cooling, tranquil nuc, tranquil pc, vesa mount
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
