Reply
Thread Tools View Mode
Old 29th Jan 2013, 11:53   #1
jcb121
Modder
jcb121 has yet to learn the way of the Dremel
Rasberry Pi Competition: The J box
So, Starting a project just to motivate myself!
I'm currently in the stages of waiting until payday to buy stuff! (thursday!)
I plan to make one of the best Xmbc boxes going.
It's going to have a Wifi, 16gb on the usb, 16gb sd Card, Bluetooth, IR remote and an external usb.
I'm toying with the idea of de-soldering the RCA, Audio and GPIO to make more space in my tiny case.
I already have my Pi and have been playing around with it.
though I do need a tad bit of advice. I need to relocate the power connection, so I was going to hack a micro usb cable to a panel mount connection.
but I'm struggling to find one small enough, a DC 5.5mm jack is too big and long for my planned case.
and ideas guys?
current progress: 1%
jcb121 is online now   Reply With Quote
Old 29th Jan 2013, 14:01   #2
jrs77
theorycrafting
jrs77's Avatar
jrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for president
Desoldering the jacks would actually violate the rules of the contest, as the case needs to have all the ports accessible.
Anyways, nice to see the first contestant
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB]
jrs77 is offline   Reply With Quote
Old 29th Jan 2013, 18:31   #3
jcb121
Modder
well I'm not going to be able to enter then :l
i'll just make it and enjoy it then!
Old 29th Jan 2013, 22:59   #4
Combatus
Custom PC/bit-tech modding sections
Combatus's Avatar
Combatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for president
Hi jcb121. Unfortunately as jrs77 says, the original ports need to be usable - this is to ensure that everyone's working to a similar design for the competition. Is there any way we can persuade you to enlarge the design a little to fit the ports?
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES! | Mod of the Month March 2013 is here! Vote now!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 30th Jan 2013, 18:26   #5
legoman
breaker of things
legoman's Avatar
legoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for president
nothing wrong with extending the jacks though My Pi has been happily running in a Cooks match box for months now I am working on a proper enclosure for it but sadly my plans are some what larger though i may have a dabble.
But yes nothing wrong with extending the ports and dont forget you dont have to have that USB hub as a sandwich layer either you have a fair amount of space to play with there.
__________________
AMD Phenom X6 1605T @ 4.5Ghz |Corsair H80 |Gigbyte970A-UD3 | 2X4 GB Kingston HyperX Beast | ASUS AMD 6950 2GB DirectCU II | Corsair HX750 | Liteon DVD RW | Samsung HD103SJ 1Tb | Crucial M4 SSD 64GB | Phobya FanMax 6 | Edimax EW-7612Pln | Coolermaster Storm Trooper | Win 7 Pro 64it | Roccat ARVO | Logitech G500 | Bamboo 1 | Samsung SyncMaster 2033SW
legoman is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
