Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 29th Jan 2013, 20:21   #1
Madness_3d
Bit-Tech/Asus OC Winner
Madness_3d's Avatar
Madness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for presidentMadness_3d should be considered for president
Mechanical Keyboards. I Don't Get It.
Okay so I can appreciate some good hardware, I can ever appreciate some good peripherals, got my nice Display, Mouse, Speakers etc, But I just don't get the Mechanical Keyboard Mania! There's a whole thread devoted to it and its huge and it just doesn't make sense!
Is it one of these things that you have to try it to appreciate it?
What's the point!?!?!
Is it really any better?
And what is the obsession with swapping keys? Are they even all the same size?
Someone please enlighten me, there's another one of these crazy keyboards on the front page of bit-tech today and I just feel like a noob when I see the price tag! It's not even backlit for gods sake!
__________________
XFXScorpio911INTEL i7 3770k @ 4.5Ghz SLI GTX 480 1536MB ASUS MAXIMUS V FORMULA16GB CORSAIR DDR3 1600 9-9-9-24 1TCORSAIR HYDRO H50CORSAIR Force 3 120GB WINDOWS 7 HP 64bitMusings On The Technical WorldSteam
Madness_3d is offline   Reply With Quote
Old 29th Jan 2013, 20:27   #2
Darkwisdom
Level 99 Retro Nerd
Darkwisdom's Avatar
Darkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming Saiyan
Yeah, it is one of those things you have to try to appreciate. The feel of a mechanical cherry key is so much more satisfying to use than a cheap membrane keyboard. The click of a mechanical key is just so much easier and it's like you know that it's been pressed.
Using Different keycaps is a strange hobby from my point of view as well. I use a set of completely black keys to go with my black theme. They all do fit, because all Cherry keys have the same connector for the keys. There are exceptions, but most of the time they'll fit.
Mechanical keyboards are expensive and a Select few will truly appreciate them, but once you've bought one; you'll probably wonder how you computed without one. It's like you're using a keyboard most of the time anyway, and you have a nice gaming mouse so why cheap out on the keyboard too?
__________________
Main Rig: i3 3220 ~ GTX 970 Strix ~ 8GB Vengeance Ram ~ EVGA Supernova G2 750W ~ P8H77-m le ~ Samsung 830 128GB SSD ~ Steelseries GCv2 ~ Razer imperator ~
Darkwisdom is offline   Reply With Quote
Old 29th Jan 2013, 20:29   #3
longweight
Possibly Longbeard.
longweight's Avatar
longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.
Try it, there is no point talking about it until you have tried one.
longweight is offline   Reply With Quote
Old 29th Jan 2013, 20:29   #4
Darkwisdom
Level 99 Retro Nerd
Darkwisdom's Avatar
The Master has spoken =p
__________________
Old 29th Jan 2013, 20:31   #5
longweight
Possibly Longbeard.
longweight's Avatar
Oh also try Topre, the gentleman's choice
Old 29th Jan 2013, 20:32   #6
Madness_3d
Madness_3d's Avatar
Anywhere you know demoing them? :P
__________________
Old 29th Jan 2013, 20:34   #7
longweight
Possibly Longbeard.
longweight's Avatar
Not really! I have a set of tester switches that I can send to you if you would like to try the switches?
http://forums.bit-tech.net/showthread.php?t=242810
Old 29th Jan 2013, 20:35   #8
fuus
Rocking All Year Christmas
fuus's Avatar
fuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyan
Unfortunately very limited in the UK... There may well be one or two shops in London with cheaper models on show.
__________________
i5 3570k :: EVGA GTX 670 :: Z77X D3H :: 8GB RAM :: Filco Browns :: 3 x Dell U2312HM :: 256GB 840 Pro
Phillips X1's :: Schiit Vali :: Schiit Modi :: Blue Snowball
fuus is offline   Reply With Quote
Old 29th Jan 2013, 20:36   #9
Margo Baggins
I'm good at Soldering
Moderator
Margo Baggins's Avatar
Margo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming Saiyan
rubber domes are a bit like pressing a sponge, sort of sloppy response, and you have to push it all the way down. Mechanical keyboards each key has a spring, acts independently and provides it's own feedback, and then the various switches all have their own feel to them. Once you spend a couple of hours typing on a mechanical keyboard you will get it.
Key caps are good as they don't really depreciate all that much if you buy good ones, obviously you couldn't sell them to just anyone, but of all the hobbies I have ever pumped money into, I think If I was to up and sell everything my keyboards would be the only thing that returned nearly what I have spent out.
__________________
My Imgur
i7 6700k - 8GB - GTX 1070
keyboards.
Margo Baggins is offline   Reply With Quote
Old 29th Jan 2013, 20:37   #10
Cei
pew pew pew
Cei's Avatar
Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.
Meh, I don't get the craze either. I just don't get on with mechanicals.
__________________
Join the BitSec organisation in Star Citizen! | Fleet Roster
i7 3770K | Asus RoG Maximus V Gene | 16GB 1866Mhz Vengeance | Crucial M4 256 & Samsung EVO 500 | Corsair H105 | Corsair AX860 | GTX 1080 FE | Air 240
i5 4670K | Asus RoG Maximus VI Impact | 8GB 1866Mhz Vengeance LP | Samsung 840 EVO 128GB | Noctua NH-U9B SE2 | GTX 770 SC 2GB | EVGA Hadron Air
Cei is offline   Reply With Quote
Old 29th Jan 2013, 20:38   #11
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
Get yourself a "cheap" Steelseries 6GV2 and test a mechanical keyboard for yourself.
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 29th Jan 2013, 20:44   #12
The_Crapman
MD of M.Z.A. Inc and Weasel Pimp
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
Last time i visited a Currys it was one with a PC TurdWorld section which had a Corsair K60 and a Razor keyboard with cherry switches on display to have a bash with.
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 29th Jan 2013, 21:09   #13
mikemorton
Hypermodder
mikemorton has yet to learn the way of the Dremelmikemorton has yet to learn the way of the Dremelmikemorton has yet to learn the way of the Dremel
I have a Mionix at home and a QPad at work, and I love them.
You can caress the keys as lightly as a lover, or bash them like a boxer and they will respond precisely each time.
Mechanical keyboards are a bit like dishwashers.
If you don't have one, you don't think you need one.
But if you do get one, you'll wonder how you ever did without.
mikemorton is offline   Reply With Quote
Old 29th Jan 2013, 21:09   #14
hamza_tm
I Mod, Therefore I Own
hamza_tm's Avatar
hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.
Feels better, and it's a hobby collecting keys if you want it to be. Some people collect stamps.
__________________
Whisper quiet gaming: 2500k@4.4Ghz | P67a-GD53 | Vengeance 8GB 1600Mhz | Force3 120GB | M4 256GB | WD15EARS 1.5TB (Icy Box USB 3.0) | BenQ XL2411T 144Hz | Asus Xonar Xense | Corsair 550D | GTX680
CM Storm Quickfire Rapid MX Brown (White Filco caps) | Zowie AM | Sennheiser PC360 | Razer Sphex
hamza_tm is offline   Reply With Quote
Old 29th Jan 2013, 22:20   #15
rollo
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
Useful for typists.
Not so useful in games.
Depending on the key type you get they will require too much force to be useful in multi touch games.
Bf3 online is probably were they are at there worst.
Typing a word document at there best.
All depends on the switch type though, some are better for gamers and some are better for typists.
I have a typist version and a normal gaming keyboard for when i game just works out easier.
rollo is offline   Reply With Quote
Old 29th Jan 2013, 23:13   #16
TheDodoKiller
Supermodder
TheDodoKiller's Avatar
TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.
I have to spend time at college using a crap dome keyboard. I come home, and typing on my keyboard at home is like someone gave me 20 cans of redbull.
so precise, you'll never miss a key with a mechanical.
If you can relate to it, think of a dome keyboard as a haribo cola bottle. it squidges, and gives you then knowledge that you have pressed it, albeit not very nicely.
A mechanical is more like crunching a crisp with your hand. you know when it happens, you feel when it happens- it's a very positive experience. Although you don't break a mech keyboard when you use it.
To me, the difference is more that the mechanical feels like an on off switch, and the rubber domes feel analogue.
__________________
- AMD 1090T OC'd at 3.6 Ghz - Asus Crosshair IV Formula - Reference Asus 6950/70 - Silverstone FT02 B-W - Kingston HyperX 3K 128GB SSD - Samsung F3 1TB - Kingston HyperX 1600 Ram 4GB - Coolermaster V8 -
TheDodoKiller is offline   Reply With Quote
Old 29th Jan 2013, 23:33   #17
RedFlames
...is a figment of your imagination
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
I had a mechanical kb... hated typing on it and it wasn't long before I broke it...
Though my typing is equally bad on membrane KBs
however like mice and speakers/headphones, keyboards are a subjective thing
__________________
Why are you still reading this? The post is over. Go Home.
RedFlames is online now   Reply With Quote
Old 30th Jan 2013, 08:30   #18
hamza_tm
hamza_tm's Avatar
Originally Posted by rollo View Post
Useful for typists.
To clarify this statement, there is only one mainstream switch type (out of 5 or so) for which this may be true, and even then it's preference.
Sorry I have this thing against making generalizations from your own specific (not very representative) observations, no offence meant!
__________________
Old 30th Jan 2013, 08:44   #19
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
If you like nice peripherals, have a look at them.
Personally I was interested as soon as I heard about them, but once I pushed that first switch... Oh my. I'm an utter convert now - there's no way I'll suffer a rubber-dome again. No way.
rollo: I can see what you're getting at, but with the various switch choices available there's something for everyone. A board with reds or blacks are well respected for gaming. Blues aren't ideal, I'll grant you, but browns work very well too.
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 30th Jan 2013, 09:09   #20
longweight
Possibly Longbeard.
longweight's Avatar
Useful for typists.
This is not true at all.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
