#1 |
I *am* a Dremel
Raspberry Pi Competition: Lego Case UPDATE: no more wheels :(
Ok, so after seeing everyones designs, I realised I needed a case for my pi, other than the box it came in
. After thinking about trying to make something with wood/acrylic I realised I didn't have a clue how to do it. So I found the big box of lego and got started. One of the main problems I had was managing to fit the Pi in with the random pieces of lego I had at my disposal. Here are some photos of the main idea, which just needs neatening up a bit. ![]() ![]() ![]() ![]() ![]() ![]() One of the main concerns I have is that I might not have left room for it to breathe, but I'll test that tomorrow. And thats about it so far, suggestions welcome
#2 |
Minimodder
nice little build !
i would suggest: useing some of the thinner lego pieces to close it in a bit more using smooth top lego pieces in some places ( looks nicer ) having some really small fan for cooling using more of the lego technical pieces with holes in them for ventilaition |
#3 | |
I *am* a Dremel
![]() This is mainly just a prototype thing, in order to judge sizing and stuff. The problem Ive got is that the only lego Ive got is the stuff that I had when I was young (hence the wheels), and most of the blocks I have are really fat. However I did see some good thin pieces with ventilation holes in while I was rummaging around so Ill give that a go. |
#4 |
MD of Mutant Zombie Armies Inc
Put a motor on it!
__________________
Project: RAt MoD:CPU:i5 3570K, Motherboard:ASUS Maximus 5 Gene, GPU:Gainward GTX 670 Phantom, Cooler:Modded Antec Kuhler 620, RAM:4GB 1600MHz G.Skill RipjawsX CL6, HDD: WD Raptor 150GB , PSU: Enermax Revolution 1050W Case: Antec P182, How to Get a FREE (sort of) Hard Drive and Other Small Parts. |
#5 |
↓ Don't trust that face!
We demand proper placement of the duck eyes!
__________________
#6 |
I *am* a Dremel
Haha, Ive had a bit of a tidy up today, and Im getting closer to an all red colour scheme.
I had a look at putting motors on the wheels, but I think its probably beyond my practical and programming skills. That and the fact that the case would have to be a fair bit bigger to house the additional power supply, motors and breakout box. |
#7 |
I *am* a Dremel
Update: Had the baby cousin round at the weekend so finally made some progress on case
![]() However, due to its use in the house as a media center the wheels weren't really working (it kept rolling away) so I got rid of them. However, its not all bad news , I managed to find enough ventilation pieces for one side, and some more red bricks for a bit of colour co-ordination.Here are the new pics: ![]() ![]() ![]() ![]() ![]() Current OS: Raspbmc with Frodo |
#8 |
llama eats dremel
Maybe put the weels on a moving hinge, so you can 'park' it, with the weels off the ground, but still ride with it if the situation warrants it (for example a baby cousin). You shouldn't worry too much about the temperatures of the pi. That thing never even gets hot. Only warm. Lego and Pi can handle 'warm'.
I'm a bit sad to see the duck-eyes gone, too. And can't you make the holes in the sides a bit smaller? or does the lego not permit that? It would make the case a bit sleeker, no? Anyhow, mod on!
__________________
my English may not be as good as I think it is... |
#9 | |
I *am* a Dremel
The port holes are about as wide as they could be as I end up swapping the cables/sd card round a fair bit, so I need a bit of room to access them. However, when I get more settled with the pi in terms of projects, ill maybe close up the gaps a bit. I like the idea of parking it, Ill just have to find something in the big box of lego for the job. |
| Thread Tools | |
| View Mode | |
