#1 |
Multimodder
Rasberry Pi Competition: Bulky - Completed 15.3.2013
Hey!
Here we go. my first ever case build. ![]() Decided use 5mm acrylic since i had sheet lying in the corner. going for a bulky look. and it will be open from the sides, (will be leavin the option for side panels), but now for ventilation they stay gone. so here is the basic layout drawing. ok got done with the jigsawing. there are two pieces on top of each other. The future legs and spacers holding them together for now. that is it for now. i am waiting for my unc 6-32 tap to arrive so i can tap the "mobo" mounting holes. Till next time fellows. Last edited by tekonivel; 15th Mar 2013 at 18:31. Reason: tittle update |
#2 |
*learning english*
am i only one who cant see pix?
__________________
10 re-plan "SuperBestBuild Of My Dream" 20 have a sleep 30 goto 10 |
#3 |
Minimodder
#4 |
Multimodder
nice to see some finnish modders! good luck in the competition!
__________________
Inverted 600T - OCN Mod of the month July 2012 CM Test Bench V2 - Cooler master mod competition 3rd prize Rig of The month December - Guru3D Nice articles of the test bench: Here and here |
#5 |
Multimodder
#6 |
↓ Don't trust that face!
Oh, dear! Now I will have to re-think my entry.
Looks good so far.
__________________
#7 |
Multimodder
#8 |
Multimodder
Ok. to keep you updated.
I have had really hard time trying to get the tap drill. finaly got one in order now. Have couple of ideas while waiting, will show them after the weekend. |
#9 |
Multimodder
I was thinking of edging the acrylic with wood like edging tape. not sure yet because it was pretty hard to get clean looking trim. Here is a practice piece.
What do you guys think? I might want to get something a bit darker. |
#10 |
Multimodder
you could engrave a hundred tiny raspberries...if you were that bored?
not sure on the tape. how about trying some dark wood like teak and glue on some tiny strips?
#11 | |
Multimodder
And with my engraving skills, ill will settle on some lettering, but more on that later. |
#12 |
Hypermodder
Why would you buy a tap for mobo standoff in plastic?
Take a 2.5/3mm drill and you can screw the mobostandofs easely in! it taps his own thread
#13 | |
Multimodder
Tried that. But I kept having really bad results with it, having the standoffs leaning in one way or another. and the tapdrill will come in handy in future mods or builds. got the bug now , just had to start from something small.
#14 |
breaker of things
Could do what i did, drilled them and set the standoffs in using plasiweld
__________________
AMD Phenom X6 1605T @ 4.5Ghz |Corsair H80 |Gigbyte970A-UD3 | 2X4 GB Kingston HyperX Beast | ASUS AMD 6950 2GB DirectCU II | Corsair HX750 | Liteon DVD RW | Samsung HD103SJ 1Tb | Crucial M4 SSD 64GB | Phobya FanMax 6 | Edimax EW-7612Pln | Coolermaster Storm Trooper | Win 7 Pro 64it | Roccat ARVO | Logitech G500 | Bamboo 1 | Samsung SyncMaster 2033SW |
#15 |
Multimodder
#16 |
Multimodder
small update
Hey guys. i decided to go with the edging tape. And it actually looks better when i did the whole edge than on the tryout piece.
Took me a while to trim it. Still a bit ruff but i'll do the finishing touch after i can remove all the protective tape. I also did these for the led that I am thinkin of installing. Just took 3 pin connector an cut it in half and trimmed it to be two single pins. led will be connected the GPIO. Tried out to engrave some random letters too, obviously i need more training in that. ![]() Till the next time. |
#17 |
Mega mom
I do believe you have a chance of winning this competition!
#18 |
Multimodder
#19 |
Multimodder
Do ya need to have the rasberry pi it self for the contest or just to make a case for it?
__________________
Finished: -Mini-PC http://forums.bit-tech.net/showthread.php?t=248203 unfinished: none!
#20 | |
Multimodder
Here is the competition information. http://www.bit-tech.net/modding/2013...-competition/1 |
| Thread Tools | |
| View Mode | |
