Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 31st Jan 2013, 10:05   #1
Shirty
Here from the future...
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
Taming a curly beard
OK, so I bit the bullet in November and grew my first proper beard beard. Always done stubble but never gone the distance and let it grow out before. Sadly for me my hair is very curly, and apparently my facial hair is no different.
Any tips on preventing protruding hairs? Is it just a case of combing it out of the shower and regularly trimming the more uncooperative hairs, or is there a prduct I can use to control the beard a bit more,preferably without making my face any greasier than it already gets?
I'm well aware that this might develop into a general beard appreciation thread, so if it does I'll amend the thread title.
Anyone else sport the most manly of secondary sexual characteristics? Opinions?
__________________
6700K | Z170I | Liqtech 120X | EVGA GTX 980Ti SC | 16GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 31st Jan 2013, 10:06   #2
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
Hairspray? Personally I let my beard roam free after its regular trimming, although it generally behaves.
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 31st Jan 2013, 10:11   #3
Shirty
Moderator
Shirty's Avatar
Is yours curly? Mine isn't afro curly, but it is pretty unruly at only about 8mm long.
__________________
Old 31st Jan 2013, 10:14   #4
sniperdude
Supermodder
sniperdude's Avatar
sniperdude is definitely a rep cheat.sniperdude is definitely a rep cheat.sniperdude is definitely a rep cheat.sniperdude is definitely a rep cheat.sniperdude is definitely a rep cheat.sniperdude is definitely a rep cheat.sniperdude is definitely a rep cheat.sniperdude is definitely a rep cheat.sniperdude is definitely a rep cheat.sniperdude is definitely a rep cheat.sniperdude is definitely a rep cheat.
LMAO
__________________
2500k @4.1Ghz /BeQuiet Dark rock advanced / Gigabyte Z68 UD4 /8GB Corsair Vengeance /MSI twin frozr GTX 670 /Audigy 4 Platinum Pro /128GB+64GB Crucial M4's /Antec P182 /BeQuiet Dark Power Pro 650W.
sniperdude is offline   Reply With Quote
Old 31st Jan 2013, 10:24   #5
Deviate
I *am* a Dremel
Deviate's Avatar
Deviate has yet to learn the way of the Dremel
My "goatee" is a full on unruly mess and is about 3 inches (so...about 75 mm?) from the bottom of my chin. My wife bought me a styling wax called Short Sexy Hair Control Maniac. It works ok, but it leaves it feeling kind of greasy and gross. It smells like grape though.
My morning routine is to get out of the shower (I don't wash the goatee with shampoo every day as it needs natural oils to stay somewhat calm) dry it as best as I can. Then I use a wide tooth comb and comb down through it and then back against the grain so it fluffs out all over the place. Then I dry it some more. I guess I could use a blow dryer...nah...too girly. Then I brush it back down with a semi-stiff bristled brush. I use the styling wax on particularly wild days, but I try not to use it more than two days in a row.
BTW, I haven't trimmed mine in over 7 months now. My wife is about to the point where she just wants it gone.
__________________
"On a long enough time line, everyone's survival rate drops to zero."
--Tyler Durden--
Deviate is offline   Reply With Quote
Old 31st Jan 2013, 10:25   #6
Mankz
5318008
Mankz's Avatar
Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.
Shave?
Mankz is offline   Reply With Quote
Old 31st Jan 2013, 12:23   #7
mrlongbeard
Ultramodder
mrlongbeard's Avatar
mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.
8mm!!!!!!!!
Come back when you've grown a beard sonny.
mrlongbeard is offline   Reply With Quote
Old 31st Jan 2013, 12:25   #8
jinq-sea
The Double Insulates
Moderator
jinq-sea's Avatar
jinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyan
I just combed mine with a normal comb, but my hair isn't that curly.
Hair straighteners?
__________________
Comrade Woody: "I dunno, whores are a bit like cornflakes, you always regret buying the cheap ones."
small(ish): i7-5960X / X99E-ITX/AC - Bitspower Block / 32Gb Ballistix / Titan X (P) / 512Gb Samsung 950 Pro NVMe / 250D
tiny: i7-4790K / Max VII Impact - EK Monoblock / 16Gb Ballistix / EVGA Titan X (M) HC / 256Gb SM951 NVMe / nCase M1
htpc/vr: i7-6700K / Z170i / 16Gb Ballistix / EVGA 1080 Founders Edition / 128Gb SM951 NVMe & Sandisk 960Gb SSD / RVZ01
jinq-sea is offline   Reply With Quote
Old 31st Jan 2013, 12:27   #9
Shirty
Moderator
Shirty's Avatar
I'll probably keep it fairly neat for work purposes. I recently trimmed it from around 15mm. I'm only client facing a few times a year, but they are multi-million pound clients and a giant face-rug might scare them away.
__________________
Old 31st Jan 2013, 12:33   #10
Scroome
Ultramodder
Scroome's Avatar
Scroome is a Super Spamming SaiyanScroome is a Super Spamming SaiyanScroome is a Super Spamming SaiyanScroome is a Super Spamming SaiyanScroome is a Super Spamming SaiyanScroome is a Super Spamming SaiyanScroome is a Super Spamming SaiyanScroome is a Super Spamming SaiyanScroome is a Super Spamming SaiyanScroome is a Super Spamming SaiyanScroome is a Super Spamming Saiyan
I wish I could grow a proper beard.
I've tried, but it just looks awful.
No bear beard for me
Scroome is offline   Reply With Quote
Old 31st Jan 2013, 12:35   #11
longweight
Possibly Longbeard.
longweight's Avatar
longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.
Have you tried beard oil?
longweight is offline   Reply With Quote
Old 31st Jan 2013, 12:38   #12
Shirty
Moderator
Shirty's Avatar
Nope - recommendations?
__________________
Old 31st Jan 2013, 12:43   #13
true_gamer
Cheesecake on sale!
true_gamer's Avatar
true_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyan
How can you guys cope with a beard? I mean, when mine gets to 2mm it itches like mad, and out comes the razer...
__________________
i5 4670K @ 4GHz - Corsair H100i - MSI Z87-G45 Gaming Mobo - 16GB Hyper X DDR3 2400MHz - SandDisk Ultra 2 120GB SSD - 500GB SSHD - 2x Asus R9 280X DCU2 - Coolermaster 1KW PSU - NZXT Phantom 530 Case - Philips 40" 4K Monitor BDM4065UC
ORIGIN username: wipeyourarse - Steam ID: true_gamer - UPLAY ID: true_gamer
Crysis 3 Ultra Config Crysis 1 ultra Config
true_gamer is offline   Reply With Quote
Old 31st Jan 2013, 12:44   #14
Shirty
Moderator
Shirty's Avatar
If you fight through the itching for about a month it goes away. You have to be determined
__________________
Old 31st Jan 2013, 12:51   #15
Scroome
Ultramodder
Scroome's Avatar
I feel like an update to the what do you look like thread is in order.
The beards must be shared!
Too creepy?
Old 31st Jan 2013, 12:53   #16
Shirty
Moderator
Shirty's Avatar
I might, but I have rotten conjunctivitis at the moment so nothing until that goes. In answer to your question: kinda
__________________
Old 31st Jan 2013, 12:59   #17
Scroome
Ultramodder
Scroome's Avatar
Seems legit.
I'll tone the creep down.....just a little.
My other half uses a hairdryer and a comb for his. Seems to work pretty well and his hair is (or was) curly. Straight out the shower and combs it through.
Old 31st Jan 2013, 13:01   #18
Shirty
Moderator
Shirty's Avatar
All that said, I did choose my tags for this thread carefully before I posted it, so I think I can forgive you.
__________________
Old 31st Jan 2013, 13:03   #19
Scroome
Ultramodder
Scroome's Avatar
Wait, you put those in.
You bear trapper you lol
Old 31st Jan 2013, 13:11   #20
mrlongbeard
Ultramodder
Too creepy?
Tramp Beard;
Drunk Beard;
Mr T Beard;
Reply
Tags
beard overclocking, beards, bum fluff, cock tickler, face muff, facial hair
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
